One thing...
Started Aug 25, 2021 | Polls
RLight Senior Member • Posts: 4,418
One thing...
There is often, but not always, something one wishes they had more of. Curious to hear other R owners (all of them) thoughts on the following:
What is the the most important thing you could use more of?
I'll followup with another poll in a minute though for ownership so there is context. If a bunch of RP people respond for example, it's going to sound like the higher end R's have no FPS, battery life and dynamic range, for example
The polls don't permit multiple answers; feel free to also respond below with comments as I'm sure many will.
 RLight's gear list:RLight's gear list
Canon EOS R3 Canon EOS R50 Canon RF 28-70mm F2L USM Canon RF-S 18-45mm Canon RF-S 55-210mm F5.0-7.1 IS STM
POLL
Longer 4K / 8K recording time
3.1% 2  votes
Megapixels
12.3% 8  votes
ISO / low light capability
24.6% 16  votes
Dynamic Range
18.5% 12  votes
Autofocus speed / accuracy
13.8% 9  votes
Frame per second
6.2% 4  votes
Battery Life
16.9% 11  votes
Video options (codecs, modes, etc)
4.6% 3  votes
  Show results
OP RLight Senior Member • Posts: 4,418
Re: One thing...
Not complaining so don't hear what I'm not saying, but for me? More ISO / low light sensitivity (less noise at higher ISOs) tops my list. FPS comes in at a very close second. Video options, in my case lower bitrates for 4k to give my Synology an easier time and uncropped 4K come in just after that by a hair, with autofocus after that.
The original R is an amazing little beast, but, it's showing it's age when you shoot a 14FPS, uncropped 4K capable M6 II next to it. I've shot an R5 before, IBIS is nice as is 45MP, but ironically less useful than I would've thought for my shooting style. Stacked BSI sensors coming to the R is refreshing as when you look at what my former Nikon 1J3 could do (high FPS, lightning fast AF, smooth video), fast sensors are a very good thing. Really looking forward to what Canon does with the R1, upcoming R and RP refreshes. The latter two may or may not get BSI/stacked CMOS though.
jwilliams Veteran Member • Posts: 6,385
None of the above ...
6
None of the above. The one thing I'd like to see more of is affordable lenses and camera bodies. The Price of the RF system has really gotten off the rails expensive and I already have spent what most sane people would think is an exorbitant amount of money on camera gear. The almost non-existant 3rd party lens support doesn't help either.
The cameras have the technical capabilities for pretty much any type of practical photo needs already. The problems to be solved are mostly not technical in nature but developing a system that can appeal to someone other than deep pocketed pros and enthusiasts.
If I could ask for anything specific it would be an updated RP.   Add IBIS and a sensor with modern tech. The RP is the only camera that is  really technologically behind by any significant amount.  A few updates would make it the ideal inexpensive and small/light camera.
Jonathan
Re: None of the above ...
Touché, you might get your wish. I was just thinking what Canon could do for the RP, and they can either drop the R sensor in it, or add IBIS, or both.
Probably the former; IBIS adds a decent measure of weight and cost. RP is about small, light in my book.
The R II will probably have IBIS though.
thunder storm Forum Pro • Posts: 10,139
Re: One thing...
Number 1: AF, stickyness of subject tracking and speed (accuracy of the R is fine)
But there's more:
  • better SOOC colors, especially in low light situations with dark backgrounds
  • IBIS
  • dedicated DOF preview button. It's always there, and you don't have to remember how important it is to assign this function to a button. The R wasn't a good first full frame camera in that regard.
I love 50mm (equivalence)
 thunder storm's gear list:thunder storm's gear list
Canon EOS 6D Canon EOS M6 II Canon EOS R5 Sony a7 IV Canon EF-S 15-85mm f/3.5-5.6 IS USM +24 more
I'd like the R6 sensor but either would be a nice upgrade.
Yeah, I'm guessing that's probably not a high probability.
What scares me are the rumors of an even cheaper R model.  If that is the follow up to the RP then you'll probably see the camera body itself go down hill which is a shame as the RP body really nails it for its intended purpose.
They really need to compete with the Z5 which means a better sensor even if it's not state of the art and really IBIS I think, but I doubt we'll see the latter.  Thats OK, but give us at least one wide to normal prime if all R bodies aren't going to have IBIS going forward.  40 2.8 IS would be fine with me.
I Think a camera with just 'R' or 'R II' for the name is not in the cards but I'm just guessing.  Seems the marketing is confusing at the very least.  Numbers do a good job of differentiating the models.  Just 'R' makes one wonder where in the hierarchy it fits.
Jonathan
KiloHotelphoto Contributing Member • Posts: 770
Re: One thing...
The only thing I wish for is a bigger body and maybe the R3 will solve that.
I have two R5's with grips and they aren't bad but would like it a little bigger and for all the controls to be the same vertical and horizontal. When I go vertical with the grip the joystick is not in the same spot and it gets annoying trying to find it and I have missed shots.
The R3 body looks nice but it's not worth it for me to buy just for that.
Also wish they would let you choose a slower frame rate when using the electronic shutter. Sometimes I want to shoot silent and not to disturb a animal but don't need 20 fps. Just to save time going through shots in post, it's amazing how fast they add up.
 KiloHotelphoto's gear list:KiloHotelphoto's gear list
Canon RF 600mm F4L Canon EOS R5 Canon EOS R3 Canon RF 24-105mm F4L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +4 more
tkbslc Forum Pro • Posts: 17,522
Re: One thing...
As an Rp owner, I'd hope the Rp mark II would address these shortcomings:
  • improved 4K video (less crop and/or better AF in 4k mode.  Not expecting pro video features)
  • improved DR (it's got the worst DR in the FF world right now)
  • Improved Battery
I don't think it really needs IBIS. I'd rather keep it small and cheap. If I needed faster burst rates and pro AF, I'd expect to pay up for an R6.
I think if I had to pick one, as the threat title says, I'd pick battery. That impacts me frequently whereas the others are just occasional annoyances.
Re: One thing...
  • Improved Battery
Agree with this. You're not buying the RP for the f/2.0 zoom, and all the others are stabilized. The 35mm and 85mm stm have IS as well. The 50 stm is a budget option anyway.
Re: One thing...
  • Improved Battery
50L and 85L too, with similar argument.   But also all those lenses are fast enough and short enough that you are not likely to need IBIS very often anyway.   Nobody had IBIS on a 50 or 85 prime for the entire history of Canon SLR cameras and it's never been a real issue.
The Nikon Z5 has IBIS, so maybe Canon will feel like they need to add it to compete.  And certainly I'll take it.  But it's way lower on the list than better sensor and battery for sure.
PicPocket Veteran Member • Posts: 5,897
Re: One thing...
I think IBIS will become as ubiquitous as AF, the only question is how long before it happens. Given the nature of tech, I would say soon
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
justmeMN Forum Pro • Posts: 10,706
An extremely compact "R200" (no EVF) might be interesting. That wouldn't overlap with the RP's product position.
MAC Forum Pro • Posts: 18,487
Re: One thing...
  • Improved Battery
I'd add -- ss 1/8000
and better implementation of e-shutter
I would need many improvements before buying another
the SOOC colors and jpgs are wonderful and I don't want to mess that up
 MAC's gear list:MAC's gear list
Canon EOS 7D Mark II Canon EOS RP Canon EOS M6 II Canon EOS R8 Canon EF 70-200mm f/2.8L USM +7 more
DigitalAmnesia Forum Member • Posts: 77
Re: One thing...
The R5 meets my needs 99% of the way. It is hard for me to imagine how it could be better, not saying it couldn't, just saying I don't know what that would look like in normal conditions. I really didn't know how the R could be improved upon either, but when I got the R5 every shot got more "atmospheric". It's easy to point and say "more ISO", or whatever, but I get along pretty well with what the R5 can do. Yesterday however I took pictures of a black cat in a poorly lit home and the ISO was up at 25600 and the images were I hate to say, cellphone quality. You might be laughing about the black cat in a dark room scenario but it happened. So, that is one case where maybe the R5 isn't a perfect camera.
 DigitalAmnesia's gear list:DigitalAmnesia's gear list
Re: One thing...
  • Improved Battery
I'll take it, but I already have some ND filters.
Seems like firmware could fix that one.  Makes no sense it is only available in a scene mode.
viska Contributing Member • Posts: 601
Re: One thing...
So,no coalmines available for the shoot?
 viska's gear list:viska's gear list
Pentax K-3 Olympus PEN-F Pentax K-1 Fujifilm X-T3 Canon EOS RP
Re: One thing...
At some point the light is just so low that it is bad light.  Being able to capture horrible light with less noise isn't going to make for good photos.   If it's a bad photo because of the bad light, who cares if it is noisy or not, it's not a photo you are going to want to use.
That could be interesting IF they make some very compact lenses (primes mostly) for it and give it a tilt screen for easy waist level shooting.  A compact camera with no viewfinder and nothing but big lenses isn't very appealing.
I just hope the RP isn't a one and done model and from then on it's higher end cameras and one model made as cheaply as possible.  That would be sad.  The RP deserves a follow up with a better sensor at least.
Jonathan
Re: One thing...
Not laughing at all. My R breaks down at 25600 too.
This is one area the R6 excels; really low light. I know DPR just got done saying R5 > R6, but my research shows when you start punching ISOs above 12800, the R6 looks better. Now how wise it is to shoot above 12800 to begin with is another story.
Part of this poll is curiosity, the other is to address where I think things will go and whether or not that “plugs the holes” so to speak. Things like the R5 are a modern technological wonder, however, it’s still an FSI sensor. The R1 will clearly be stacked CMOS and thus BSI. The difference is about 1/3-2/3 stops, in other words ISO 25600 on an R1 should look like ISO20000 or 16000 on and R5. Those are much more workable ISOs.
The R6 sensor will get BSI first in the form of the R3. That one has my attention.
Canon will probably do another DIGIC iteration with the R1; curious if it’ll improve both throughput and power efficiency. Depends how fancy they get with its design.
My bet? Dual DIGICX. DIGICX2/Y might be a split or hybrid design. The R1 needs sheer power. Other non demanding sensors need efficiency where I can see high speed and low speed cores.
Re: One thing...
LOL
