17-50mm Lens on an SD1 Merrill - Sharpness Field.
Started Aug 24, 2021 | Discussions
xpatUSA
xpatUSA Forum Pro • Posts: 23,017
I'm reading about Lens Field Curvature in articles by Roger Cicala (he of Lens Rentals fame). I've also read comments here about a significant field curvature from the 17-50mm. Cicala mentions that the field curvature of a lens can be shown by shooting grass and then applying Edge Detection to the resulting image:
https://www.dpreview.com/opinion/4042117089/roger-cicala-why-i-dont-use-an-mtf-bench-to-test-my-own-lenses
I intend to do that soon with my copy of the 17-50mm, set at f/2.8 and a few different focal lengths.
But, meanwhile, I tried out Edge Detection on a shot taken at 23mm focal length with the said lens:
The usual test scene ...
Focus was on the far tree tops about 600 ft distant. SPP settings were all at default, including Sharpness. Algorithm was Laplace as found in the GIMP - there are others ...
Not the best scene for Field Curvature, but I'm beginning to wonder why I sold the SD1 Merrill.
"It all depends on what the meaning of 'is' is ..." Our Bill C., as seen on TV.
Panasonic Lumix DMC-LX1 Sigma SD9 Panasonic Lumix DC-G9 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Sigma 17-50mm F2.8 EX DC OS HSM +11 more
Sigma SD1 Merrill
Scottelly
Scottelly Forum Pro • Posts: 18,028
Re: 17-50mm Lens on an SD1 Merrill - Sharpness Field.
Nice!
I'll swap it for an SD Quattro H, if you can get hold of one of those Ted.
Merrill.
Scott Barton Kennelly
https://www.bigprintphotos.com/
 Scottelly's gear list:Scottelly's gear list
Sony SLT-A65 Nikon D810 Sigma sd Quattro H Nikon AF-S Nikkor 200-400mm f/4G ED-IF VR Sony DT 18-55mm F3.5-5.6 SAM +27 more
xpatUSA
OP xpatUSA Forum Pro • Posts: 23,017
LOL, Scott, I bet you would!
Did you miss this one at $650?
https://www.ebay.com/itm/393373281992
Item was sold, BTW.
In the link, ebay is showing an alternative for over $800 ...
Tom Schum
Tom Schum Forum Pro • Posts: 13,282
I had that lens and shot it with my SD1.  I don't have them anymore, but I do remember I was not particularly impressed with the lens overall.
Tom Schum
"Beware of taking advice from anonymous wise men." Quote from Anon.
Fujifilm X30 Sigma dp0 Quattro Panasonic ZS100 Fujifilm X-T3 Fujifilm X-E4 +14 more
mike earussi Veteran Member • Posts: 9,440
I own it now and use it on my SD1M as a snapshot lens, but it's certainly nothing I'd use for high quality work.
 mike earussi's gear list:mike earussi's gear list
Sigma SD1 Merrill Sigma 105mm F2.8 EX DG Macro Sigma 17-50mm F2.8 EX DC OS HSM Sigma 50mm F1.4 DG HSM | A Sigma 24-35mm F2 DG HSM Art +2 more
rick decker
MOD rick decker Forum Pro • Posts: 19,097
Ditto
I hadthe 17-50 and have still the 17-70 C. They both have soft corners until around 30 or 35.  I did a whole set of comparisons with  using an SD1.  I kept the 17-70.  Although the differences were not that great, given other issues given - weight, size OS and close-up capability, and center sharpness, I kept the 17-70.
You have my express consent to edit any of my images that I post on DPR. If you want to edit an image that does not belong to me that I have edited and posted, you need to contact the owner.
http://www.lightreflection.com
http://www.rickswavepics.com
Scottelly
Hey Ted, what did you find out?
I found my 17-50mm f2.8 OS EX lens in my backpack. I'll shoot some photos on some flat grasslands for you, and post one or two here. I just might try shooting the flat surface of a parking lot too. I figure that should do it pretty well. I'll shoot a canyon with it too, so you can see how great that lens is for shooting canyons.
BTW, my Sigma 24-135mm f2.8-4.5 in Nikon F mount has a lot of field curvature too. It works great for some stuff on my D810. Here's a thread I posted with a bunch of samples from that lens:
https://www.dpreview.com/forums/post/62268435
xpatUSA
Nothing definitive, I'm afraid. Couldn't find an homogeneous enough patch of grass.
Looking forward to those for sure ..
I looked at the edges in the 'excess curvature' example but didn't see why the lamp on the post should be terribly out of focus. 56mm at f/8 is an aperture size of 7mm, so anything in the scene bigger than that will be resolved. One would need to know the distance to the lamp and the distance to the balcony to see if the lamps parts should be well-resolved or not. See:
http://www.trenholm.org/hmmerk/TIAOOFe.pdf
By "resolved" I do not mean in perfect focus - plead read the link carefully especially about Convolution - or "pseudo science" as @jfa3000 often says.
P.S. I just now looked at the lamp in QuickMTF - the whole image is over-sharpened, so I'll refrain from further comment about that particular lens' focus field curvature.
