X-E2 won’t turn off and doesn’t react
Started Aug 23, 2021 | Questions
dvdpchlr New Member • Posts: 5
hey dpreview-community,
my trusted X-E2 recently decided to not work anymore. Maybe some of you had the same problems…
When I am turning it on, the screen will “light up” black.
The camera doesn’t react, no matter which button I am pressing.
When I am switching it off, it will stay on with the same black screen.
I tried different batteries, lenses and sd-cards. Fuji and third-party.
I was able to do a firmware-update from the newest firmware to… the newest firmware, but it didn’t solve the problem.
Thank you in advance for any helping comments!
 dvdpchlr's gear list:dvdpchlr's gear list
Canon EOS 5D Mark II Fujifilm X-E2 Canon EF 50mm f/2.5 Macro Fujifilm XF 27mm F2.8 Fujifilm XF 23mm F2 R WR +5 more
Fujifilm X-E2
Robmas4229
Robmas4229 Senior Member • Posts: 1,272
Re: X-E2 won’t turn off and doesn’t react
Hi, strange issue. Not sure what "light up black" means but I guess you mean somehow the LCD turns on but is dark. How about the EVF, is that the same? Same for shooting and playback modes?
How did you perform a firmware re-load if you couldn't see any display?
 Robmas4229's gear list:Robmas4229's gear list
Fujifilm X-E3 Fujifilm X-T3 Fujifilm X-T30 II Fujifilm XF 18-55mm F2.8-4 R LM OIS Samyang 12mm F2.0 NCS CS +7 more
j tokarz Senior Member • Posts: 1,387
Sounds to me as though the camera has bitten the dust. (possible motherboard prob'). Good excuse to replace.
El Vuelo del Escorpion
El Vuelo del Escorpion Contributing Member • Posts: 883
Probably is a silly suggestion, but maybe you changed the display mode? (Turning LCD off)?
Óscar
IG @oscarlagarrotxa @mallorca.in.love | Landscape: https://500px.com/p/fingers1971 | www.oscarlagarrotxa.com | www.mallorcainlove.es |
 El Vuelo del Escorpion's gear list:El Vuelo del Escorpion's gear list
Panasonic Lumix DMC-LX3 Fujifilm X-E2 Fujifilm X-T2 Fujifilm X-H1 Nikon AF Nikkor 35mm f/2D +13 more
(unknown member) Regular Member • Posts: 122
This part is the most troubling. Since you've tried different batteries, I assume that also means that you've taken the battery out. Have you tried leaving the battery out for a day and trying again?
How did you accomplish that? The screen for firmware updates works, but the regular screen doesn't?
Have you been able to try a factory reset? Maybe you can see the screen through the HDMI?
If that doesn't work, you might be out of luck on a self repair.
OP dvdpchlr New Member • Posts: 5
Yes, the LCD turns on but is black. EVF doesn’t react.
The updatescreen will show up when pressing the “display/back-button” while turning the camera on.
yep, no effect even after a week
the updatescreen is the only thing that will show up when pressing the disp/back button while switching it on.
since i can’t access any menus i wasn’t able to do a factory reset (or is there a way without accessing the menus?). i will try the HDMI tho, thanks!
The camera doesn’t react to any buttons whatsoever (except for firmwareupdate) - so i can’t change any settings or the displaymode
Robmas4229
So nothing in playback mode either? Only have a display when you initiate the software version/update option?
It may be worth a call to Fujifilm tech support, otherwise I think it's time to go shopping my friend. Sorry for your loss. Not sure what the repair costs would be but likely not worth the expense.
Bodils New Member • Posts: 1
I have the exact same problem on my X-E2. Did you find a solution to the problem OP?
I wasn't OP. It looks like the thread was started with an account that was used only for that thread, so they might not respond, unfortunately.
