16-80 on X-E1-4 unbalanced?
Started Aug 21, 2021 | Discussions
User4993559350
User4993559350 New Member • Posts: 15
Anyone using the 16-80 on an X-E series camera?
I generally shoot landscape and use an X-T3 with 10-24 / 16-55 / 50-140 and the 33 f1.4.
But with my X-E3 as my daily camera, only the 35 f1.4 feels reasonable on the body and I've used the 18-55 and thought it felt good, but would appreciate a little more reach.
I'm interested in the 16-80 for general use but worry about the lens weight.
Anyone use this combo and care to share?
 User4993559350's gear list:User4993559350's gear list
Olympus Tough TG-3 Panasonic LX100 Panasonic Lumix DMC-GX85 Fujifilm X-E3 Fujifilm X-T3 +7 more
Fujifilm X-E3 Fujifilm XF 16-80mm F4
GreatOceanSoftware
GreatOceanSoftware Senior Member • Posts: 1,222
Re: 16-80 on X-E1-4 unbalanced?
It is certainly more substantial than the 18-55. You’ll probably want a grip accessory to take away some of the imbalanced feeling. But I don’t mind it on my XE4. I use a Gariz half case and it helps.
Randy
 GreatOceanSoftware's gear list:GreatOceanSoftware's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 60mm F2.4 R Macro Fujifilm XF 18-55mm F2.8-4 R LM OIS +11 more
Fujila New Member • Posts: 21
I have the 16-80 and an X-E3. It's a little front heavy but perfectly usable especially if you have a wrist or neck strap.
a_c_skinner Forum Pro • Posts: 13,047
I use the 16-55 and 80mm on an X-E3. They balance perfectly. You put your left hand under the lens, palm up. You can manipulate the control rings too.
Just learn the craft.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
