Auto FP / HSS on XE-3
Started Aug 19, 2021 | Questions
Donnie AI
Donnie AI New Member • Posts: 10
Hello Everyone,
Hope all of you guys are doing well and good.
(I apologize if this has been asked  before)
I am currently in the process of migrating from Sony to Fuji. I am eyeing on a used XE-3 (2nd hand prices of it on our place is really cheap) not to mention I prefer the rangefinder more than the usual SLR style. The XPRO2 is still on the high side so that's a not an option for me.
The only thing that is holding me back is if it support HSS?
This is rather big for me as I use flash / strobes 95% of the time. I tried searching online but I can't seem to find a direct answer.
Thank you all in advance.
 Donnie AI's gear list:Donnie AI's gear list
Sony a6000 Sony E 50mm F1.8 OSS Sigma 30mm F2.8 DN | A Sigma 16mm F1.4 DC DN (E/EF-M mounts) Sigma 56mm F1.4 DC DN | C (X-mount)
RogueOne Regular Member • Posts: 200
Re: Auto FP / HSS on XE-3
It requires a HSS compatible trigger.  I was actually testing a trigger this morning and my Flashpoint X-Pro allowed HSS easily while another trigger did not.
 RogueOne's gear list:RogueOne's gear list
Fujifilm X-T2 Fujifilm X-E3 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +4 more
Donnie AI
OP Donnie AI New Member • Posts: 10
That's good to hear. I was worried that the lower end bodies are setup like Nikon / Canons, wherein HSS are only made available to their higher end offerings.
Im currently invested in the Godox system. Will probably get their Fuji trigger then.
Thank you so much for your help.
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,178
Yep this works
Hi Donnie
I confirm this. The X-E3 is technically the same camera as my X-T20.
The Godox TT 685 F and the X-Pro F trigger work also in HSS mode.
What doesn't work is the AF assist, https://www.dpreview.com/forums/post/63544168
Kind regards,
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Donnie AI
Re: Yep this works
Hi Donnie
Kind regards,
Martin
Thank you for sharing. Really appreciate the information. I can be more at ease then with my purchase.
Stay Safe always and Best Regards.
