X100V eyepiece issue
Started Aug 19, 2021 | Discussions
kulvershtukas New Member • Posts: 22
Hi there,
maybe somebody knows, if the eyepiece rubber part is replaceable? Mine started to peel of after 5 days of accurate use. Most probably will be quite bad in a few month.
Fujifilm FinePix X100 Fujifilm X10 Leica X1
ViMa
ViMa Senior Member • Posts: 2,150
Re: X100V eyepiece issue
Hi. Your screen also seems scratched just where the eyepiece is, so it seems you bumped it somewhere.
Vittorio
_________________________________________________
https://www.flickr.com/photos/155724624@N06/
 ViMa's gear list:ViMa's gear list
Ricoh GR III Ricoh GR IIIx
OP kulvershtukas New Member • Posts: 22
Hi, nope, it’s not scratched, it’s a reflection. Screen is totally fine.
but the main question is if the eye cup is replaceable or not.
Here is a bit different angle
iRanN
iRanN Contributing Member • Posts: 660
kulvershtukas wrote:
Hi there,
What is accurate use? I used one for months, daily and doesn’t have a mark on the eye piece, that looks to me like it took a good hit on something sharp enough to damage it.
But to answer the question, no, they eye piece isn’t user replaceable.
AE Conrady
AE Conrady Regular Member • Posts: 252
The 100V has a rather robust rubber eyeoeace which doesn't peel off easily. If you have still guarantee, I would sent to an official Fujifilm repair center.
 AE Conrady's gear list:AE Conrady's gear list
Fujifilm X100V Fujifilm X-Pro3 Fujifilm XF 18mm F2 R Carl Zeiss Touit 2.8/12 Fujifilm XF 56mm F1.2 R +1 more
Hi there,
accurate use means not a single hit, wore it in a special bag when not used. No rubbing, tearing etc. So definitely not caused by wrong use.
Most probably will do so, thnx
redisred Regular Member • Posts: 119
Mines got the same issue but farther along. It's right where it rubs against my eye socket when I look through it. I've used it a lot though, so I wasn't totally surprised when it started happening. It seems to just be the shiny coating on the rubber that's wearing off; the rubber itself is still fine. It's a mild cosmetic bummer, but not bad enough to be without the camera for a month and deal with fuji's incompetent New Jersey repair center. I'm past a year now, so I'm just going to live with it. I honestly had forgotten about it until reading this.
 redisred's gear list:redisred's gear list
Fujifilm X-Pro3 Fujifilm XF 35mm F2 R WR Fujifilm XF 23mm F2 R WR Sigma 56mm F1.4 DC DN | C (X-mount) Fujifilm XF 18mm F1.4 R LM WR +1 more
So I am not the only one. Most probably have to consider it as battle scars than even if replace it there is a chance the new one will peel as well
notchy
notchy Contributing Member • Posts: 713
I was thinking "hmm, haven't noticed this on mine" but then I checked and saw that my 100V also has some peeling on the top of the eyepiece ring. A little surprising as the roughest surfaces my eyepiece has encountered have been my eye socket and the soft finish of the padding in the camera bag it lives in -- or so I thought. I suppose it's possible that I scraped it against some surface, but if I did, I wasn't aware of it.
I should point out that the peeling is rather more obvious in a photograph than it is in real life (which is why I hadn't noticed it).
Peeling surface of X100V eyepiece ring
 notchy's gear list:notchy's gear list
Fujifilm X100V Fujifilm X-H1 Fujifilm X-T3 Fujifilm X-Pro3
Toilet Roll
Toilet Roll Regular Member • Posts: 281
My X100v paint on the top plate has chips, quite annoying and dont know how it occurred.
I place it screen side down im my camera bag so might have to avoid doing that if the eyepiece is fragile too.
 Toilet Roll's gear list:Toilet Roll's gear list
Fujifilm X100V Canon EOS 5D Mark III Canon EOS R
tolgatacmahal Regular Member • Posts: 134
yes
 tolgatacmahal's gear list:tolgatacmahal's gear list
Ricoh GR Sony Alpha NEX-5N
Kavanadb New Member • Posts: 1
This is an old thread but it seemed there was some doubt that eyepiece wear was an issue with the x100v.
Here's my eyepiece after 18months. The rubber has worn away so much that the metal beneath it is coming through. In my case I wear glasses so I can imagine it wears much faster than for people who don't but I still find it pretty disappointing. I'm risking scratching my glasses using the camera now.
I had the original x100 for ten years before this and the rubber never wore away.
bs1946
bs1946 Veteran Member • Posts: 7,778
I have an X-E4 and an X-T2 with three primes. I was planning to sell my X-T2 and one of my lenses, but with all of the quality and reliability complaints I keep seeing posted here and in other Fuji forums and groups about the X100V and X-T4, I'm beginning to have second thoughts about keeping the X-E4 instead of the X-T2.
Bill S.
www.flickr.com/photos/wrs1946
“Sharpness is a bourgeois concept”
- Henri Cartier-Bresson -
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
DirkPeh
DirkPeh Contributing Member • Posts: 520
tolgatacmahal wrote:
yes
The scissors seem to have the same owner as the camera...:-)
 DirkPeh's gear list:DirkPeh's gear list
Panasonic LX10 Ricoh GR III Fujifilm X100V Sony a6400 Sony E 50mm F1.8 OSS +5 more
athensGA Contributing Member • Posts: 751
Same issue here 12 o' clock position. I just hope it isn’t progressive.
 athensGA's gear list:athensGA's gear list
Ricoh GR III Fujifilm X-Pro3 +1 more
Christian Unger
Christian Unger Regular Member • Posts: 179
Anyone similar experience or got it fixed?
I have the same problem after about a week without "abusing" it - a small part of the top layer of the eyepiece rubber came off.
I'm wearing glasses so maybe this can be the reason.
 Christian Unger's gear list:Christian Unger's gear list
Panasonic Lumix DC-S5 DJI Pocket 2 Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 85mm F1.8 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS +2 more
Coldpaw Contributing Member • Posts: 772
To my knowledge it is not possible to simply replace the eyepiece alone, so you either have to live with it, send it to Fujifilm for replacing the whole piece or use some DIY methods in order to at least try fixing it up a bit.
Christian Unger
I saw that the eyepiece with sensor is available on Ebay for 65 usd so I assume it won't be so expensive to have it fixed by fujifilm.
I'm not worried but would be interested if someone got it fixed (under warranty?). I hope it will last a while but it would be great if it could be replaced at a later time.
mcmarfia Forum Member • Posts: 83
I've got a similar experience with the eyepiece on my X-Pro3 Dura Silver. It is peeling off and getting worse unfortunately. Since it's still under warranty I'm considering to contact Amazon (where I purchased the camera from) and see what they can do about it.
