Question, 75/1.8 on G9
Started Aug 17, 2021 | Discussions
DrHook59
DrHook59 Contributing Member • Posts: 856
Re: Question, 75/1.8 on G9
Interceptor121 wrote:
The sigma focuses slow compared ton Panasonic lenses is well known. Moreover many sigma lenses are slow to focus on all formats
Sigma 60 focuses pretty darn quick. Certainly quick enough for tennis balls in flight. AND it's the cheapest of the lot around this focal length!  This is a SAF single shot example below.
_____________________________________
Some of the coolest things in life are really, really small.
https://www.flickr.com/photos/roddyhays/
 DrHook59's gear list:DrHook59's gear list
Panasonic Lumix DMC-GX8 Panasonic Lumix G X Vario PZ 45-175mm F4.0-5.6 ASPH OIS Olympus M.Zuiko Digital ED 60mm F2.8 Macro Sigma 60mm F2.8 DN Art Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS +2 more
Gnine Senior Member • Posts: 4,108
So does the 56. I'll post a sequence shot in AFS, well AFC without DFD anyway, of some bikes traveling at 30-35km/hr when I get a chance. I honestly can't pick a difference between it, and native Panasonic m4/3 lenses
DrHook59
Interesting - I mean, if there is a quicker focusing lens please advise me!
Skeeterbytes Forum Pro • Posts: 23,186
At the focal length we're discussing the 40-150 Pro focuses very fast and silently. It may be a product of the dual focus groups and voice coil motors. In that FL range I have not encountered anything faster, the 75/1.8 included.
There may be others but they have not made it into my bag.
Rick
Interceptor121 Veteran Member • Posts: 8,691
You haven’t stressed the lens enough bikes going at 35 km/h is not a good test you need to look at acceleration in the frame
A bird or even a person starting from still and doing a sprint towards you for example or another sudden movement. Objects moving at constant speed with you panning are almost static
sigma dc lenses are well known to be accurate but slow to focus. 16mm as it is wide an exception
this is not a huge problem for the 56mm as the use case is typically portraits
The 75mm in this thread is slower that was my point
would prefer not to go off topic on this thread that is about the olympus 75mm 1.8 that I also have just wanted to give some perspective on similar though not identical lenses
In terms of IQ I do think the 75mm 1.8 has an edge however the use case is not exactly the same and 56mm is a bit wider and faster and that helps many situations but the 75mm is a great lens if you can put it to use no doubt
 Interceptor121's gear list:Interceptor121's gear list
Sony a1 Panasonic Lumix DC-GH5 II Panasonic Lumix DC-GH6 Panasonic Leica DG Macro-Elmarit 45mm F2.8 ASPH OIS Canon EF 8-15mm f/4L Fisheye USM +24 more
