90/2.0 handheld?
Started Aug 16, 2021 | Discussions
dccberry Senior Member • Posts: 1,239
Re: 90/2.0 handheld?
Dem Bell wrote:
dccberry wrote:
I would suggest renting the 50-140 and see how it behaves for you. I bought the 90, and sold it quickly. Focal length is not that useful, and for me, the 50-140 is a great workhorse. The weight is not bad at all, especially if you have used the Nikon equivalent.
Some numbers to ponder on...
Lenses:
Fuji XF 50-140 f/2.8 = 995g
Nikon 70-200mm f/4 G ED VR AF-S = 850g
Camera bodies:
Fuji X-T4 = 607g
Nikon D750 = 840g
Together:
Fuji = 1602g
Nikon = 1690g
I don't find either setup heavy in actual use. The 70-200-type lenses are the only zooms I ever use, the rest being fixed focal length. I play a 9 pound electric bass regularly, so compared to that, the cameras are featherweight!
 dccberry's gear list:dccberry's gear list
Ricoh GR Nikon D810 Nikon D850 Fujifilm X-T3 Fujifilm X-T4 +10 more
Corot2 Senior Member • Posts: 1,697
Fuji 16-80
Good for travel and great lens 6 stops  ois may be perfect for travel and family
https://500px.com/corot2
Until you realize how easy it is for your mind to be manipulated, you remain the puppet of someone else's game
 Corot2's gear list:Corot2's gear list
Fujifilm X100F Fujifilm X100V Fujifilm X-M1 Fujifilm X-T1 Fujifilm X-E2S +11 more
stratman1976
OP stratman1976 Senior Member • Posts: 1,277
Lenses:
Camera bodies:
Fuji X-T4 = 607g
Nikon D750 = 840g
Together:
Fuji = 1602g
Nikon = 1690g
I see your point, but I use a D850 and 70-200/2.8E FL and that combo is well over 2 kg
 stratman1976's gear list:stratman1976's gear list
Nikon D700 Fujifilm X-T3 Nikon AF-S Nikkor 24-70mm f/2.8G ED Nikon AF Micro-Nikkor 60mm f/2.8D Nikon AF-S Nikkor 85mm F1.4G +12 more
stratman1976
Re: Fuji 16-80
Yes, it would, kind if would make my 18-55 redundant. Looks like the 16-80 is not that sharp at 80mm when you move away from the center though.
Re: Fuji 16-80
I have read conflicting reviews on edge sharpness
I guess if one really pixel peeps then maybe
However, most people do not examine the edges when looking at a photo.
So much sharper than previous generations so imho for most people probably is not an issue.
Bernie Ess Veteran Member • Posts: 7,153
I have both, 56mm and 90mm
I used both on stabilized (X-H1) and unstabilized (X-T1 + T3) bodies, for dimly lit concerts, musicals and such.
90mm is indeed not easy, you need at least 1/90s, if the person moves, better 1/125 which, at f2 will push your ISO up quickly. But it is what it is: once you nail focus and can hold the camera still, you're rewarded with great and very sharp photos with beautiful bokeh. Inside you need the space if you want more than a head shot of course...
The 56mm/1,2 has less contrast and sharpenss (wide open at least) but also can deliver nice portraits.
I don't intend to sell any of these, but if I had to, it would be the 56mm...
'All the technique in the world doesn’t compensate for the inability to notice.' (Elliot Erwitt)
 Bernie Ess's gear list:Bernie Ess's gear list
Fujifilm X-T3
stratman1976
Hi everyone,
OP reporting back here. Just ordered the 56/1.2 today and it will arrive tomorrow. Just thought the 56 would be more versatile than the 90, plus I wanted to keep the size and weight down a bit.
I'll report back soon!
