OP
notuno
Forum Member
Re: G7 as a second camera?
Hi all,
I did some tests (brick wall and other subjects, mostly on a tripod, at different focal lengths and exposures) to compare my GX85 with the G7, and the Panasonic 14-140 f/3.5-5.6 lens with both the Olympus 40-150 f/4-5.6 and the Panasonic 12-32mm lenses.
I don't have time to export and upload images right now but here are my observations (keep in mind the G7 and 14-140 are brand new, the rest of the material is five years old):
Lens comparison:
1. At 40mm on the GX85, the 14-140 has a somewhat narrower FOV than the Oly 40-150. I cannot see any difference in color. The Olympus is somewhat sharper in the center, Panny sharper in corners.
2. At 14mm, the 14-140mm is considerably sharper than the 12-32mm lens. At 32mm, the 12-32 is slightly sharper instead.
3. At 140mm 1/2000 s, on the GX85 the Olympus lens is slightly sharper than the Panasonic lens. On the G7, it's the other way around, I don't know if this is due to antialiasing filter.
Camera comparison:
4. Indeed I see some shutter shock when comparing mechanical and electronic shutter on the G7 with the 14-140mm, at different focal lengths and exposures. I don't see it on
the GX85 under the same conditions.
5. At 40mm with the 14-140 lens, the G7 with electronic shutter is slightly sharper than the GX85. Surprisingly, even with mechanical shutter, at 1/125's the G7 is slightly sharper.
6. At140mm, using the 14-140 with electronic shutter, G7 is just as sharp as GX85.
7. With prime lens (17mm f/1.8 Olympus) shots are just as sharp with both cameras. So are
videos on a tripod. Handheld, obviously the GX85 wins because of stabilization.
8. Auto white balance gives quite different colors, with the GX85 giving redder images. I prefer the G7 colors.
9. S priority gives different apertures, slightly darker on G7
Bottom line:
For general outdoor use, the G7 with the Panasonic 14-140, used with electronic shutter, is a more than viable substitute for my GX85 with the 40-150, 12-32 combo (I lose slightly range at both ends obviously). For static videos, the G7 with prime lenses is also a more than viable substitute.
