Lens or body defect?
Started Aug 10, 2021 | Questions
Electuur New Member • Posts: 21
A friend of my has a Panasonic G7 and a LUMIX G VARIO 14-140/F3.5-5.6 lens. Often she gets bad photo's, like this photo:
What is wrong?
We think there is a defect in the lens or body.
 Electuur's gear list:Electuur's gear list
Panasonic G85 +2 more
Panasonic Lumix DMC-G7 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S
alcelc
alcelc Forum Pro • Posts: 19,006
What made you unhappy?
14
Although I couldn't examine the image close on my phone screen, off hand found nothing wrong.
Please kindly let us know what made you thinking your gear has problem?
A point wish to mention is f/11 has entered the diffraction zone of M43 such that the output might on the soft side.
Albert
** Please forgive my typo error.
** Please feel free to download the original image I posted here and edit it as you like **
Panasonic Lumix DMC-GX1 Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GX85 Panasonic Lumix DMC-GF3 Panasonic G85 +11 more
Boss of Sony Senior Member • Posts: 2,425
Re: Lens or body defect?
What is wrong?
I think there are a number of things going on here.
1. It’s a very bright sky, and the camera has exposed correctly, keeping the highlights under control, which might make the foreground a bit darker than you expected.
2. You might have the sharpness and noise reduction a bit high, resulting in less fine detail. This would be even more obvious if you used the vivid profile.
3. The camera’s automatic JPEG processing might not be to your taste. DPreview several times noted that Panasonic cameras tend to under-expose JPEGs compared to Olympus. The more recent Panasonic models have massively improved JPEG processing, with much nicer colours in my opinion. I recommend shooting RAW and processing with DXO Photolab if you’re unhappy with the camera’s JPEGs.
 Boss of Sony's gear list:Boss of Sony's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix DMC-GF1 Olympus M.Zuiko ED 75-300mm 1:4.8-6.7 II Olympus 9mm F8 Fish-Eye Body Cap Lens Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS
Jouko Senior Member • Posts: 1,985
Strange thing seems to be, that while the red flowers (poppies) seem to be sharp and in focus, the red bush on the right (and in the about middle around another bush) are just a mess, no definition,no details. Like blurred...
Was there some wind or something like that? The shutter speed seems to be fast enough to stop normal motion, but if that bush has very fine foliage, that can "move" fast to get a blur. The F11 wont help, that's beyond the diffraction limit - better to use F8 or faster aperture. Usually there is enough DOF anyway in the mFT format for landscapes even wide open.
Also shooting RAW and developing the photos in some program in computer can bring out more details than in camera jpg's. Use DxO, Lightroom, Darktable, Capture1 or something. Plenty of choices, some better than others, some free, some cost. Those programs will also bring out more possibilities for adjusting the light levels, colors etc for the taste - but of course using those will take some time, but also give something new to the hobby.
Learning photography will give lots of unsatisfying photos, but also those masterpieces... The key is to learn from those bad ones and try to make the good ones better.
Have a nice day!
Jouko
'The best camera in the world is the one you have with you when you need it'
https://www.instagram.com/jouko.k.lehto/
http://lehtokukka.smugmug.com/
http://jouko-lehto.artistwebsites.com/
https://joukolehto.blogspot.fi/ - Lenses for mFT-cameras
https://joukolehto.blogspot.fi/2015/12/what-to-dowith-camera-during-winter.html
bs1946
bs1946 Veteran Member • Posts: 7,780
If your friend has access to another lens and just stop using the 14-140mm lens for a while. If the problem goes away, then it is probably the lens, if not then it's probably the camera. Make sure that the G7 and the 14-140mm have the latest firmware updates and also consider a reset of the G7.
Bill S.
www.flickr.com/photos/wrs1946
“Gear Doesn’t Matter”
- Mattias Burling (Swedish Photographer & Videographer) -
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 12-60mm F3.5-5.6 OIS Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 20mm F1.7 II Apple iPhone 12 Pro Max
martinhb Contributing Member • Posts: 801
Would be helpful if two images were displayed, one good & the other bad so that it's possible to determine what is expected. Mentioning the lens indicates that the problem is to do with focusing & blurriness of the image, is this assumption correct?
 martinhb's gear list:martinhb's gear list
Canon PowerShot G1 X Olympus E-M1 II Panasonic Lumix DMC-G3 Panasonic Leica D Vario-Elmar 14-150mm F3.5-5.6 Asph Mega OIS Olympus 12-100mm F4.0 +3 more
RSTP14 Veteran Member • Posts: 6,370
What is wrong?
Or the photographer.  A little explanation as to what you find upsetting migh be helpful. What is wrong? Is that a trick question?
Roger
 RSTP14's gear list:RSTP14's gear list
OM-1 Olympus M.Zuiko Digital 17mm F1.8 Olympus 12-45mm F4 Pro +4 more
Isola Verde
Isola Verde Forum Pro • Posts: 10,640
What is wrong?
I suspect, perhaps due to the passage of time since it was taken, that your friend may have misinformed you?
Her image apparently measures 4592 pixels by 2932 pixels - although the range of "Large" dimensions listed in the G7 manual are...
aspect ratio [4:3] 4592 x 3448
aspect ratio [3:2] 4592 x 3064
aspect ratio [16:9] 4592 x 2584
aspect ratio [1:1] 3424 x 3424
So I wonder if she has trimmed her picture slightly, either "in camera" or subsequently, and - in doing so - saved it at a lower quality that the original?
Indeed, from the G7 instructions...
My own JPGs of similar scenes from 16MP Panasonics generally tend to be a bit larger than the 5.69 MB of this one!
[Personally, I'd avoid f/11 - and would have preferred to shoot this instead in A mode, at f/6.3 or f/8, hoping for a higher shutter speed still, with base ISO]
All that said, the frondy maroon "flowers" of the bushes at centre and right were probably never going to come out very well at such a distance?
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus PEN E-P7 Olympus OM-D E-M10 IV
Simon97
Simon97 Veteran Member • Posts: 3,444
Why f/11 and ISO 400? Judging by the exposure data, Base ISO and a wider aperture would be better. Image is a bit contrasty. The tree gets a little dark. Sky could use more definition. Landscapes are often better done shooting raw and tweaking the contrast, color and exposure.
Composition wise, the image is not that interesting. Perhaps trying different angles, focal lengths, ect. would yield something better.
 Simon97's gear list:Simon97's gear list
Canon PowerShot ELPH 360 HS Panasonic Lumix DC-G100
Skeeterbytes Forum Pro • Posts: 23,186
That's what I notice--they look like little poofs of smoke with no definition. I don't know what I'm looking at and whether it's some kind of technical anomoly.
Otherwise it's just a snapshot of modest distinction.
The recommendation of opening the aperture is on target, I don't know that lens' sweet spot. I might play with HDR or at least do an exposure bracket to find best exposure. And add a pola filter.
Rick
Albert Valentino Veteran Member • Posts: 9,770
Yes, base ISO and wider aperture means more DR potential, sharper results, and faster shutter speed to minimize blur from wind blur on foliage. Also, excessive processing, especially noise reduction, will reliably blur detail rich parts of a photo.
Lens or body defect? Neither IMO, likely technique, shooting settings and/or processing choices. If lens or body then the problem would be easily reproducible
If you don't get older and wiser, than you just get older.
 Albert Valentino's gear list:Albert Valentino's gear list
Olympus E-M1 III Olympus M.Zuiko Digital ED 60mm F2.8 Macro Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 Panasonic 8-18mm F2.8-4 +10 more
ahaslett
ahaslett Forum Pro • Posts: 12,662
There is definitely something very wrong with this image.
Various other posters have mentioned the inappropriate settings, which make it hard to pin down the likely cause.  My guess is a focus problem.
Can you ask your friend to take 2 identical images on a tripod at ISO 200, f6.3 and 24mm with shutter timer delay.  For the first use SAF and for the second MF.
If you could upload the RAW files somewhere and post a link, we can have another look.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
Please feel free to edit any images that I post
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
Bassam Guy Veteran Member • Posts: 4,890
+1 But What?
What do you see wrong that would indicate anything but exposure related problems suggested elsewhere? That would indicate a lens or body problem?
I'm in a meeting right now and can't take too close of a look at the photo.
 Bassam Guy's gear list:Bassam Guy's gear list
Olympus E-M5 III Olympus E-M1 III Olympus M.Zuiko Digital ED 12mm 1:2 Olympus M.Zuiko Digital 17mm F1.8 Olympus M.Zuiko Digital 25mm F1.8 +8 more
ahaslett
Re: +1 But What?
The whole image is blurred on my laptop screen at Original Size.  Looks fine on a phone.
Andrew
Pete Berry Veteran Member • Posts: 4,322
5
What is wrong?
Time to answer back, OP. Do you see anything "bad" aside from the possibilities enumerated above?
Personally, I think there's a little kid hidden behind the dark red bushes on the right shaking the limbs to blur the flower bunches...
Box Brownie Veteran Member • Posts: 4,366
IMO to ask a question without specificity is not a question.
In other words exactly what you are asking for feedback on, what exactly do you and your friend think is wrong with the image ???
Trevor Carpenter
Trevor Carpenter Forum Pro • Posts: 19,436
6
user error.  Nearly always the answer before camera or lens..
Panasonic G85 Panasonic Lumix DC-G9 OM-1 Panasonic Lumix G Vario 14-140mm F3.5-5.6 O.I.S Olympus M.Zuiko Digital ED 60mm F2.8 Macro +1 more
Felice62 Veteran Member • Posts: 5,079
Couldn't see anything particularly bad from viewing on the phone screen but the G7 is prone to shutter shock so you might have some portions of the image blurred, perhaps?
If only closed minds came with closed mouths..
 Felice62's gear list:Felice62's gear list
Olympus Stylus 1 Olympus Tough TG-3 Olympus Stylus Tough TG-850 iHS Panasonic ZS100 Olympus E-M5 II +36 more
drj3 Forum Pro • Posts: 12,636
The blurred bush looks like what happens when you use DXO Deep Prime and it interprets something with little detail as noise and which it then completely blurs to remove the noise.
drj3
 drj3's gear list:drj3's gear list
Olympus E-M1 Olympus E-510 Olympus E-5 Olympus OM-D E-M10 Olympus E-M1 II +13 more
olrett Contributing Member • Posts: 684
That blurred bush looks like it's a https://en.wikipedia.org/wiki/Cotinus_coggygria
No wonder it looks blurred.
 olrett's gear list:olrett's gear list
Olympus TG-6 Panasonic Lumix DMC-LX3 Panasonic Lumix DC-G9 Olympus OM-D E-M10 II Olympus E-M1 II +25 more
