Maxxum macro setting
Started Aug 8, 2021 | Discussions
ESQuicksall New Member • Posts: 6
I have a Minulta Maxxum 5D. I want to take extreme close-ups. Is there a way?
Konica Minolta Maxxum 5D (Dynax 5D)
neilt3
neilt3 Veteran Member • Posts: 3,008
macro lens , not a setting
Yes , quite simple really .
It depends on what your calling extreme closeup .
Do you mean close-up photography at less than life size , or macro , from a magnification of life size upwards ?
If you want 1:1 reproduction you buy a macro lens . That will put an image on your sensor that is the same size as the item your photographing .
So you will fill the frame with something the size of a full bumblebee .
If you want a higher magnification then you buy the Minolta 1x-3x macro lens .
So at 3x life size , you would get only a proportion of the bumblebees body in the frame .
I wouldn't call this extreme close up though .
For extreme close ups you need to use microscope objectives .
At 100x magnification you will be taking a shot of just part of a bee's eye .
If course a sturdy tripod is required , a perfectly still subject .
A well lit subject for focussing , and suitable macro flash to take the exposure to avoid noise from long exposures etc .
The higher the magnification , the closer to the subject the lens is , the less light there is and the harder it is to provide light .
 neilt3's gear list:neilt3's gear list
Minolta DiMAGE 7 Minolta DiMAGE 7Hi Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Konica Minolta DiMAGE A200 +68 more
neilt3
A question of manners .
Also , this is the third post you've made and the third time you've asked a question .
But you've yet to have the manners to respond to the people that have tried to help you .
It's only polite to at least say "thanks" . I learnt that of my parents not long after I learnt to talk .
Were you not tought the same ?
Manners cost nothing .
If you ask a question where a question is asked to you , if you can't be bothered answering , then it's impossible to help you further .
Regards .
