Recommendations for Scanning Slides
Started Aug 7, 2021 | Discussions
paul wassermann Senior Member • Posts: 2,274
Have a large number of 35mm slides and negs to digitize; wonder what works best?  Looking at Kodak digitizer for around $150.  Want simple, fast, accurate images that could be printed up to 8 x 10.
 paul wassermann's gear list:paul wassermann's gear list
Sony a9 Sony a7C Sony FE 90mm F2.8 macro Sony FE 100-400mm F4.5-5.6 Sony FE 24mm F1.4 GM +5 more
Bobthearch
Bobthearch Forum Pro • Posts: 11,052
Re: Recommendations for Scanning Slides
Flatbed scanner with a backlight, like the Epson V600.
Of course my biggest tip is to carefully and hyper-critically cull the selection before the tedious process of prepping and cleaning the slides for scanning.
Personal non-commercial websites with no ads or tracking:
Local photography: http://ratonphotos.com/
Travel and photography: http://placesandpics.com/
Special-interest photos: http://ghosttowns.placesandpics.com/
 Bobthearch's gear list:Bobthearch's gear list
Nikon D7100 Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Tokina AT-X Pro 11-16mm f/2.8 DX II Nikon AF-S DX Nikkor 18-55mm f/3.5-5.6G VR II +2 more
OP paul wassermann Senior Member • Posts: 2,274
Thanks!  I just solved my problem ( I think).  I have a light tablet, have made a painter's tape rectangle just slightly smaller than a 2 x 2  mounted slide.  I can just carefully slide the slide in under an edge of the tape.  I set up my Sony a9 with 90mm macro lens on a small tripod with the camera carefully positioned square with the slide surface.  Two second delay after a shutter press and the image is captured.  So far I am really impressed with the detail still preserved in these vintage film images.  I am able to clean, load, and photograph a slide in about 30 seconds; the camera does a wonderful job selecting exposure and white balance.  So far, so good and have done about 100 slides.
Bobthearch
Glad to hear it.
ProfHankD
ProfHankD Veteran Member • Posts: 9,147
Use HDR
Pretty close to what I was about to suggest (Duplihood ).
However, try putting your A9 into multi-shot auto HDR mode. Slides commonly have about 2 stops of extra DR that is encoded with wildly wrong (too dark) tonality, making it invisible to humans viewing the projected slide, but the huge DR of the auto HDR mode and tone mapping it applies often can pull those shades back into useful scene detail.
Canon PowerShot SX530 Olympus TG-860 Sony a7R II Canon EOS 5D Mark IV Sony a6500 +32 more
Re: Use HDR
Thank you for the suggestion...I'll give it a try tomorrow!
iljitsch Senior Member • Posts: 1,635
Scanner with infrared
I used an Epson scanner with slide and negative scanning attachments to scan slides and negatives. Took a good amount of time, but now I have digital copies of all my slides and negatives.
Biggest issue: dust and other debris. I understand that this can be largely fixed in software for color film/slides if you have a scanner that has an infrared channel. So I'd highly recommend that.
 iljitsch's gear list:iljitsch's gear list
Nikon D7100 Nikon Z fc Nikon AF-S DX Nikkor 16-85mm f/3.5-5.6G ED VR Nikon AF-S DX Nikkor 35mm F1.8G Nikon AF Nikkor 50mm f/1.8D +10 more
ProfHankD
Dust removal without an NIR image
Flatbed scanners tend to have more of a dust issue than other methods of slide scanning -- after all, they have a piece of glass fixed horizontally near the focus plane and it can get dusty.
The dust/srcatch removal is generally done by capturing an NIR image to use as a mask. The dark pixels in NIR are simply interpolated over. A better fix would be to do true inpainting to fill the gaps. I was thinking I could write code to automatically recognize and fix the dust spots without NIR, but it's been done: Automatic Sensor Dust Removal . Yes, that's essentially the same problem as dust on scanned film. Anyway, they link to python OpenCV code that finds the spots & inpaints to remove 'em: Python-Automatic-Sensor-Dust-Removal .
Re: Dust removal without an NIR image
I was able to digitize all my slides by photographing them with my Sony 90mm macro lens using a backlit drawing tablet.  I used masking tape to make a top and bottom little ledge that would hold the slide.  Blew compressed air on the slides and wiped with microfiber cloth and then photographed.  They came out great...surprised how much detail was present in the underexposed areas of the slides.
DoctorCamel Junior Member • Posts: 26
DoctorCamel wrote:
https://vimeo.com/12405612
Thanks!  My system (excluding the tripod, camera, and macro lens) cost about $50.  I set exposure to manual, f11 aperture priority, ISO 100 and AWB.  Used two second delay with remote trigger.  I got the light pad on Ebay used and it has really met my needs.
Entropy512 Veteran Member • Posts: 6,016
Re: Use HDR
Alternatively, just bracket raw and feed the results to hdrmerge - https://github.com/jcelaya/hdrmerge - rather than trust whatever the camera does internally as far as tonemapping.
Context is key. If I have quoted someone else's post when replying, please do not reply to something I say without reading text that I have quoted, and understanding the reason the quote function exists.
 Entropy512's gear list:Entropy512's gear list
Sony a6000 Pentax K-5 Pentax K-01 Sony a6300 Canon EF 85mm F1.8 USM +5 more
ProfHankD
Re: Use HDR
Lots of tools can do HDR processing, but the Sony in-camera version actually does surprisingly better than most in this case, which is an odd case because the extra info isn't with appropriate brightness to scale normally. The tone mapping just happens to do well with it.
The other issue is that you might need as much as 6 stop HDR coverage, and bracketing on many cameras doesn't handle that well. It also means a pile of raws because it's best done with more than two shots. Still, you are absolutely right that you can do a little better with raw captures and really careful tweaking of the tone mapping....
Re: Use HDR
6 stop not handled well by most cameras?
I'm not sure of any camera that doesn't offer 5-shot 2EV steps (8EV between maximum and minimum), or 3-shot 3EV (exactly 6EV total)
I guess maybe I'm spoiled by Sonys, even really old Sony bodies (like the A6000) did 3-shot with 3EV steps per shot?
GreatWhiteWing Senior Member • Posts: 1,675
When I scanned a couple thousand slides I used a slightly older (now) flatbed that can hold a number of slides (I don't remember number) at a time and the software worked pretty well.
I did consider having it done by a service but that was pretty costly at the time, maybe a decade ago. Back in win 7 days
I also did a lot of negative scans too and again worked pretty well but it was a time commitment
 GreatWhiteWing's gear list:GreatWhiteWing's gear list
Canon EOS 5D Mark IV Canon EF 24-70mm F4L IS USM Canon EF 16-35mm F4L IS USM Tamron SP 70-200 F2.8 G2 +2 more
