Tedolph can save Olympus!
Started Aug 3, 2021 | Discussions
tedolf
OP tedolf Forum Pro • Posts: 29,548
Re: Tedolph can save Olympus!
Peter CS wrote:
Why would anyone want to own both a 35mm and 40mm FX equivalent lens as two out of three total lenses? Not a practical choice...
The lenses already exist and they focus the same way rf lenses do-all the elements move as a single unit. All you have to do is glue the cam on the back and take out the AF mechanism.
Tedolph
 tedolf's gear list:tedolf's gear list
Olympus PEN E-P5 Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Olympus M.Zuiko Digital ED 40-150mm 1:4-5.6 Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Samyang 7.5mm F3.5 Fisheye +9 more
victorav Senior Member • Posts: 2,751
All things must pass.
Alexis D Contributing Member • Posts: 858
Re: Studying the Fuji X-E?
red pencil wrote:
Alexis D wrote:
It should help to analyse why Fuji can continue releasing the XE1, 2, 3, and 4, and apparently doing well, compared to M43 equivalents, e.g. GX8, GX9... PEN F, PEN F 11, E-P7...
Bigger sensor makes people feel more comfortable with their purchase
Bigger sensor essentially the same size bodies.  The X-E4, and also the X-S10, is also very small, about the same as the GX9 and PEN F.   People feel more comfortable with purchasing brands that show more commitment and that have a clearer future.   What M43 has is a lot of diehard fans.
The x-e4 is a very tempting camera, but not weather resistant (so weather resistant lenses don't matter) and no ibis. Ep7 basically the same size but has ibis. :/
Every brand has diehard fans, but if you spend too much time in forums you'll think everyone who owns a particular brand is a die-hard fan.
Guy Parsons
Guy Parsons Forum Pro • Posts: 40,000
Re: They did.....
pdelux wrote:
tedolf wrote:
victorav wrote:
tedolf wrote:
Now that the dust has settled with the Olympus spin off Tedolph freely gives his plan to Olympus. The plebeians here correctly asses that m4/3 is just not competitive with other larger formats unless it takes advantage of its reduced size potential. Right now this plays out in wildlife photography mostly. Others have noted that Fuji has carved out a niche even without any real advantage in the APS world probably due to the control layout. Leica (and now Nikon) play the retro card and that seems to succeed.
So, here is the plan: Olympus uses the old E-p5 body, takes out the flash and drops in the optical rangefinder from the Voigtlander Bessa rangefinders and makes three lenses with rangefinder cams on the back, the 17mm f/2.8, the 20mm f1.7 and a 42.5mm f1.7. In every other regard it is just the old e-p5 with the EVF accessory port.
Checks all the boxes: Retro, Rangefinder, Compact but still can use all the m4/3 lenses.
Done.
Tedolph
Maybe just stick an evf on the ep5.
They did. It was called the Pen F.
Then they stopped selling it.
Tedolph
And they missed the opportunity on the EP7 --- instead put a built in flash.
The E-P7 name is a misnomer, it is really an E-PL11 and is some sort of b@stard child of Pen Lite and Pen-F but born down to a price.
Gnine Senior Member • Posts: 4,108
Re: They did.....
victorav wrote:
I've seen it marked as discontinued though? Left over stock in circulation I guess?
And that tells you everything you need to know. The just didn't sell in large enough numbers then, why would they now? They'd probably sell 6 or 7 to the exceedingly vocal Olympus fans in here, and not many more.
(unknown member) Forum Pro • Posts: 47,805
But the X-E4 has vastly better AF and better image quality. It share the same image quality of the top of the line and same AF of the top of the line. I can't say that about the E-P7 as much as I like it.
While IBIS is nice to have. Better fast accurate AF is better.
No, not everyone.
Raist3d/Ricardo (Photographer, software dev.)- I photograph black cats in coal mines at night...
“The further a society drifts from truth the more it will hate those who speak it.” - George Orwell
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
Armchair engineering is so easy ....
In a real engineering job, your designs must function perfectly in thousands of units over a wide temperature range, the return rate must be well below 1%, the factory yield must be over 90%, cost to manufacture held to a minimum.
Lots of hard work in testing and debugging, predicting the power consumption and the temperature rise.
Cheers
Eric
(Feel free to edit and repost any image that I have posted in a DPR, as long as you identify me as the original poster)
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
bobn2
bobn2 Forum Pro • Posts: 71,955
Guy Parsons wrote:
bobn2 wrote:
It was the second time Olympus has done a faux Pen-F. The first time was the E-3, which had a side flipping mirror and porro-prisms like the original Pen F. It was about twice the size, though.
No, that was the E-300, mine still works but gosh it is huge after using my E-P5 for so long. 8MP of CCD Kodak sensor. Nice results.
Beg pardon, yes, it was the E-300.
The original F had a rotary FP shutter, which didn't cause shake.
Had a Pen FT back years ago, really jewel like camera that none of the digitals has ever managed to successfully copy in style and feel.
The strange thing of course was that it was half frame across the film. So to take landscape shots you held it portrait mode, and to take portrait shots you held it landscape style.
Traded my Pen FT and lenses in on some 6x6 medium format gear and was much happier with the results.
Is it always wrong
for one to have the hots for
Comrade Kim Yo Jong?
Guy Parsons
E-300 aside.
It was an curious attempt in the era of big/bulky electronics trying to fit in a certain size.
One interesting fact (for some) is that the E-300 TTL flash relied on a test flash just after the mirror got out of the way and before the shutter ran. The TTL test flash was metered off the closed shutter which was grey coloured. Then the shutter opened and the exposure flash happened when it was fully open (for first curtain sync).
The side effect of that was that the TTL and exposure flashes were only about 6 millisec apart and thus were too close together to allow S2 slave flashes to work as they need at least about 50 millisec between flashes to be able to count them reliably.
Been there done that with my E-300, S1 slave flashes failed because it triggers on the TTL pulse, S2 flashes fail because the two pulses are too close together so the S2 slave never fires.
When M4/3 came along they changed the period between TTL test pulse being measured and the first curtain flash pulse to something like 120 millisec so now S2 slaves work reliably.
Note: Memory might be hazy on the flash timing numbers as it was a long time ago, I used to record the flash pulses using a solar cell plugged into the audio input, then look at the timing of the resulting recorded signal to see the flash pulse spacing.
Anders W
Anders W Forum Pro • Posts: 22,144
What we need is not RF but FF!
Range finders are so last-century. In these mirror- and shutter-less times, Oly needs to take the final step and introduce the flange finder (aka FF), the sexiest see-through finder imaginable. I mean, who really needs a body when you’ve got a lens? 😎🤓
Panasonic Lumix DMC-G1 Olympus PEN-F Olympus E-M1 II Panasonic Lumix G Vario 14-45mm F3.5-5.6 ASPH OIS Panasonic Lumix G Vario 7-14mm F4 ASPH +20 more
As current fujin apsc, not gfx.
You should read the first line: "very tempting" for the reasons you described.
Ep7 issues the 20mp sensor, so current best sensor available in MFT cameras, not so much on the af side.
Depends on what you shoot. Em10 mkiii af is mediocre at best, but I have yet to be in a situation where s-af fails me.
No, not everyone.
That's my point...
Asla
Asla Senior Member • Posts: 1,101
I can't see...
Done.
Tedolph
Hi!
I can't see anything but bright future for this roadmap!:-D
A s l a
tedolf
Bingo.....
Guy Parsons wrote:
pdelux wrote:
Done.
Tedolph
Tedolph
Bingo. A big disappointment. It might make sense if the were going to discontinue the PL line but I don't see any evidence of that. I also don't see the advantage of eliminating the Accessory II port. It took a lot of accessories other than just the tilting EVF: flash, mic jack, macro lights, stereo mics, etc.
Must be something we don't know.
Tedolph
tedolf
Printing....
Once you crop the image to fit most common print sizes, e.g.  5x7", 8x10", 8.5x11", 11x14", 16x20" an APS sensor is putting about the same number of pixels on print as a 4/3rds sensor. So effectively, the APS sensor is no bigger than the 4/3 sensor especially if it is Canon.
Tedolph
tedolf
True.
Sigh....
Tedolph
JDLaing50 Veteran Member • Posts: 3,170
You can’t put a rangefinder in a ep5 body.
 JDLaing50's gear list:JDLaing50's gear list
Sony RX1R II Leica SL (Typ 601) Olympus PEN-F Leica M-P (Typ 240) Leica CL +12 more
bobn2
Re: Printing....
Not really
The highest resolution commercial mFT sensor is 20MP and 3888 pixels high. Most APS-C sensors are 24MP and 4000 pixels high, but there are also 26MP ones (Fujifilm) which are 4160 pixels high. The Canon 90d is 32.5MP and 4640 pixels high.
Any of those will put more pixels on the print than an mFT camera, especially if they are Canon (90D, at least).
In terms of sensor area, it is whatever is the long side and 13mm high for mFT, 14.8mm for Canon and 15.6mm for the rest. All will give a larger used sensor area than mFT.
Is it always wrong
gary0319
gary0319 Forum Pro • Posts: 10,540
Re: Bingo.....
If one takes the time to review the marketing material for the PL7, it becomes readily apparent that the target market for this camera is folks that prefer a tilt down selfie screen to an EVF, like cosmetic variety like white leatherette cases, prefer latte to beer, etc.
Little wonder that it was not introduced to the US market where everything needs to be offered supersized, and feature jammed packed. I also rather think the PL7 is a pretty poor design match for the armchair engineers on this forum.
 gary0319's gear list:gary0319's gear list
Olympus OM-D E-M10 IV OM-1 OM System OM-5 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R Olympus M.Zuiko Digital ED 14-42mm F3.5-5.6 EZ +7 more
ahaslett
ahaslett Forum Pro • Posts: 12,662
Re: Bingo.....
The burning issue that OMDS face is how to regain the market share in the Japanese MILC market that they lost in the transition from Olympus to OMDS.  Judging by many posts over the years, North America wasn’t a priority market for Olympus, so it’s probably not going to be one for OMDS.  They also have to prioritise cash towards survival or readiness for trade sale.
Olympus seem to have decided late in the day that their USP was handheld photography out in the wild.  Who knows where OMDS are going to position their offer and where limited MFT niche products will fit in that already niche part of the MILC global market.
If OMDS does cease trading there will be plenty of used gear for years plus multiple other MILC systems to switch to.
I hope not, as Olympus kit suits me, apart from their successive blunders on sensors and the long history of delayed product release post announcement.  At least with used gear, it’s available with a strong review and through life history.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
Please feel free to edit any images that I post
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
