bobn2
Re: Tedolph can save Olympus!
5
tedolf wrote:
Now that the dust has settled with the Olympus spin off Tedolph freely gives his plan to Olympus. The plebeians here correctly asses that m4/3 is just not competitive with other larger formats unless it takes advantage of its reduced size potential. Right now this plays out in wildlife photography mostly. Others have noted that Fuji has carved out a niche even without any real advantage in the APS world probably due to the control layout. Leica (and now Nikon) play the retro card and that seems to succeed.
So, here is the plan: Olympus uses the old E-p5 body, takes out the flash and drops in the optical rangefinder from the Voigtlander Bessa rangefinders and makes three lenses with rangefinder cams on the back, the 17mm f/2.8, the 20mm f1.7 and a 42.5mm f1.7. In every other regard it is just the old e-p5 with the EVF accessory port.
Checks all the boxes: Retro, Rangefinder, Compact but still can use all the m4/3 lenses.
I have a variant. Use a retro rangefinder, but make it electronic. That's much cheaper than the optical mechanical version. Behind the rangefinder window you put a small phone style camera. Now the processor compares the image from that with the image from the main sensor and uses the differences to work out the range. It can be AF or presented as a split image range finder box in the EVF. Most of the advantages of on sensor PDAF without the special sensor. Plus, it can be presented as a faux, old style RF.
The real problem though is most of the retro stuff is playing with the manufacturers' own heritage. Olympus has already played the game with the OM and Pen F SLRs, but it didn't ever make interchangeable lens RF cameras.
Is it always wrong
for one to have the hots for
Comrade Kim Yo Jong?
