Confirmed: The R3 will have a 24 MP sensor. Locked
Started Aug 2, 2021 | Discussions
This thread is locked.
9VIII Senior Member • Posts: 1,331
Re: Confirmed: The R3 will have a 24 MP sensor.
Canon can swap sensors at the drop of a hat.
The resolution of a preview body is almost meaningless.
They probably will stick with 24MP, but if all the Canon representatives (the only people Canon listens to) go up in arms about it Canon would have a new sensor in there by the end of the week.
 9VIII's gear list:9VIII's gear list
Canon EOS 1100D Fujifilm X-E2S Fujifilm X-E3 Canon EF 400mm f/5.6L USM Sigma 150mm F2.8 EX DG Macro HSM +7 more
PicPocket Veteran Member • Posts: 5,897
No they cannot
Any basis to these unrealistic claims?
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
Doppler9000 Senior Member • Posts: 1,573
I believe you are underestimating the complexities involved here.
A sensor and supporting electronics are designed and built as an integrated package.
There are data throughput issues, including thermal limitations, which mean that there is a negative correlation between resolution and frame rates.  If you want more resolution, you get slower output.
Canon cannot just pop a higher resolution sensor and get the same output speeds.
Thomas A Anderson Senior Member • Posts: 1,360
Then we should have 1GP sensors by now.
Doppler9000 wrote:
Thomas A Anderson wrote:
archerscreek wrote:
yayatosorus wrote:
According to DP Review , the R3 will indeed feature a 24 megapixel sensor.
I see many continue to hold out hope, reasoning that it’s possible Cable and other R3 shooters submitting images simply don’t want to shoot anything higher than 24 MP. The flaw with that line of reasoning, however, is that Cable is also shooting with two R5 cameras in his gear bag and is submitting images with higher resolutions than the R3 ones. If the R3 had a higher resolution potential, it would have shown up.
It’s time to admit it and get over your disappointment. The R3 is a 24MP camera.
It also stands to reason that when they're working on a new technology, in this case a BSI CMOS, that they wouldn't instantly have the highest pixel density available. They had to come up with the architecture, the manufacturing tooling and processes, and then prove that it could be mass produced. The only way to do that is to do it. And a proof of concept is great, but making money off of the result is even better. So they get it all figured out on a lower MP sensor, start cranking out sensors, work through all the bugs at a low rate initial production, and slowly ramp up. Then, once all those details are worked out they can work on cramming twice as many pixels in (again, not only BSI but also DPAF, which means they're already doing 48MP on a 24MP output sensor) and get a decent yield.
Hard to believe Canon’s 2021 chip fab capabilities are that far behind Samsung’s from 7 years ago.
How long has Canon had BSI CMOS fabs? How does Canon's CMOS chip architecture transfer to a BSI layout? Did they have to entirely reinvent their technology? Because the issue here is that this is new to Canon, not to the world. Canon had to figure out their own way of doing it....assuming they didn't steal or purchase the tech from someone else.
Presumably they would have licensed pieces of the required IP instead of being more than 7 years behind?
For example, Canon got CMOS engineering advice from Mitsubishi when it set up its sensor fab operation.
Samsung sold cameras in 2014 that had 28 MP APS-C BSI CMOS sensors.
And those 28MP sensors were Dual Pixel with two photodiodes at each pixel location? And while BSI CMOS may define the architecture of a chip to a certain point, there are still architectural details that differ from sensor to sensor.
2014.
2008.
That's the year Sony announced development of their first BSI CMOS sensor. In 2010 they announced a 16.41MP BSI CMOS phone sensor that started shipping January 2011. It was a 1/2.8" sensor with an area of around 20 mm2 (that's rounding up). A FF sensor is 864 mm2, which is 44.2 X the area. So my question is why hasn't anyone, even Sony, made a 725MP FF sensor? The technology existed in 2010 to do it, which means anything less than that should be considered falling behind Sony's abilities.
At this density, a full frame sensor (~63 MP) would be the highest resolution FF photographic camera on the market today.
And who's to say they could have upscaled that density to a FF size while still getting enough yield to put it in an affordable camera? One can't simply assume that's the case.
I didn’t assume anything - just pointing out the implied pixel density and that it seems unlikely that 2014 Samsung had significantly denser sensor production capability than Canon’s maximum 2021 capability. Seven years is a pretty long time to lag behind someone in this sort of technological space. The facts point to an answer that isn’t that 24 MP is Canon’s current BSI chip density max, in my view.
You are free to disagree, but saying that Samsung perhaps could’t have produced a FF 63 MP BSI chip in 2014 due to potential yield issues rather misses the point of the benchmark.
I would think the resolution vs speed trade offs in the R3 reflect Canon’s view of the needs of the target photographers, more so than technical fabrication constraints.
But the technical fabrication restraints result from the architecture that allows increased read speed on the chip. This is why I said BSI CMOS doesn't tell the whole story: if it did then every sensor using that technology would run at the same speed, but integrating amplifiers, onboard memory, onboard buffer, or whatever other vertical integration/stacking that may be necessary also plays a role. And that's not to mention materials used in the sensor circuitry itself, the processes required to make that type of manufacturing feasible, and changes to physical architecture that could say....increase speed, increase efficiency, increase dynamic range. There are so many details of the pixel itself, the transport of data, amplification, etc. etc. that go into these things besides simply cramming more and more pixels into the same space.
 Thomas A Anderson's gear list:Thomas A Anderson's gear list
Canon EOS R
Re: Then we should have 1GP sensors by now.
2008.
This paragraph uses both the "Straw Man" logical fallacy and a false analogy.
Not very compelling.
Also, unclear that it supports your contention that in 2021, Canon is technologically-limited to a 24 MP limit for a FF BSI sensor.
By the way, leaving technical sensor concerns aside, the reason we are unlikely to see, or want, a 725 MP FF camera is diffraction.
You would be limited to fast lenses and large apertures or give your resolution back to diffraction.
https://www.dpreview.com/forums/post/62940604
BigBen08 Veteran Member • Posts: 7,472
Here's what will happen, Canon will offer the R3 in two versions, 24mp and 50mp.
Hey, a sweet dream isn't it ?
My best aviation photos: https://500px.com/kenfm2018
(unknown member) Regular Member • Posts: 217
2014.
2008.
2014.
That is the year the first BSI showed up in an interchangeable lens camera.  No, it wasn't a Sony nor was it made by Sony.   In fact,  some argue that sensor is still better than one found in the camera Sony released just a few days ago!
2008.
You cited a Samsung APS-C from 2014 as a benchmark for Canon 2021 BSI CMOS sensor manufacturing as a method for comparing and evaluating Canon's technical and manufacturing expertise/experience. Why is an APS-C sensor from 2014 a more valid benchmark for comparison than a 1/2.8" sensor made by Sony in 2010?
Please explain applying your logical fallacies to my comparison but NOT to your comparison.  The fact is that using your logic the Samsung sensor you use as a benchmark is itself far behind where it should be based on the sensor Sony shipped in 2010.
Neither was your comparison to Samsung BSI sensors from 2014, which was exactly my point. There are so many reasons why Canon may choose a 24MP sensor for a FF camera body. You claimed Canon must be having technical issues with their manufacturing when you said they are "so far behind" Samsung from 2014.
I'm really going to need you to explain how there is any difference at all: an earlier BSI sensor not made by Canon with a resolution that implies we should have far more pixels today for anyone who has a level of technical and manufacturing capability that we would expect of them.
It doesn't. There's no evidence in the Samsung 2014 comparison nor the Sony 2010 comparison that in any way indicates the choice of 24MP from Canon has anything to do with technological or manufacturing limitations. It is most likely a matter of cost. And that cost also has to do with getting a fab up and running. Any fab requires investment that has to be recovered by selling its output. So as they get their BSI processes online they need to make sure their yield is high enough to make that line profitable. And once they have improved their processes they may upscale to more pixels, but this is the same exact process for any fab development and the same cost/benefit analysis for any new technology whether its a chip architecture or a manufacturing process (which can be equally challenging to updating the chip architecture itself).
Sure, obviously. At the same time, a 28 MP APS-C BSI CMOS sensor from Samsung upscaled to FF (332mm2 versus 864 mm2) is about 72.9MP. The highest resolution Sony and Canon sensors to date are far below that (Sony max at 61MP) and are very sensitive to diffraction. If diffraction is an issue, then your Samsung comparison also means Canon shouldn't get anywhere near that implied 72.9MP recommendation you made with a 10 foot pole. I
Canon EOS R
Sure they will....but they'll call the 50MP body the R1.
Canon EOS R
Are you saying diffraction is an issue that would cap maximum usable resolution on a full frame camera below 72.9 MP?  If so, I disagree.
And, I didn't make any recommendations with a ten foot pole.
BirdShooter7 Veteran Member • Posts: 9,127
Oh I thought the R1 was going to be 90MP, all these rumors are so confusing
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
Mako2011
MOD Mako2011 Forum Pro • Posts: 28,706
Folks...
...starting to throw away civility
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
