Fuji Raw X Studio Help - Converting to TIFF not working
pjelliottt New Member • Posts: 5
Hello!
I currently have 1600raws on my Fuji GFX50s that I need to convert to TIFF. I've put them into Fuji X Raw Studio to convert them.
Whenever I select all and click Tiff 8-Bit, the software will convert the image that I'm currently selecting to TIFF and the rest just to JPEG.
Is there a way to make sure it changes all the photos to TIFF en masse or does it have to be individual?
Please let me know if you get a second!
JimKasson
MOD JimKasson Forum Pro • Posts: 35,351
Re: Fuji Raw X Studio Help - Converting to TIFF not working
pjelliottt wrote:
Hello!
I don’t use that software, but are you sure you want 8 bit TIFFs, not 16 bit ones? What are you going to do with them?
 JimKasson's gear list:JimKasson's gear list
Nikon Z7 Fujifilm GFX 100 Sony a7R IV Sony a9 II +1 more
SrMi
SrMi Senior Member • Posts: 2,293
pjelliottt wrote:
Hello!
1) Set File Type and other settings in one image, then Conversion -> Copy Conversion Profile.
2) Select all images, Conversion -> Paste Conversion Profile. Now all images should have the same File Type and other settings.
3) Run conversion
SrMi
JimKasson wrote:
pjelliottt wrote:
Hello!
I would assume that all/most processing is already done in Fujifilm X Raw Studio. I would still use 16-bit TIFFs, but I do not convert many images to large 16-bit TIFFs.
BTW and AFAIK, selecting 16-bit TIFF will generate a 16-bit TIFF with only 10-bit usable data (how can I check that?).
JimKasson
SrMi wrote:
JimKasson wrote:
pjelliottt wrote:
Hello!
Is that a quirk of Fuji X Raw Studio? Seems crippling.
Look at the 6 LSBs of a bunch of pixels.
SrMi
JimKasson wrote:
SrMi wrote:
JimKasson wrote:
pjelliottt wrote:
Hello!
It is a limitation of the camera, as TIFFs or JPEGs are generated by the camera.
Thanks. It seems that the 5 LSBs are always zero. That would mean an 11-bit TIFF (GFX100S).
JimKasson
SrMi wrote:
JimKasson wrote:
SrMi wrote:
JimKasson wrote:
pjelliottt wrote:
Hello!
I see. So you're left with restricted DR, but better than an 8-bit JPEG.
11 bit with sRGB tone curve is about the same as 14-bit linear wrt DR, so that's not too bad.
