Is there anyway to repair dead MicroSD card?
MD Mostafizur Rahman
MD Mostafizur Rahman Forum Member • Posts: 58
I had brought Sandisk MicroSD 32GB Extreme Pro version and everything was okay. I didn't use it two months and kept in my moneybag and now this is not working.
Inserted it in my D5200 and it is heating up. It is not showing in my android. Used it on my Windows laptop and wasn't working there either.
Can I do anything to repair?
Nikon D5 Nikon D5200
mclewis Senior Member • Posts: 1,406
Re: Is there anyway to repair dead MicroSD card?
You can't fix them.  Just throw it away and buy a new one.
a_c_skinner Forum Pro • Posts: 11,421
No, nothing.  If you bought it from a reputable source return it and press for a refund.  There are a lot of counterfeit cards around, you may have been scammed.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
mamallama
mamallama Forum Pro • Posts: 60,004
Before you throw it away check that the contacts are clean and free of anything that might obstruct with the contacts.
 mamallama's gear list:mamallama's gear list
Panasonic Lumix DMC-GX85 +1 more
OP MD Mostafizur Rahman Forum Member • Posts: 58
Lost warranty card.
Send it back anyway.  It won't take long to write the letter or cost much to post.  You've little to lose.
Andrew Skinner
Doug J Forum Pro • Posts: 11,342
Here is the warranty table for Sandisk products, your card may have a lifetime warranty.
https://kb.sandisk.com/app/warranty/a_id/22478
I suggest you contact the reseller you purchased the card from and ask about a replacement.
Doug
tkbslc Forum Pro • Posts: 16,658
Given the cost of as cards these days, it isn’t even worth the effort.   32gb card like $10.
mamallama
Depends if anything of value is stored on the card.
Gk1037 New Member • Posts: 8
Hello!
$10?
Adorama has them for $7and $8?
The likelihood of getting an SD card repaired at any price is so low that you’d be just as well off waiting for time travel so you can reshoot the photos.
mamallama
I was just pointing out that the value of a card is not always just the value of a pristine card.
