Walimex pro 14mm NX mount
Started Jul 28, 2021 | Discussions
markyboy81 Veteran Member • Posts: 4,778
Just got hold of this Walimex pro 14mm 3.1 video lens. Very impressed so far. I have got it hooked up to a focus pull motor to control focus but the depth of field is so deep that I might attach the motor to the aperture ring instead.
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Wahid Khan 1961 Regular Member • Posts: 179
Re: Walimex pro 14mm NX mount
Hi Mark, I'm not a video shooter despite the NX1's excellent video credentials. How does this interesting lens perform as a stills lens?
 Wahid Khan 1961's gear list:Wahid Khan 1961's gear list
Samsung NX10 Pentax K-5 Samsung NX1000 Samsung NX20 Samsung NX1100 +32 more
wpstl Senior Member • Posts: 1,251
It's a rebranded Samyang, same as Rokinon/Bower etc. And it's pretty good.
"Sometimes I like to throw a grenade and run away."
 wpstl's gear list:wpstl's gear list
Samsung NX1 Sony a7R II Sony a7R III Samsung NX 85mm F1.4 ED SSA Samsung NX 60mm F2.8 Macro ED OIS SSA +5 more
OP markyboy81 Veteran Member • Posts: 4,778
To be honest I haven't used it much for stills other than a few quick tests. But it seems fairly sharp and the reviews I saw were quite favourable.
I think there's also a stills version of this lens - f2.8 without the gear ring. I think that's the only difference though.
What's odd and annoying about this lens is that the focus and aperture marker is on the bottom side of the lens. Why on earth would they do that?? I thought I had somehow attached the lens upside down at first but it only attaches one way. How strange.
Good to know, funnily I have the Samyang in f2.8 for Pentax with a Samsung adapter. I'm a fan of the lens.
How bizarre.
basyl1891 Regular Member • Posts: 116
I'd try to fix it by carefully unscrew the mount plate, rotate it, and screw it back.
 basyl1891's gear list:basyl1891's gear list
Panasonic Lumix DMC-LX3 Samsung TL500 Olympus E-500 Ricoh GXR S10 24-72mm F2.5-4.4 VC Samsung NX100 +6 more
