Sensor Cleaning - a grump.
Started Jul 26, 2021 | Discussions
petebfrance Contributing Member • Posts: 757
I haven't cleaned the sensor on the K50 for some years, but noticed some really impressive dust bunnies so took the plunge.  Last few times one or two wipes  with the swab was enough, but not this time.
Loads of bunnies, and the first few passes left streaks, bo doubt squashed bunnies, which wouldn't come off so 'wet-cleaning' was done.  After that the streaks were gone, no bunnies, but a little black mark which I thought 'dust removal' would get rid of; I was right, it did, and added two new bunnies!  Unexpected, tried dust removal again, still two bunnies so another swab.
One way or another I got through 6 or 7 swabs.
Moral of the story I guess is don't take macros at small apertures, go for nice shallow depth of field - no wonder the latter is so popular these days.
regards,
Pete
 petebfrance's gear list:petebfrance's gear list
Canon PowerShot SX50 HS Pentax K-50 Pentax smc DA 18-55mm F3.5-5.6 AL WR Pentax smc DA 35mm F2.4 AL +4 more
Pentax K-50
Dericali Regular Member • Posts: 290
Re: Sensor Cleaning - a grump.
Do you have the Ricoh sensor cleaning tool? It works pretty well.
paulkienitz
paulkienitz Veteran Member • Posts: 5,459
Yeah, it's done great for me... but then, I hardly change lenses anymore, if I take a picture it's mostly either with the DA* 300 or with my phone.
"A good photograph is knowing where to stand." -- Ansel
 paulkienitz's gear list:paulkienitz's gear list
Pentax Q Pentax K-3 Pentax smc DA 55-300mm F4.0-5.8 ED Pentax smc DA* 300mm F4.0 ED (IF) SDM Samyang 8mm F3.5 Aspherical IF MC Fisheye +4 more
OP petebfrance Contributing Member • Posts: 757
No, just a set of swabs and come cleaning fluid.  Will look into the Rocih tool.
regards,
Pete
JeremieB Senior Member • Posts: 2,041
When you describe dust getting back on the sensor over and over, it makes me think there might be dust inside the camera and not only on the sensor/mirror. Did you try to blow some dry air inside, mirror up, to get rid of it maybe ?
With my K100D (not Super) sometimes I had the feeling that if there was one particle of dust in a room, it would get attracted to the sensor, like a black hole Cleaning it was boring.
 JeremieB's gear list:JeremieB's gear list
Pentax K-70 Pentax K-3 Mark III Pentax smc FA 50mm F1.4 Pentax smc DA 18-55mm F3.5-5.6 AL Pentax smc D-FA 100mm F2.8 Macro WR +9 more
You need a premium air blower, not a cheap knock off, from Giottos, such as the '
'Giottos GTAA1900 Super Rocket-Air Blower Black'.
Use the blower first and then the Ricoh cleaning tool.
Normally when I take my camera to a professional cleaning service via a dealer, whichever the brand, they are using the Ricoh tool.
Yes, my impression is that there's dust sitting in there.  I have done the usual 'blowing out of dust with a Giotto rocket air blower, but suspect that there's more in there.  Actually, after my rant I reviewed my picture of the 'clean' sensor again and found another tiny spot (in a different position) which came off with the dust removal function.  So yes, it's in there....
regards,
Pete
PDL Regular Member • Posts: 457
You might try a electro static eliminator before you use the blower (with a valve). I kept my very old Realistic DISCOTRON® from my vinyl record playing days.
It shoots Positive and Negative ions when squeezed. The ions remove any static charges from surfaces and dust particles. Then the blower can simply remove them. Be sure to hold the camera body facing down because - well gravity is your friend.
And before anyone gets all bent. No, the use of static eliminators will not damage the sensor in any way, shape or form. However, today static eliminators are pretty pricey, since their demand has dropped off the cliff.
PDL
Ian Stuart Forsyth
Ian Stuart Forsyth Veteran Member • Posts: 4,095
What I would recommend prior to cleaning your sensor is find 2 fan brushes, label one as sensor brush. Go about blowing out your mirror box and then charge your other brush by blowing air over it with a bulb. Wipe out all of your mirror box including your mirror including the sides top and bottom cleaning your brush several time by blowing over it.
When you have it clean while the mirror is up then go about cleaning everything under the mirror again blowing out the brush several times.
When you are done blow out the sensor and when you think you are clean enough start to use the sensor brush, charge it by blowing on it and then in a sweeping motion take 1 sweep and then clean the brush do this until you think you are clean.
A lot of times you will still have a blob that will stick to the sensor and for this I spot clean the blob with
https://lenspen.com/product/sensorklear-ii/
I would look at getting the kit with a loop makes it very easy to clean a sensor in half the time and half the problems.
If there is grease on the sensor is about the only time now that I would use a wet swab and  even then to remove any of the streaks left I use the pen to clean it up.
The Camera is only a tool, photography is deciding how to use it.
The hardest part about capturing wildlife is not the photographing portion; it’s getting them to sign a model release
 Ian Stuart Forsyth's gear list:Ian Stuart Forsyth's gear list
Nikon PC-E Nikkor 45mm f/2.8D ED Pentax *ist DS Pentax K10D Pentax K20D Pentax K-7 +27 more
That's an interesting idea - I do have one of those somewhere or other so it may be worth searching it out.  Thanks!
regards,
Pete
Thank-you.  I'll think about this one (I do have some fan brushes, never thought of using them for this purpose though.)
regards,
Pete
grcolts Veteran Member • Posts: 3,911
Out of all the cameras I have used over the years the K50 was the worst for dust on the sensor. No matter how cautious I am dust always gets onto it. The best thing I have found is what others have already mentioned is the Ricoh dust removal tool. I love my K50 but hate the dust it collects.
johnami
johnami Senior Member • Posts: 1,330
Any type of digital camera can have dust spots.
It's better to have a box where you have access to the sensor.....otherwise expect to pay the price.
One reason I didn't buy the Ricoh GR3...
 johnami's gear list:johnami's gear list
Sigma DP2 Pentax K10D Pentax K-5 Fujifilm X-T2 Olympus E-M1 III +19 more
Ian Stuart Forsyth
Like  I said using a wet wipe is the very last thing I do when I am out of options.
For the 4 cameras that I run I have not wet wipe one of them is 5 years
That was my first ever 'wet clean.' I suspect, but can't prove, that it would have been unnecessary if I hadn't neglected taking care of the thing since its aperture block failure (but continued to use it in a rather grudging manner with manual lenses) - hence, less precautions, less use of the 'rocket air cleaner' and so on.
I think it definately needs more through cleaning inside the mirror box (as per your method) than it was getting - the dust from the sensor shake mechanism has to go somewhere and evidently my efforts had not been getting rid of it.
regards,
Pete
