WongRQ
Contributing Member
Any caveats to this tripod hack?
Jul 26, 2021
Hi everyone,
This tripod hack might've been discovered by someone else before, but I just discovered that you can get extreme-low angle shots while on a SIRUI Traveler 7A tripod, that has an inverted center column and a 1/4" -20 threaded screw accessory port.
The problem with the inverted center column is unless you buy an adapter or use an articulating arm, you're going to have to find a way to have your pictures at normal rotation. Some cameras might be able to do this, but I'm not aware of any.
I am using this trick with a the ball head that came with the SIRUI Traveler 7A, the SIRUI E-10 Ball Head. Other heads that are larger/have varying designs may not work with this trick.
1. Remove the ball head
2. Remove the disc and the screw.
On one end there's a 3/8" -16 male screw thread and on the other there's a 1/4" -20 male screw thread. A versatile tripod indeed.
3. Take the end with the 1/4" -20 Male screw and screw it into the 1/4" -20 femake screw thread accessory port.
4. Tighten by holding the 3/8" -16 Male Thread end and screwing it in, then holding the disc and tightening it further. The disc will be able to move a tiny bit as it's a bit loose and if you look inside, you'd see why. Not a concern so long as it's screwed tight.
5. Attach the ball head
6. Put the ball head in a vertical position so that the camera will face upwards instead of facing down. Then turn the panoramic base to level.
Any caveats to this?
Canon EOS 7D
Canon EOS 600D
Canon EF-S 18-135mm F3.5-5.6 IS
Sigma 150-600mm F5-6.3 | C
