Minolta XD-5 - (Unable to advance)
Started Jul 26, 2021 | Questions
Rocket-Man New Member • Posts: 1
Hello,
My late dad purchased this Minolta when it first came out. Unfortunately it broke in my possession.  I have all the horns and whistles, but they do me no good, if the camera is not functioning. The advance film switch is jammed. I changed the batteries.  Took it to the largest Camera shop in Buffalo, NY, but they say they're not fixing these cameras.  When I move the self timer lever and picture snaps, I then get the the switch to advance.
Can this be fixed? Any suggestions would be appreciated.
FrancoD Forum Pro • Posts: 19,261
Re: Minolta XD-5 - (Unable to advance)
Michael Fritzen Veteran Member • Posts: 6,741
Hi,
from your description of the issue I'm not sure whether the problem is electronics (and thus possibly the capacitor issue FrancoD addressed) or more on the mechanical side.
Owning once the XE-5 and later also the XG-M I remember that the film advance lever was linked to several components like a dented film advance / guide just right beside the shutter (if you open the cam's back), of course the cocking of the shutter ifself and also the small rewind release button on the cam's bottom side.
Perhaps one of the mechanically driven components got somehow stuck - what you feel at the advance lever. If you open the cam's back, do you see the shutter curtain rise as you move the film advance lever? Same for the film advance/guide on the right? Do you notice any jam?
If I remember correctly in those times it was recommended to operate once in a while the shutter / film lever / cock the shutter / release it to avoid mechanical issues reletaed to longer periods of non usage. Perhaps your cam stayed unused too long. But perhaps gently moving gets it back into working order.
BTW my XE-5, while mechanically robust like several models of that times, was doomed twice by an internally broken on-off switch.
Michael Fritzen
mcsk Regular Member • Posts: 126
Is the advance lever stuck after the shutter fires, or is the shutter not operating in the first place? Does setting the shutter speed to one of the purely mechanical settings (O or B) change anything?
