jalywol
Re: Are these photos have any potential?
I understand what you are trying to do with these images. The maidenhair fern leaf you are shooting is a very appealing shape with nice detail. However, you have picked a difficult subject to photograph in this habitat, as the lighting on the leaf is not much brighter than the background, and it is a long object to try and capture in focus close up if you are looking from front to back rather than top down on the whole frond.
You can adjust some of this in post-processing (see below), but I would suggest trying some other exercises next time you go out:
One of the hardest things to learn in photography is how to not just see the subject you are interested in when you are composing the image, but instead, to see the background as well, and adjust your shooting parameters to optimize both. So, next time you go out and are struck by a wonderful leaf or flower or other such subject, take the time to not just shoot the subject, but adjust your exposure, focus, etc, so that what you are seeing in the viewfinder emphasizes the subject and uses the background as a "cooperative backdrop" rather than a competitive visual field to your target subject
Here's your image with the frond brightness adjusted separately from the background, and the background darkened a bit to keep focus on the subject instead.
Here's an example of the same type of technique that was achieved in camera, not in PP:
Exposure and where the subject was located in its particular spot in my yard allowed the dark background with the lighter flowers without having to adjust anything afterwards.
Another thing you can try to do, if you don't want this type of darker contrast, is to position your camera so that your subject is framed and emphasized by the background foliage:
Not a flower, but the pattern on the butterfly was complemented by the leaf pattern in the background.
Again, a bird, not a plant subject, but the same things apply here: The tree leaves in back of the bird form an arc over its head, so they draw your eye to the bird rather than compete with it.
You may want to consider buying some photographic technique books about composition, as the basics are good to have reference to when you need them.
Keep up the good work!
-J
