problem with flash setting on Canon 7D mk2
Adyaacov New Member • Posts: 19
Greetings everyone
I have been using my Canon 7D2 with multiple off camera flashes (Canon and Godox) triggered by the Godox X-pro. Recently my camera took a fall and was totaled so I got a replacement body.
On the new body when I use the flashes in ETTL and the camera is on manual mode, when I try to change the aperture I get the message "Low" and the camera goes back to F4 (which is the lowest F stop of the lens). On my old body on manual mode I could change both shutter speed (up to 250) and aperture freely. Other than the body I have made no changes.
I am guessing (hoping) that this is just a setting issue. Does anyone know how to fix it?
Other than that the new body seems to be working well.
Cheers
A
Canon EOS 7D
tugwilson Veteran Member • Posts: 3,447
Re: problem with flash setting on Canon 7D mk2
You could try to do a system reset. Instructions here.
OP Adyaacov New Member • Posts: 19
Editing
Turns out the problem is with manual mode in general. Regardless of the flash.
Would still appreciate any help.
A
ScratchDisk Veteran Member • Posts: 3,788
Hi, Beyond a Camera reset, as above, I'd add a flash reset as well.
Battery door open, turn 'on', fully press 'pilot', turn 'off' . .
Also, re-attach speedlite with both body & flash off, turn flash on first . .
(re-clean all 12 contact surfaces (5 + rail) X 2)
 ScratchDisk's gear list:ScratchDisk's gear list
Canon EOS 5D Mark III Canon EOS M5 Canon EOS 90D
Solved
Was just the shift lock LOL.
Thank you all
