K-1?
TomWret
TomWret Veteran Member • Posts: 4,303
K-1?
I currently have the Pentax 50-135mm lens and the K-1. My question is: if I were to sell it for the 55-300mm PLM would I loose or gain something in terms of reach? Back when I had my K-3ll and the PLM I was impressed with its fast-lock in on focus.
Tom W
 TomWret's gear list:TomWret's gear list
Pentax K-1 HD Pentax D FA 24-70mm F2.8 ED SDM WR Epson Stylus Photo R3000 +6 more
Pentax K-1
ozdean
ozdean Forum Pro • Posts: 27,284
Re: K-1?
Tom if you put your K1 in crop mode you will gain a lot of reach with the plm.
Regards Dean - Capturing Creation
N.B. All my Images are Protected by Copyright
 ozdean's gear list:ozdean's gear list
Pentax MX-1 Pentax K-5 IIs Pentax K-3 Mark III Pentax smc DA* 55mm F1.4 SDM Pentax smc DA 15mm F4 ED AL Limited +13 more
TomWret
OP TomWret Veteran Member • Posts: 4,303
Re: K-1?
THANK YOU Dean I'll Mark as answered.
Tom W
M R Padmaraju Veteran Member • Posts: 5,968
Re: K-1?
55-300 PLM can be used nearer to 300 in Square crop , which is better than the APSC in Pixel count !
Regards ,
mrp .
 M R Padmaraju's gear list:M R Padmaraju's gear list
Fujifilm FinePix F40fd Pentax K-x Pentax K-01 Pentax K-500 Pentax K-S1 +8 more
James O'Neill Veteran Member • Posts: 5,746
Re: K-1?
I'm assuming it needs to be in crop mode for the whole range ? So it will be like an 80-450.  If works OK in FF mode for some or all of the range then there are other options.
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-5 IIs Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 18-250mm F3.5-6.3 Pentax smc FA 43mm F1.9 Limited +3 more
TomWret
Re: K-1?
Thanks, mrp.
Tom W
TomWret
Re: K-1?
Thanks James.
Tom W
