Samsung lens MTF chart
Started Jul 19, 2021 | Discussions
kev-xkq New Member • Posts: 12
almost every lens manufacture publishes their lens MTF chart. but l failed to find MTF chart published by Samsung officially.
now l only get the MTF chart to the lens below:
16-50s
50-150s
50-200
30
45
10
20-50
18-55
l'm looking forward to get the MTF chart to the rest of Samsung lens.
especially:18-200 and 16-50pz
Thanks!
 kev-xkq's gear list:kev-xkq's gear list
Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 10mm F3.5 Fisheye Samsung 16-50mm F3.5-5.6 power zoom
shutterbugnx
shutterbugnx Regular Member • Posts: 168
Re: Samsung lens MTF chart
16-50mm PZ
18-200mm
Here are the ones you specifically mentioned. Let me know if you'd like any others.
 shutterbugnx's gear list:shutterbugnx's gear list
Panasonic Lumix DMC-ZS60 Olympus PEN E-PM1 Sony Alpha NEX-7 Samsung NX2000 Fujifilm X-M1 +46 more
OP kev-xkq New Member • Posts: 12
Where did you find them? Can you give me the website?
shutterbugnx wrote:
16-50mm PZ
18-200mm
according to the MTF chart, 18-200 seems to have good image quality (at least not bad) among this kind of lens. But the result among people who use it is rather poor. What makes this difference?
shutterbugnx
They used to be on Samsung's website. I also owned a lens catalogue published by Samsung.
There are many factors. Superzooms tend to have significant copy-to-copy variation for one. Also MTF charts provided by manufacturers are generally at infinity focus, so don't tell you how the lens will perform at close distance. And relying on OIS can easily yield poor results.
sorry to bother you again. but I want to get the lens diagram and MTF chart for NX85mm 1.4. l have some urgent uses. l would very appreciated it if you can send it to me.
shutterbugnx
85mm
Here you go.
Siralgovia Regular Member • Posts: 157
shutterbugnx wrote:
16-50mm PZ
18-200mm
I love my 18-200 on my Galaxy NX. It's heavy, but at 18mm I find its IQ highly enjoyable. Corners are softer, but the lens has its own unique rendering.
As you zoom in, edges get kind of crazy but my copy has very good center sharpness (non pixel peeped) throughout the range. At 200 it almost looks like you're shooting through a blurry tunnel but center sharpness is still good enough.
OIS is very good, I was surprised.
Technically, pixel peeped, I'm sure there is plenty wrong with this lens, especially with the edges. But from a uniqueness-in-rendering point, this lens scores high for me. I was sceptical when I bought it, I already had the 50-200, which is technically the better lens. But I fell in love with the 18-200, I very much enjoy its output. I'm not sure how it does on an NX1 as the 28 MP sensor probably outresolves this lens, but my Galaxy NX and this lens makes for a very enjoyable combo.
I also own a Panasonic G9 with the 14-140ii lens. While that lens is classes above the 18-200 in edge sharpness, I find myself grabbing my Samsung setup more frequently, but only on sunny days. Looking at the pictures at home I get less keepers but also more select 'wow' factor images.
markyboy81 Veteran Member • Posts: 4,778
shutterbugnx wrote:
16-50mm PZ
18-200mm
I'm also a fan of the 18-200mm. You're right it's probably not as good technically as the 50-200mm but it has some real advantages. The most obvious is that it starts at 18mm but also the autofocus system is better and quieter (good for video) and the OIS seems better.
It's the only lens in the system that truly makes the camera a 'bridge' camera. I use it occasionally with my NX1 and I'm happy with the results. In fact I'm on the look out for another copy - mine came without the hood (which is impossible to find separately), the front element has some marks and the lock switch is broken!
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Yes, mine came without the hood as well. But it hasn't bothered me. I just shield the sun with my hand if it comes in from the side. I've never been a fan of those hoods, even though they serve their purpose.
Forgot to say that the build quality ov the 18-200 is substantial. Very solid lens.
