Focus mode on a7iii switches to manusl
Isabel Cutler
Isabel Cutler Forum Pro • Posts: 18,591
Set up for eye at in caf with wide area.   was working for a while then suddenly it wasnt and I got a popup that it was in manual mode and I couldn't change it out of manual.
Am at an event and I need the rye af.  Help!isabel
isabek
"If you're not prepared to be wrong you'll never come up with anything original" Sir Ken Robinson
http://www.pBase.com/isabel95
https://www.flickr.com/photos/isabel95/
 Isabel Cutler's gear list:Isabel Cutler's gear list
Sony RX10 IV Canon EOS 7D Olympus PEN E-PL5 Panasonic Lumix DMC-GX7 Olympus OM-D E-M10 II +2 more
Sony a7
Isabel Cutler
OP Isabel Cutler Forum Pro • Posts: 18,591
Re: using Tamron 70-180 (nt)
Paul Barnard
Paul Barnard Veteran Member • Posts: 3,784
Re: Focus mode on a7iii switches to manusl
I hope you already fixed it but if not two things to check/do.
1.  Make sure the lens MF switch isn’t turned on if it has one.  I’ve been there before…
2. take the lens off and clean the contacts on both the lens and the body.
 Paul Barnard's gear list:Paul Barnard's gear list
Sony a7R III Sony FE 55mm F1.8 Sony FE 70-200 F4 Zeiss Batis 25mm F2 Sony 1.4x Teleconverter (2016) +5 more
Isabel Cutler
Re: Thank You!
As you can tell by my typos on the hastily written phone post, I was pretty freaked out.
I turned off Eye AF and focused on my subjects by moving the camera around so that the wide focus mode chose the intended subject.  Not ideal, but it generally worked.
I went through the menu and could find no way to get rid of manual focus since the focus choice was grayed out.  The Tamron lens has no af/mf switch.
When I got home I search the web for a solution and found that I could assigned af/mf switching to a custom button and did so.  Hope that will work and I will continue to test it.
I had thought about removing and reattaching the lens but never did do that.
All in all I was very happy with the Tamron and the focal range was very suited to the venue.  Here's an attendee listening to a candidate at a Meet and Greet event.  Lighting was a mix of artificial and window.
Isabel
Isabel
Paul Barnard
Re: Thank You!
Isabel
Isabel
I certainly heard the tension in your typing 😀
great that you found a solution to keep you going and with great results
give the contacts a wipe just in case.
Isabel Cutler
Re: Thank You!
I certainly will!  Thanks.
Isabel
