Light setup for hike X-E4 with 14 2.8 or 16 2.8?
Started Jul 15, 2021 | Discussions
christ0f Forum Member • Posts: 72
Hello!
I wish to complete a very light setup for long hikes and wish to take only two lenses - one for wide angle - like 14 or 16 and some short tele - like 50. (maybe eve 18-55 not yet decided)
My question is about the field of view - I read here in threads that 16 2.8 offers similar FOV as the wider 14 - is that correct? Could anybody post the samples showing it. I'm really more into the 21mm equivalent that 24mm. Also I saw a lot of admirations about the rendering of the "old" 14 - is it that better that 16? Btw: I'm discarding the 16 1.4 - too bulky, no need for 1.4 light.
Thanks!
DocetLector Contributing Member • Posts: 934
Re: Light setup for hike X-E4 with 14 2.8 or 16 2.8?
What about the 15-45? I use it if I want to go really light. Not so good at the long end
but very good from 15-30mm. But you have to get used to the power zoom.
The 14mm is still one of the best Fuji lenses. very sharp and completly corrected.
 DocetLector's gear list:DocetLector's gear list
Canon G1 X II Canon EOS M6 Canon EOS M6 II Canon EF-M 18-55mm f/3.5-5.6 IS STM Canon EF-M 22mm f/2 STM +5 more
Gringostarr Regular Member • Posts: 481
The 16/2.6 has soft corners that never fully clean up due to how much correction it needs. The 14/2.8 is fully corrected and is a fantastic lens for hiking and will be what I’ll pair the 60/2.4 with for my lightweight hiking kit, substituting the 60 for the 70-300 when I want extra reach.
Also, a lowepro dashpoint 30 works flawlessly with either of those lenses and the X-E4 attached to the shoulder strap of a dedicated hiking pack. I use an Osprey Stratos 24 for my day pack and a Gregory Optic 58 for my multi-day pack and love that setup.
 Gringostarr's gear list:Gringostarr's gear list
Fujifilm X-E4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 27mm F2.8 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 30mm F2.8 R LM WR +1 more
biza43 Forum Pro • Posts: 15,074
The Fuji 14 is a really excellent landscape lens. Those 2 mm make a good difference. I have used both lenses, and prefer the 14mm one: better distortion correction for example, which is important to me (lots of seascapes). The AF > MF clutch is also useful.
Some 14mm examples.
www.paulobizarro.com
http://blog.paulobizarro.com/
 biza43's gear list:biza43's gear list
Fujifilm X-T3 Fujifilm X-T4 Fujifilm XF 16mm F1.4 R WR Fujifilm XF 70-300 F4-5.6 R LM OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
(unknown member) Forum Pro • Posts: 12,354
I've no idea why people take primes when hiking, and I've done more than my fair share. In my experience you can't beat a standard zoom if you're travelling light, no need to change lenses and wide to normal telephoto are covered. The other obsession seems to be wider than usual with fast apertures, again, I have no idea why, if you're at any kind of altitude telephoto is far more useful for interesting shots. Wide angle shots with no foreground interest are just so bland and uninteresting and make anything of actual interest smaller and more distant, each to their own I guess, but I just don't get it.
My kit before swapping to using the X-E4 and 2 primes (or one prime and a true telephoto zoom) was the X-T30 & 16-80 before it was stolen and to be honest I was never truly happy with. My issues with my original kit was that it was much bigger and so would either hang off my shoulder strap totally exposed when I used a capture clip or I had to stick it in a non-easily accessible compartment of my bag. Plus the capture clip dug into my chest on hikes lasting longer than about an hour which for me was pretty much every hike. I also found that I mostly used the 16-80 at either 16mm or in the 60-70mm range while never wanting to use anything in between and also wishing I had a macro lens on me to take close-ups of plant life and critters while on trail.
Now my setup keeps my gear much more protected from dust (what I really wanted to protect it from) and as easily accessible as using the capture clip while being much more comfortable to carry. Plus most hikes are out and backs so I typically have one lens mounted while on the way to the destination and one lens mounted on the way back.
See my recent trip to Lassen National Park using the 14/2.8 and 60/.24 on the hike to Widow Lake, and 14/2.8 & 70-300 on the hike up Cinder Cone for an example of why I'm fine hiking with either those two primes or the ultra wide and a true telephoto.
https://www.dpreview.com/forums/thread/4587275?page=3#forum-post-65318532
As I said, whatever works for you, the 70-300mm seems like a big lens for such a trip, personally I'd go for the XC 55-230mm. The combination of that and the 18-55mm would seem like the ideal combination for me personally. However, you know how you prefer to shoot and what you're prepared to carry.
jhorse Veteran Member • Posts: 5,913
With experience of both the 14/f2.8 and 16/f2.8, the latter is no slouch and performs fine, especially stopped from f4. I do agree, however, that the 14 delivers excellent IQ.
I use the 16/f2.8, 23/f2 and 50/f2 with my XE4 as a light weight hiking kit when I go solo and can focus more on photography. If I am with the family or friends, when photography plays second fiddle, then I use a 18-55 instead.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
OP christ0f Forum Member • Posts: 72
It could be weird indeed to sacrifice the freedom of having a zoom, but actually it works for me quite opposite. When I'm limited with a given focal I'm working a lot to get a shoot that I'm happy with. With the zoom I often end up with rotating the ring back and forth. Second thing is quite a low profile and weight - it also counts.
I know that 16-80 could be the option, I really hoped it is a quality lens, but after having Canon 24-105L and seeing the samples from it I really can not stand it, the drop of quality is higher as expected.
After the responses in the thread I'm really now thinking about the combo of 14 with 60 2.4.
Thanks for replies!
sir_c Contributing Member • Posts: 740
The 14/2.8 has an angle of view of 89 degrees, whereas the 16 sits around 83 degrees.
That difference is quite noticeable, and furthermore the XF 14 is a really sharp lens that is fully optically corrected. It is an UWA lens, but its perspective is still nice.
 sir_c's gear list:sir_c's gear list
Fujifilm X-T1 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R Fujifilm XF 18-55mm F2.8-4 R LM OIS +5 more
Thanks for replies!
I've also owned the the 24-105L, and I'm more than happy with the 16-80mm in comparison, internet samples don't tell you anything useful about a lens IMHO, you have to try them yourself. I've read so much nonsense about this lens it's difficult to know where to start.
