Issue with exposure pulsing/blooming when recording video
Started Jul 15, 2021 | Discussions
markyboy81 Veteran Member • Posts: 4,778
I've read about other NX1 users experiencing issues where the exposure changes whilst recording video, even in manual mode when all settings are constant.
I have experienced similar issues but not in manual mode - it's where I have it in shutter priority and the aperture automatically changes, which seems to result in a sort of pulsing and change in exposure. I think this may be more apparent when using an older lens, as it doesn't seem to happen as much with the S lenses.
Has anyone else experienced this?
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
Samsung NX1
Roman Proydakov
Roman Proydakov Junior Member • Posts: 25
Re: Issue with exposure pulsing/blooming when recording video
I have had experience with this exposure problem. After reviewing many forums on this issue, I decided for myself that it's all about the latest firmware 1.41. This firmware solves problems with communication with mobile devices, but the exposure jumps. If you go back to 1.40, the exposure problem should go away, but there will be problems with wireless communication with devices.
www.instagram.com/roman.proydakov_photo/
 Roman Proydakov's gear list:Roman Proydakov's gear list
Samsung NX1 Samsung NX 85mm F1.4 ED SSA Samsung NX 45mm F1.8 Samsung 16-50mm F2.0-2.8 Samsung 50-150mm F2.8 S
Bixbe Junior Member • Posts: 49
I have several NX1 since 2015 and I use mostly the S lenses in P mode. The exposure corrects itself mostly in a second but I never have any problem with exposure stepping.
 Bixbe's gear list:Bixbe's gear list
Panasonic LX100 Samsung NX1 Samsung 16-50mm F2.0-2.8
OP markyboy81 Veteran Member • Posts: 4,778
To be honest the new NX1 I have won't connect with my phone anyway.
How do you revert back to 1.40? I thought you could only updgrade?
Roman Proydakov
There are no problems with downgrade to the older version of firmware using an SD card.
Roman Proydakov
Here is a EOSHD forum thread about this NX1 issue from 2015:
https://www.eoshd.com/comments/topic/7770-nx1-exposure-drift-problem-fix/page/10/
StenM Regular Member • Posts: 201
I don't suppose you have a link to the 1.40 firmware file?
Roman Proydakov
Thanks so much, I've sent a message to request access to it.
That wayback machine is fantastic! Already retrieved firmware to update some lenses!
mokara Regular Member • Posts: 139
If you are using one of the priority modes then the camera is likely at an aperture threshold and opening/closing the aperture in response to small scene changes. That would create the pulsing effect since stuff like ISO and aperture change in steps, not smoothly.
 mokara's gear list:mokara's gear list
Canon EOS R5 C
http://downloadcenter.samsung.com/content/FM/201508/20150821161049567/NX1_FW_v1.40_sec.zip
