Suggestions for a good street photography setup?
Started Jul 14, 2021 | Discussions
ange_photo New Member • Posts: 2
I have a D7500 which is just too annoying to carry around with me when I'm on trips and it's hard to keep a low profile while shooting with a black DSLR in the streets.
I'd like a camera that isn't too big (I am a big guy so I don't mind a slightly bigger camera), that's well built, with decent image quality and dynamic range, possibly with weather sealing, with decent battery life, decent EVF and interchangeable lenses.
That's why I started looking at the m4/3 ecosystem. I like that there are many available lenses around and I like the fact that m4/3 cameras tend to be small and cute.
My budget is about €1000 for a camera and a lens. What do you suggest?
For the lens, I thought about getting the Panasonic 20mm f1.7 asph. mark II which goes for about €300, and this would leave €700 for the camera.
Thanks.
Nikon D7500 Panasonic 20mm F1.7 II
yardcoyote Forum Pro • Posts: 15,754
Re: Suggestions for a good street photography setup?
If you like the field of view, the Panasonic 20mm is a nifty little street/ walkaround lens. I have the original version, which is not particularly fast focusing. This is fine with me, but I think the current version is supposed to be better in this area.  It's optically excellent and pleases me with its good close focus capabilities particularly for a pancake lens.
I have mine on an Olympus EM-10 mk2, which is a very capable and very small camera.  It's an older model and would be well within your budget.
Instagram: @yardcoyote
 yardcoyote's gear list:yardcoyote's gear list
Fujifilm X10 Fujifilm X100T Fujifilm X-Pro1 Pentax K-5 IIs Fujifilm X-M1 +20 more
bs1946
bs1946 Veteran Member • Posts: 7,780
The 20mm f1.7 takes beautiful images plus V1 & V2 share the same optics., so you can even go for the cheaper V1. But, the 20mm is also well noted for its slow and noisy autofocus, two attributes you don't want in a street lens.
The Olympus 12mm f2 coupled with the Panasonic GX9 make a perfect street shooting pair, nobody will pay much attention to you and if you learn to shoot while holding the camera against your gut, all the better. Plus the 12mm has the AF/MF snapback clutch which allows you to switch to MF and use zone focusing.
Bill S.
www.flickr.com/photos/wrs1946
“Gear Doesn’t Matter”
- Mattias Burling (Swedish Photographer & Videographer) -
 bs1946's gear list:bs1946's gear list
Panasonic Lumix DC-GX9 Panasonic 20mm F1.7 II Panasonic Lumix G 14mm F2.5 II ASPH Panasonic 12-60mm F3.5-5.6 OIS Apple iPhone 12 Pro Max
OP ange_photo New Member • Posts: 2
Thanks, I'll check it out.
Regarding your version of the 20mm, do you find the time it takes to focus particularly annoying? Is the mark ii worth it?
ahaslett
ahaslett Forum Pro • Posts: 12,662
Here in the U.K., I’d buy used from a reputable dealer.  I’d also get a 20Mpix body with decent IBIS.
The 20/1.7 is a bit slow and noisy, so not suitable for video.  Unless you shoot action, it should be fast enough.  You can’t hear the noise unless you are close.
Given you don’t want the smallest camera, I’d go for an EM1.2.
If you want a rangefinder style smaller body, the the GX9 with kit 12-32mm and 20/1.7.
Excellent IBIS is the great strength of the EM1.2, along with a lot of stills functionality.
Andrew
Infinite are the arguments of mages. Truth is a jewel with many facets. Ursula K LeGuin
Please feel free to edit any images that I post
 ahaslett's gear list:ahaslett's gear list
Sigma DP1 Merrill Sigma DP3 Merrill Olympus E-M1 Sony a7R Panasonic Lumix DMC-GM1 +33 more
dwkdnvr Regular Member • Posts: 264
5
I think a GX80/GX85 + Panny/Leica 15mm/1.7 is a great combo, and kinda/sorta can be an M43 alternative to a fixed lens street camera like the X100 series (different ergonomics, obviously)
nurseMarty Regular Member • Posts: 326
This was my initial reaction too.
The GX85 in the US can be had for,~£175 used. Don’t know about the UK. The body is lite and small. Love the IBIS. The images have very nice colors.  The L monochrome B&W film simulation is also very nice.
The 15mm lens is almost built for this body and purpose. It almost has the same POV as the 20mm les. It is a very nice bit of kit and one I use. I can recommend this combination from personal use.
Mask on Nurse Marty
pdelux Senior Member • Posts: 1,113
20mm did annoy me with its focus time.
Plus I didnt really like 20mm fOV and the pancake has some distortion on the edges, but its a good lense and many others like them.
I would prefer any of the other 17ish lenses which are faster to focus. Though not as small but still small.
 pdelux's gear list:pdelux's gear list
Olympus OM-D E-M5 Olympus PEN-F Olympus Zuiko Digital ED 9-18mm 1:4.0-5.6 Panasonic Lumix G 20mm F1.7 ASPH Olympus M.Zuiko Digital 45mm F1.8 +6 more
janeenadamsmartin
janeenadamsmartin Senior Member • Posts: 1,119
I ended up using my Ricoh GRII rather than my EM1.3
I thought about the same thing, for riding with my new bike, but instead, I dug out my Ricoh GRII, which I never completely got the hang of, and now I love it!
It forces me to take photos a different way -- mainly a street photo style -- and the output is tremedous.  It truly does fit in a pocket and is so unobstrusive.  With snap focus it isn't even obvious you are taking a photo.
I already had mine, and they aren't inexpensive, but so glad I made the effort instead of adapting my EM1.3 for that job.
jan
 janeenadamsmartin's gear list:janeenadamsmartin's gear list
Olympus M.Zuiko Digital 45mm F1.8 Olympus M.Zuiko Digital ED 75mm F1.8 Olympus 12-40mm F2.8 Pro Panasonic Lumix DMC-FZ200 Panasonic Lumix DMC-FZ300 +16 more
pannumon Veteran Member • Posts: 4,130
20mm f/1.7 seems to AF better on Panasonic bodies. Distortion is automatically corrected, except perhaps on some older Olympus bodies.
Panasonic 20mm f/1.7, Panasonic Leica 15mm f/1.7, Olympus 17mm f/1.8, Sigma 19mm f/2.8 are all good options, 20mm f/1.7 being my first choice. I would probably add a Panasonic 12-32mm pancake or 12-60mm (non-Leica) or maybe Olympus 14-42mm EZ pancake. This would mean a 400€-600€ budget for the camera, meaning something like Panasonic GX80, Panasonic G80, Panasonic G90(?), Olympus E-M5 mk II, Olympus E-M10 mk III/IV. I would first look at G80 and E-M5 mk II that are a bit older upper mid-range models.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
Mr Giggles Contributing Member • Posts: 950
Re: I ended up using my Ricoh GRII rather than my EM1.3
jan
I agree with this
the Riccoh GHii is absolutely outstanding street camera
I used it in central America and the snap focus will be a god send for you
larsbc Forum Pro • Posts: 18,282
How do you shoot street?
Thanks.
Do you prefer to shoot from the chest or waist? Do you find a scene and wait for people to enter or do you need to be able to catch sudden opportunities?
I've been shooting a LOT of street since the pandemic started. I frequently shoot from the chest and I need to be able to capture unexpected opportunities that suddenly appear. While m43 AF is quite fast, when you factor in the time required to specify your focus area, it's still not fast enough for my kind of street shooting. After shooting with the 20/1.7, 15/1.7 and 25/1.4, I've actually found that my most reliable lens has been an inexpensive Laowa 17/1.8 manual focus. I use it in zone focusing mode. The distance markings aren't accurate so I have taped my own markings onto the lens barrel for 1, 2 and 3 metres. An Olympus lens with the sliding MF focus collar might also work well but I can't say one way or another since I've never used one.
While I got some good results with the 20, I found that its FoV was a bit too tight. My framing is usually sloppy so I prefer to have more in the frame and don't worry too much about the final image quality. The composition is much more important to me than fine focus and image detail.
For framing, I prefer a single-axis rear screen. It's less bulky, inconspicuous, and faster to deploy.
My camera needs to have a fast on/off time since I never know when an opportunity will present itself.
I also require a Minimum Shutter Speed setting. For me this is important because I often photograph while I'm literally walking and the subject might also be walking towards me. 1/400s is my minimum shutter speed.
As much as I like stabilization, it hasn't been necessary for my street work because I usually need a fast shutter speed anyway.
My m43 camera of choice for that kind of street photography is a GX9 with the aforementioned Laowa 17/1.8. It has the features I need (fast on/off, silent shutter, single axis rear screen, min. shutter speed) plus 20mp which gives me some decent latitude for cropping.
I'm not annoyed by it at all, but then I work primarily with static or highly predictable subjects so AF speed is not a high priority for me in general. I think It's faster than some of my Fuji lens/ camera pairings as it is.
I chose my first version (used) over a new version 2 because the two are optically identical, and a lot of people around the world are still using the first version happily. It even seems to be considered a bit of a classic. So since the whole thing was an experiment for me anyway, I decided to save the money. I was not expecting to like the lens nearly as much as I do.
I don't know if the 20/1.7 II is any better than the first version in terms of AF speed/noise.  I thought it was a cosmetic update?
Harold66
Harold66 Forum Pro • Posts: 12,002
This is complete BS. at least for stills. Nobody will hear the AF noise in a street configuration
This is obviously hearsay and not firsthand experience
g.
Harold
FOLLOW me on IG @ledaylightstudio.
thedemandingtraveler.org
www.haroldglit.com
IG :thedemandingtraveler
 Harold66's gear list:Harold66's gear list
Sigma DP2 Merrill Ricoh GR II Panasonic Lumix DC-G9 Fujifilm GFX 50S II Panasonic 20mm F1.7 II +5 more
Isola Verde
Isola Verde Forum Pro • Posts: 10,640
Thanks.
A rarely-mentioned drawback of the 20mm f/1.7 is that it focuses by moving a group of lens elements (and inbuilt filter thread) in and out - so it's not advisable to press the lens against glass surfaces (the windows of shops, cars or planes, museum display cases, etc) to cut out stray reflections.... on pain of causing damage to the focusing mechanism.
May matter to you, or may not - but probably better to know, rather than finding out the hard way?
I enjoy using the original version, while trying to keep the above in mind!
Peter
 Isola Verde's gear list:Isola Verde's gear list
Olympus OM-D E-M10 IV Olympus PEN E-P7
uniball Veteran Member • Posts: 3,075
Not going to comment on the body. The 20/1.7 is about the slowest focusing lens I've used since the original, sans-firmware updates, X100. Its a total annoyance for street in anything but good light and contrast. In the absence of decent light, it will hunt, and hunt, and... I have the current version. Nice render but rarely mounted and will likely be sold.
I use either the PL15/1.7 or the O25/1.8 and am delighted with both of them.
ahaslett
Interesting, it doesn’t hunt on an EM1.2.  Just been trying inside a dark cupboard.
Andrew
Pete_W
Pete_W Senior Member • Posts: 2,838
I completely agree.
I do most of my shooting with a G95 but whenever I want to go light and walk around the street with a camera, I find my GX85 with the PL15mm lens ideal. The tilting screen allows me to shoot from the hip which helps keep a low profile.
Pete
 Pete_W's gear list:Pete_W's gear list
Panasonic Lumix DC-S5 Panasonic S 24-105mm F4 Macro OIS Panasonic Lumix S 20-60mm F3.5-5.6 Panasonic Lumix S 70-300 F4.5-5.6 Macro OIS Panasonic Lumix S 50mm F1.8 +14 more
I recently purchased the GR iii used. I too am not in love with it. It is not the GRiii’s fault.
I love the size and weight. I love the snap focus. I love the B&W simulation. The lens is plenty sharp. Here are my problems. FOV. 18mm is too wide for me. Workaround. Reconfigured the video button so I can digitally zoom to 23mm at 19mp. More than OK. No view finder. Some times I want an EVF to help frame the shot. The GR series never has had an EVF. I knew that but never realized how much I’d miss it. Then there is the battery. Tiny. Easy workaround. Buy more batteries. Since the battery is so lite, carrying a couple extra batteries is no problem. The overall user experience for me, so far, is I’m not having that much fun either the aGR iii.
Still using the GR. Trying to find the love. Overall, I enjoy using my Panasonic GX85 and 15mm lens and Fuji X100S more than the GR.
Mask on Nurse Marty
