Do shorter range zoom lens offer better quality?
Started Jul 12, 2021 | Discussions
Brisn5757 Veteran Member • Posts: 4,540
I have a Panasonic G7 camera and the following lens
14-140mm zoom f3.5-5.6 Lens
45-150mm zoom lens f4-5.6 lens (was free when I got the camera)
I was thinking of buying the 14-42mm lens f3.5 but only if I get better quality from a short range zoom lens as the 14-140mm lens replaces the other two lens.
The other option would be to get a fixed lens (eg Panasonic Lumix G 25mm f1.7 lens)
I'm not certain if this lens is a good option as wide angle lens tend to give distortion.
I would use a fixed lens for photographing items on display. Maybe there is a better option for fixed lens.
Brian
 Brisn5757's gear list:Brisn5757's gear list
Olympus SP-570 UZ Sony Cyber-shot DSC-WX70 Sony Cyber-shot DSC-HX200V Sony RX100 IV Canon EOS 300D +9 more
Panasonic Lumix DMC-G7
WileEC_ID
WileEC_ID Senior Member • Posts: 1,749
Re: Do shorter range zoom lens offer better quality?
Not necessarily. The quality of the lens and the skill of the shooter result in better quality. It tends to be true that you can get better results the closer you are to the subject - but that is true of most any lens.
Quality of lens tends to be a function of the cost of the lens. Fixed aperture zooms tend to provide higher quality than variable aperture zooms and faster primes tend to provide higher quality than slower. But skill of the shooter and closeness to subject can easily influence quality of the result more than the capability of the lens.
 WileEC_ID's gear list:WileEC_ID's gear list
Olympus OM-D E-M1X Olympus E-M1 III Nikon Z6 II OM-1 Olympus M.Zuiko Digital ED 60mm F2.8 Macro +13 more
rurikw
rurikw Veteran Member • Posts: 3,788
A very good lens I am using more and more.
Also very good for its price. That and the 45-150 compete for my most used.
That's the trend with some exceptions which you can usually see on the price. Read some tests and you'll see how they compare.
25 is not wide and on many lenses distortion is at least partly corrected in camera and there are lots of apps that can eliminate the residual distortion too.
25mm could be a good all round fl for that purpose though I don't know what items you shoot and in what circumstances. f1.7 is fast so helps getting good exposure in dim light but only a thin slice of the (3d) object will look sharp.
Brian
 rurikw's gear list:rurikw's gear list
Nikon Coolpix 5000 Sony Cyber-shot DSC-R1 Sigma DP1 Merrill Sigma DP2 Merrill Sigma DP3 Merrill +37 more
alcelc
alcelc Forum Pro • Posts: 19,006
There are two non PZ version 14~42, the mk-I is mediocre at best, and the mk-II is a great lens having IQ very close to, or in opinion of some of its  owners, better than the legendary 14~45. The mk-II is also better than 12~32 on IQ. One of the best f/3.5 class general standard zoom lens of panny.
However, your 14~140 (I guess it is the f/3.5-5.6 mk-I or II) has IQ very comparable to 14~42 mk-II. In fact my copy of 14~140 mk-I is not weaker than the premium 12~35 f/2.8 and has edge to edge sharpness even better than 12~35 f/2.8 on wide open of both. To match with 14~140, I usually shall stop down 12~35 to f/3.5~4.
When compare to 45~150, 14~140 is always a winner.
If f/2.8 and 12 is not required, I would say 14~140 can replace 12~35 + 45~150 without doubt not only on its versatile all-in-one zoom range but also its IQ.
25 f/1.7 had been awarded a gold award by DPR recently. However, it has many reports on sample variation since released. Make sure the return policy of your seller.
Among the f/1.7 primes of 15, 20, 25 and 42.5, I picked 15 because of the wider AoV is better for limited shooting spaces indoor. Never regret it.
Albert
** Please forgive my typo error.
** Please feel free to download the original image I posted here and edit it as you like **
Allan Brown
Allan Brown Veteran Member • Posts: 3,179
Well, I doubt that many will agree with you. I had the P14-42 and it was very poor at 20mm and above. I got rid of it fast.
I had the Oly 14-42 IIR and I also got rid of it.
I had the 14-45 - optically, it is good - far better than the 14-42
I have the 12-32, actually, two of them and I find these to be very good. That is why I have two.
I found that the OIS of the 14-45 is not as good as the 12-32. I was unable to get steady video with it, whereas, the 12-32 is excellent in this regard.
There are many posts comparing the 14-42 to the 14-45 and the 14-45 wins every time - especially, at 40+mm.
Allan
BBbuilder467 Veteran Member • Posts: 7,057
Brian
I think the main advantage of the short zooms is they are easier to hand-hold at the shorter focal length and you don't need to stop down. You take advantage of the shorter focal length. They are a little like primes where you do what they do well.
I have the 25mm f/1.7. That's not wide angle. It doesn't produce particularly shallow dof if you aren't close or have much magnification. I like the 30mm f/2.8 macro lens better for tabletop type photography.  The 25mm makes a good general purpose lens, but there is nothing exceptional about it. It makes a good low light complement to a slow zoom.
alcelc
Are you referring to mk-I of 14-42?
I don't have 14~42 mk-II, but heard more than enough good comment on it from members I trusted... It is very difference to the mk-I.
Albert
cba_melbourne
cba_melbourne Veteran Member • Posts: 5,850
It definitely used to be like that in the film days. Not much anymore, it is now mainly a function of price.
 cba_melbourne's gear list:cba_melbourne's gear list
Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Olympus E-M5 II Olympus PEN-F Olympus E-M5 III +16 more
rurikw
I have the II. It's the only normal range zoom lens I ever had so can't compare but have been happy with its performance since 2015. Just checked what Optical Limits said about both. The difference was less than I remembered but they were tested on 16 vs 12 MP cameras so not directly comparable. Anyway the II is 'surprisingly impressive' in terms of resolution and has low CA according to OL.
alcelc
+1
It was what I heard repeatedly by mk-II's owners. 😀
Some even put it the best ever f/3.5ish standard zoom lens of M43... I can't verify this because I have already too many lenses in similar class. I believe even it might not be the best, it must be among the best.
Albert
Mr Giggles Contributing Member • Posts: 950
YES -
shorter zoom range produces better image that large zoom range
prime lens offer better image than zooms
of course a high quality zoom will be better than a crappy prime
but all things equal the more you want a lens to do the more elements you introduce - the more surface to air reflections ,,,, the more lens elements abd compromises you must make and the more expensive to manufacture
that's why those giant TV camera zoom lens cost a fortune - they must do everything
Allan Brown
Yes, you are probably right if this is the one that replaced the 14-45. It is the one that came with my G3.
If this is the smaller one of the three 14-4x lenses, then yes, I have heard a lot of good things about it.
I did not buy it as I was already into the 12-32.
Some say that the 14-45 is better than the 12-32 but I did not find that. I had both at the same time and compared them. There were differences both in sharpness and colour but not an overall difference. So, either you wanted 12mm or 45mm.
What I did find was the 12-32's OIS was far better than the 14-45 - especially, for video.
So, what I have now is two 12-32 for casual use and my 12-40 Oly for more serious work.
Allan
Harold66
Harold66 Forum Pro • Posts: 12,002
Truth be told , there are better options for ALL the lenses you mentioned in your post
most of the lenses you mentioned are entry level zooms. depending on your budget of course , you could do much better than that
Harold
FOLLOW me on IG @ledaylightstudio.
thedemandingtraveler.org
www.haroldglit.com
IG :thedemandingtraveler
 Harold66's gear list:Harold66's gear list
Sigma DP2 Merrill Ricoh GR II Panasonic Lumix DC-G9 Fujifilm GFX 50S II Panasonic 20mm F1.7 II +5 more
brentbrent Veteran Member • Posts: 5,768
I have owned all three of these lenses.
The second version of the non-power-zoom 14-42 f/3.5-5.6 takes a 46mm filter. https://www.dpreview.com/products/panasonic/lenses/panasonic_14-42_3p5-5p6_ii It is a much better lens than the original one.
The original non-power-zoom 14-42 f/3.5-5.6 takes a 52mm filter. https://www.dpreview.com/products/panasonic/lenses/panasonic_14-42_3p5-5p6/specifications I have owned this lens too, and it is not a good lens.
I thought the 45-150 was also pretty good. I sold that and the 14-42 II to acquire the 14-140, for the convenience of having basically that full range in one lens.
I think the image quality of the 14-140 is as good as that of the 14-42 II and 45-150. Some may say better. So I would recommend against buying the 14-42 II if your reason for doing so is to get better image quality. If you just want a smaller lens to use when you don't need longer than 42mm, it might make sense.
I think it would make more sense to sell your 45-150 and then consider buying the 12-32, to have 12mm at the wide end and a very compact lens for when you don't want to use the 14-140.
Or a prime, like you mention (25mm f/1.7, which is not a wide angle lens)
That's a general rule of thumb, but it does not always hold true. I don't think it holds true in comparing the 14-140 against the other two lenses you mention. It certainly doesn't hold true when comparing, say, the Olympus 12-100 against any 14-42 lens.
Do you think the image quality from your 45-150 is better than from your 14-140?   While some 10x zoom lenses don't have very good image quality, most here think that the Panasonic 14-140 f/3.5-5.6 is very good, me included.
Brent
 brentbrent's gear list:brentbrent's gear list
Panasonic Lumix DMC-GX7 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-GX8 Panasonic Lumix DC-G9 Olympus E-M1 III +26 more
one blind eye
one blind eye Contributing Member • Posts: 807
Brian
Yes.
I see life through monocular vision.
 one blind eye's gear list:one blind eye's gear list
Sony RX100 Sony RX100 VII Panasonic Lumix DMC-GX7 Olympus PEN-F Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 +5 more
Sergey Borachev Veteran Member • Posts: 5,338
Of course shorter range should always give better quality, if you have the the same attention to quality in design, use of expensive material and lens elements, tolerance in manufacturing, same speed ...
Eric Nepean
Eric Nepean Veteran Member • Posts: 6,209
This is usually true all else being equal.
The 45-150 f4-5.6 is a nice sharp lens (I have it)
The original 14-140mm f3.5-5.6 zoom does not have a good reputation. (but I have never tried it)
If do have the 12-60 f3.5-5.6 zoom and I find it a sharp lens. It's a good companion to the 45-150.
Brian
Cheers
Eric
(Feel free to edit and repost any image that I have posted in a DPR, as long as you identify me as the original poster)
 Eric Nepean's gear list:Eric Nepean's gear list
Panasonic Lumix DMC-TS3 Panasonic Lumix DMC-GX7 Olympus E-M1 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 +73 more
alcelc
Dear Eric, did you wish to say the bigger and oldest version of 14~140, which is f/4~5.8 instead of the newer and smaller f/3.5~5.6 version?
AFAIK the 14~140 f/3.6-5.6 mk-I, before its updated mk-II WR version was released, was one of the most recommended lenses of M43 Panny non pro class lens.
Or did you refer to the shutter shock possibility of this particular lens?
IMHO 14~140 is sharper than 12~60 if we can avoid SS. On similar zoom range, on IQ my mk-I is comparable to 12~35 f/2.8, marginally better than 12~32 and beat 45~150.
Brian
Cheers
Eric
Albert
Eric Nepean
Hello Albert
I think your knowledge of the 14-140 zooms is superior to mine. You own one, and I note your careful evaluattion.
I meant to refer to the bigger and oldest version of 14-140, which is f/4~5.8
I wasn't thinking of shutter shock, simply MTF. I too have heard many postive comments about the MKI and MKII versions you refer too. However, its difficult to find any quantitative evaluation of thee image quality
That's a very useful comparison.
It's Interesting that my evaluation of the 12-32 is different than yours. I have quite a high regard for my original version 12-35 f/2.8 and also my 45-150. I have 3 copies of the 12-32 and I don't like the images from any of them (although one is the best) It seems there is some sample variation.
What is your opinion of the shutter shock of the 14-140 f/3.6-5.6 MKI and MKII on your latest bodies (I see you have both G85 and GX80 on your gear list)?
I do like my GX7 but my current cameras are GX8 and GM5.
Brian
Regards
Eric
bobn2
bobn2 Forum Pro • Posts: 71,955
Like many of these things, don't confuse a tendency with an absolute rule. The design constraints on shorter range zooms are more relaxed than longer range ones, so the designers have more freedom which can be used to make them better. That doesn't mean that every short zoom will be better than every long zoom, and there are some good examples of longer zooms which are better than quite a few shorter zooms.
Is it always wrong
for one to have the hots for
Comrade Kim Yo Jong?
