RF 400, or EF 400 with adapter?
Started Jul 11, 2021 | Discussions
John Sheehy Forum Pro • Posts: 26,688
Re: RF 400, or EF 400 with adapter?
bernie r wrote:
So you’re saying that used mk3 EF 600mm f/4’s are selling for half price? Certainly not that I’ve seen. Used mk3’s seem as rare as hen’s teeth. Now, mk2’s yes they have gotten very affordable but then there are more differences than AF speed between that and the new models.
Only real difference is the size and weight, aside from that you'll be getting the same resulting image, I don't see a point to paying $13,500 for a RF 600 f4 when you can get a used EF 600 f4 MK2 for $7000.
But do what you want to, if weight is worth over $6,000 to you, that's fine.
We don't know that it is just weight; the RF AF and stability may be better.  Without some more comparative facts, we can't tell what the extra $6K buys you (besides new-ness and lower weight).
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
dgumshu
dgumshu Veteran Member • Posts: 4,623
Link Taken from another thread... looks like the extra 6K will buy a fuzzier picture too with 1.4 tc:
https://www.the-digital-picture.com/Reviews/ISO-12233-Sample-Crops.aspx?Lens=1556&Camera=1508&Sample=0&FLI=1&API=1&LensComp=748&CameraComp=979&SampleComp=0&FLIComp=1&APIComp=1
 dgumshu's gear list:dgumshu's gear list
Canon EOS-1D X Canon EOS 5DS R Canon EOS 5D Mark IV Canon EOS R5 OM-1 +52 more
bernie r Contributing Member • Posts: 536
I'm oddly not surprised, I'm not switching my EF 500 f4 for awhile...
Camera:
Canon EOS R5
Canon RF 15-35 2.8
Canon RF 28-70 2
Canon EF 70-200 2.8
Canon RF 85 1.2
Canon EF 500 f/4 L IS II USM + 1.4X III
Other:
Gitzo Fluid Gimbal Head
Gitzo GT4543LS Systematic Series 4 Carbon eXact Long Tripod
Benro Mach3 TMA38CL Carbon Fibre Tripod
Benro G3 Ball Head
Canon Speedlite EL-1 Flash
Canon Speedlite 470EX-AI Flashgun
Gitzo Adventury 45L
PicPocket Veteran Member • Posts: 5,897
Let's switch to Good copy, bad copy threads...
 PicPocket's gear list:PicPocket's gear list
Canon EOS R5 Canon EF 24-70mm F2.8L II USM Sigma 135mm F1.8 Art Canon RF 70-200mm F2.8L IS USM Canon RF 100-500mm F4.5-7.1L IS USM +16 more
A lens costing $13,500 shouldn't have room for a 'bad copy'.
pls....
Camera:
Canon EOS R5
Canon RF 15-35 2.8
Canon RF 28-70 2
Canon EF 70-200 2.8
Canon RF 85 1.2
Other:
Benro G3 Ball Head
Gitzo Adventury 45L
BirdShooter7 Veteran Member • Posts: 9,127
lol let’s do, there is definitely a lot of motivated reasoning going on in these forums so why not.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
pls....
Yes you certainly would think so and especially with all the automated assembly.
There's also conversion parameters, including lens corrections, and resampling issues when making them the same size for the test image elements.
John
dgumshu
Ironically, three copies of the EF lll were compared to the EF ll during the EF lll lab tests at this site.  Same results.  Optically, the RF and EF are identical.
dgumshu
That one is a keeper.  Best lens I ever shot with.
Olgierd Regular Member • Posts: 405
I would check if there's difference in the image stabilization department.  Does the IS of the EF lens work in conjunction with IBIS ?
Olgierd
Good or bad I'm guy with a big lens.
 Olgierd's gear list:Olgierd's gear list
Canon EOS 5D Mark III Canon EOS M Canon EOS 7D Mark II Canon EOS R6 Canon EF 16-35mm F2.8L II USM +12 more
roby17269
roby17269 Senior Member • Posts: 2,395
lokatz wrote:
Still fairly new to the Canon world, so I'm hoping someone can help me with this:
I am contemplating getting a 400mm f/2.8 lens for my R5. From what I can see, it appears to make more sense to get the latest version of the EF lens and put it on the body via a control ring adapter since the RF lens has no control ring. I like the added flexibility the control ring gives me, even if its placement is quite inconvenient.
Availability put aside, is there ANY disadvantage to this that I need to be aware of and that would speak for getting the RF lens instead?
My take, worthy less than the 2 proverbial cents, is simply...
If you are on the market for a new lens, go for the RF version. If you are ok with a used lens, get the EF mkIII version.
I am speculating like everyone else here. My assumption is that the RF version is 100% identical to the EF mkIII version with an adapter bolted on.
Ultimately, I think that, if there were material differences between the 2 version, Canon would have advertised them explicitly. I am sure that the RF version is great, but I also think that it is as great as the EF mkIII version, no more no less.
Based on this assumption, I assume that:
  • there is a minor disadvantage with the RF version in that you cannot have a control ring. Personally it wouldn't be a big deal to me, but YMMV
    • I see no issue with not being able to use the adapter with the drop-in filter, since those lenses already have a drop-in filter
  • there is a minor advantage with the RF version in that there is 1 less mechanical coupling, therefore the camera+lens combo may be a little more robust
  • the AF of the RF version will be indeed faster with a R3/R1, but in the same way the AF of the EF version is faster with a 1D body. It's all about bigger batteries. So I suspect that the EF mkIII version will be equally faster when used with a R3/R1
Ciao!
Roberto
My photos: http://rdmfashionphoto.com/
IG: @rdmfashionphoto
 roby17269's gear list:roby17269's gear list
Canon EOS R5 Canon TS-E 17mm f/4L Canon MP-E 65mm f/2.5 1-5x Macro Canon TS-E 24mm f/3.5L II Canon RF 50mm F1.2L USM +20 more
lokatz
OP lokatz Veteran Member • Posts: 3,564
Thanks, Roberto.  I'd say your post is worth at least 2.5 cents.  After all, it concentrates on whatever few facts seem to be available.
 lokatz's gear list:lokatz's gear list
Sony RX100 VII Canon EOS R5 OM-1 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +31 more
roby17269
Thank you kind sir 2.5 it is then
Ciao!
Roberto
