RF 400, or EF 400 with adapter?
Started Jul 11, 2021 | Discussions
lokatz
lokatz Veteran Member • Posts: 3,564
Still fairly new to the Canon world, so I'm hoping someone can help me with this:
I am contemplating getting a 400mm f/2.8 lens for my R5.  From what I can see, it appears to make more sense to get the latest version of the EF lens and put it on the body via a control ring adapter since the RF lens has no control ring. I like the added flexibility the control ring gives me, even if its placement is quite inconvenient.
Availability put aside, is there ANY disadvantage to this that I need to be aware of and that would speak for getting the RF lens instead?
 lokatz's gear list:lokatz's gear list
Sony RX100 VII Canon EOS R5 OM-1 Olympus Zuiko Digital 1.4x Teleconverter EC-14 Olympus M.Zuiko Digital ED 40-150mm F4-5.6 R +31 more
Canon EF 400mm f/2.8L IS II USM Canon EOS R5 Canon RF 400mm F2.8L
BirdShooter7 Veteran Member • Posts: 9,127
Re: RF 400, or EF 400 with adapter?
Unless I planned on using the the lens on an old EF body I’d definitely go for the RF since it has the newer mount with faster communications capabilities.  It will be interesting to see if any noticeable differences exist as people get a chance to try the RF version, especially if they already have experience with the EF.
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
cjb
cjb Contributing Member • Posts: 575
Optically the same.
EF works on more systems: DSLR and other systems with adapters.
EF allows use of control ring adapter (I don't think I'd use this honestly - too far back.)
EF allows use of variable ND drop-in EF-RF adapter. Helpful for landscapes.
RF has more pins and the possibility of taking full advantage of R1 and R3 speed. It might focus a fraction faster with those systems. But Canon is not saying and no one outside of Canon knows for sure.
RF has one less mechanical coupling. It should be slightly stiffer.
It's a close call. I'd pick the EF version today. For the flexibility. But tomorrow?
 cjb's gear list:cjb's gear list
Fujifilm X100V Canon EOS-1Ds Mark III Canon EOS-1D Mark IV Canon EOS-1D X Canon EOS 5DS R +43 more
cjb wrote:
Optically the same.
The higher speed communication could also benefit the image stabilizer as well.
cjb
Yup. Maybe.
Lots of speculation. I wish we knew more to help inform these very expensive purchase decisions. I currently am wrestling with this decision myself, but I don't have an R camera yet. I was waiting for the R1, but the R3 may be it.
cjb wrote:
Yup. Maybe.
Yes it would be great if Canon talked about this but I’d be very surprised if they do.
Tambopata Regular Member • Posts: 164
BirdShooter7 wrote:
cjb wrote:
Optically the same.
It might increase AF prescision as well. I do believe that the RF extenders will produce better details with the RF 400/600 than the EF extenders do with the EF 400/600.
 Tambopata's gear list:Tambopata's gear list
Canon EOS R5 Canon EF 600mm f/4.0L IS II USM Canon RF 24-105mm F4L IS USM
lokatz
OP lokatz Veteran Member • Posts: 3,564
Appreciate everyone's inputs!
hedleyw
hedleyw Contributing Member • Posts: 539
I can’t comment on the RF version but I have the EF 400mm f2.8 mkiii and it works really well on my R5, both on its own and with the 1.4x and 2x mark iii converters.
One advantage over the RF is that you may be able to pick one up used, as I did, and save a fair bit of money. It will be quite a wait for a used RF version. It is the only EF lens that I own so the adapter lives on it permanently.
Hedley
 hedleyw's gear list:hedleyw's gear list
Olympus Tough TG-4 Ricoh GR IIIx Olympus PEN-F Canon EOS R5 Canon EOS R3 +27 more
John Crowe
John Crowe Veteran Member • Posts: 3,476
Well, you know more about RF than I do, and I have been shooting Canon for 35 years.
First I am shocked they are the same price.  Canon usually prefers to gouge it's customers.
It is a large purchase to consider...not just the size of the lens.  I have used mirrorless in the past so my main concern is how well you can adapt to how they work for sports.  I will make that assumption based on it being the 400/2.8, and I am referring to the EVF.  I would master the R5 first to evaluate how it is likely to perform with a big lens.  This will also tell you how much you rely on the control ring.  If you end up preferring an OVF then go with the EF and control ring adapter, and buy a used DSLR for those times when you prefer the OVF.
If you evaluate the R5 and determine that you are never going back to  DSLR then I would chose the RF lens, with one caveat.   It certainly looks like the RF 400/2.8 is not truly an RF lens.  It seems to be an "affordable" stop gap until Canon themselves get used to the RF system and what they can do with it.  I suspect that with continued success of the RF system that Canon will replace this lens before too long.  Perhaps with even a 400/2.4.
If you chose the EF 400/2.8 I suggest purchasing a used IS II for half the price, see how it goes, and then resell it at almost no loss, when you see what Canon does with an updated RF 400.
I have used two old 400/2.8 lenses so I know they are all incredible!  Any advantage that the current RF lens has over the EF will be virtually unnoticeable.  It is the replacement for this RF 400/2.8 that could be the deal breaker.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
tkbslc Forum Pro • Posts: 17,522
Canon themselves have said it's the latest EF lens in RF clothing. It can't shoot more FPS or focus faster. It doesn't have the highest available stabilization stops like a true RF redesign. Just look at pictures of the RF version and you can see there's a silver adapter bolted on the end. They didn't even design new white lens body down to the mount.  It's no different than if you did it yourself, except you can't remove it later.
I'd definitely get which ever was cheaper.  Honestly, I'd get a used EF 400mm II.  Save about half and the pictures will be the same.
bernie r Contributing Member • Posts: 536
Why would you spend twice the amount of money for basically the same product? With an attached adapter, just get a used EF 400, for literally half the price of the RF one. People won't be able to tell a difference in your images.
Camera:
Canon EOS R5
Canon RF 15-35 2.8
Canon RF 28-70 2
Canon EF 70-200 2.8
Canon RF 85 1.2
Canon EF 500 f/4 L IS II USM + 1.4X III
Other:
Gitzo Fluid Gimbal Head
Gitzo GT4543LS Systematic Series 4 Carbon eXact Long Tripod
Benro Mach3 TMA38CL Carbon Fibre Tripod
Benro G3 Ball Head
Canon Speedlite EL-1 Flash
Canon Speedlite 470EX-AI Flashgun
Gitzo Adventury 45L
Can you show me where they said it doesn’t perform AF any better?  All I remember reading was that it has the same optical formula.
lokatz
John Crowe wrote:
Hi John, Appreciate your thoughts.
Well, I've had the R5 together with the RF 100-500 for about two months now. I also own a Nikon Z7 II and had a Z7 before that. I primarily shoot birds, so the 400mm will practically be welded to a TC, and I am comfortable with the EVF, especially the one on the R5.  The control ring comes handy but is not an absolute must-have.
That is a good point.  As others pointed out, the EF and RF versions of this lens are virtually identical, so the RF might well be a stop gap.
Problem is, I cannot find any decent used EF copy here in Germany, at least not in the version II incarnation, so this does not look like a viable route.
Where can I buy an EF 400mm f/2.8 iii for ~$6000???
Camera:
Canon EOS R5
Canon RF 15-35 2.8
Canon RF 28-70 2
Canon EF 70-200 2.8
Canon RF 85 1.2
Other:
Benro G3 Ball Head
Gitzo Adventury 45L
RDM5546
RDM5546 Senior Member • Posts: 3,654
My experience with the R5 and the RF100-500 lens would cause me to be cautious in overlooking the improvements that may be possible in the RF400f2.8. I own an 16year old EF400f2.8L IS mk 1 which works very well even using the 20fps electronic shutter with R5. It is razor sharp and it is very sharp with enormously nice bokeh using F2.8 on a tripod It is a very heavy 12lb lens providing excellent results. So the prospect of me upgrade to the RF 400f2.8l IS is slight without me knowing a lot more information about the advantages it would bring. That is a lot of money it costs but it is more than 5 lbs lighter and maybe is handy on a monopod while my 12 lb EF 400f2.8L IS beast is not really a monopod friendly lens. I have relevant prior experience in the benefits of expensivie upgrading of my EF100-400 II to RF100-500 which was less upgrade expense than the RF400f2.8 upgrade but still a lot of money.
I have the R5 with the EF 100-400 II and I originally thought that RF 100-500 that I was not sure I would ever buy. I own the 1.4X III and 2.0X III TCs so as to upgrade to the RF lens I would need to by the RF lens and two TCs costing a lot of money.
Both the EF and RF are quite similar except for focal lengths covering 400-500mm, 1lb in weight. and reduces FL ranges during TC usage (RF100-500 becomes 300-500mm when using TC while EF100-400 remains 100-400). The extended reach of 400-500 and 1lb lens weight were both very attractive to me once I tried the RF lens which IQ of both lenses used at in the same conditions seemed very similar in sharpness and rendering. The RF was not better in IQ in any major way but likewise it was not worse than the EF 100-400 II. Weight and lens reach were the two initial benefits.
However, the R5 EVF has has a menu item (red camera, menu tab 7 #3 High Speed Display) that is an EVF enhancing function that is specific only to Mechanical and First Curtain Shutter modes only, requiring both Autofocus ON and the drive mode H (not H+). This High Speed display mode works only with RF lenses like the RF 100-500 and not EF lenses.
When comparing the EF 100-400II with the RF100-500 I tried to evaluate any benefits that the High Speed Display mode of the R5 had when using that is available using the RF100-500. I read did not note a big difference with the HSD menu item turned on or off. It was hard to tell there was a difference. However, when shooting BIF I felt that the RF 100-500 produced for me a higher keeper rate yielding sharper and better tracked images with HSD on or off. I do not if it was AF or my tracking skills assisted by lower weight that was responsible. It remains a mystery but convinced me to spend the money to keep the RF 100-500 and pay the big money for lens and the RF 1.4 and 2X TCs.
So what I thought I learned from this prior upgrade you may really need to get hold of the RF and EF lenses to them shoot with the same camera close to side by side as you can to accurately determine how you feel about each alternative. You can rent both lenses for a week maybe and do your tests. I was surprised by how my opinion of the RF lenses became even more favorable once I tried them and saw the images I could produce. I doubt I will be doing this any time soon for my case since my use for the 400mmf2.8 has been reduced because I am still exploring the benefits of using the wonderful RF 100-500 light weight action shooting on the R5.
The beneficial RF400f2.8 6lbs lens extra nice bokeh and f2.8 lowlight level sensitivity are reduced my interest in my use of this lens by my surprising RF100-500 shooting experiences. The grounding breaking low light sensitivity of the R5 used along with the software power of the DXO PL4 Deep Prime software act to reduce motivation and my needs for the benefit of the RF f2.8 lens over my existing proven performance paid for EF 400f2.8LIS..
 RDM5546's gear list:RDM5546's gear list
Canon RF 100-500mm F4.5-7.1L IS USM Canon G5 X II Canon EOS 70D Canon EOS 7D Mark II Canon EOS 5D Mark IV +47 more
That’s the heavier mk2, not the mk3
$6000 vs 1kg weight savings.   Same pictures.
It's the exact same lens with the same motors, how could it perform AF better?
