Scanning more than one photo at a time - saving as individual files
RayGuselli
RayGuselli Forum Pro • Posts: 17,959
I know this is asking a lot but……
A few years ago I was told about a program which allowed me to scan a few photographs at a time on my A3 scanner, but where photoshop (or some script) then automatically saved each one as a separate scan/image.
I just cannot remember what it was or how to do it…
Can anyone suggest what I was using please.
Many thanks
Ray
VISIT MY WEBSITE HERE...HOPE YOU LIKE
http://www.flickr.com/photos/77568703@N03/
 RayGuselli's gear list:RayGuselli's gear list
Nikon D300 Nikon D700 Nikon D750 Nikon AF Nikkor 18-35mm f/3.5-4.5D IF ED Nikon AF-S Nikkor 28-300mm f/3.5-5.6G ED VR +2 more
RayGuselli
OP RayGuselli Forum Pro • Posts: 17,959
Re: Scanning more than one photo at a time - saving as individual files
For anyone who might be thinking the same...I have found it here...
https://www.dpreview.com/forums/post/60466298
Best wishes Ray
IanYorke Veteran Member • Posts: 4,672
Many thanks
Ray
Have you tried Vuescan. It allows you to scan the photos and then you can crop and adjust individual photos and then save from memory without re-scanning.
Ian
RayGuselli
Than k you Ian...that sounds a good idea...
I will have a look at that...
Much appreciated.
Best wishes Ray
JohnWheeler Contributing Member • Posts: 612
Many thanks
Ray
Hi Ray
First thanks for all you posts on colorization of images and have learned a lot from you.  I am amazed by your skills (and glad you wife puts up with it   )
Vuescan was already mentioned and that may be a great and less expensive way to go.
Another software option to consider is Silverfast: https://www.silverfast.com/silverfast9/
I must say I have not used Vuescan yet it sounds really good.   Silverfast is more of the "Photoshop" of scanning apps with a lot of bells and whistles.   That can be good and it can be bad with a bit more learning curve.
I have used it with my Epson scanner to scan multiple 1800 era prints at a time.  Silverfast allows you to identify as many crops as you want with unique settings for each (if desired) so when you tell it to scan, you can walk away and just have it do all the work.
That was appealing to me as one crop would be of the entire set of images, I would flipt them over and do an entire scan of the back (to capture notes people had put on the images) and then a crop of each of the individual prints and then scans of each of the individual people or parts of the image.
The first overall scans were similar to a contact print at relatively low resolution and the others were at a resolution where I could get 300 dpi for an 8x10 print whether for the individual full print or an individual person  crop.  This worked for me rather than one supper high resolution scan of all the images simultaneously with cropping after in photoshop.    It ended up being faster scanning time overall as well.   All my desired options were pre-cropped so a small time saver there as well.
Just another option to consider though it does cost more.
John Wheeler
John Wheeler
Never give up. Never surrender. Galaxy Quest
sluggy_warrior Senior Member • Posts: 2,656
Best wishes Ray
I recently had to scan a few hundreds of tiny B&W photos of my parents, was able to fit 9-12 of them in one scan but had the same problem of splitting them automatically.
Since I don't use Photoshop (on Ubuntu), I found a plugin/script for GIMP that does similarly, worked well consistently for me.
https://github.com/dmig/DivideScannedImages
https://francoismalan.com/2013/01/how-to-batch-separate-crop-multiple-scanned-photos/
RayGuselli
Hi John
Many thanks or such kind words which are really appreciated...
I will tell my wife...LOL
Thanks for this other option...
Something else to consider now and hopefully when the winter nights come and I am looking for something to do I can start to move thousands of images to digital...
Will have a look at this option.
Many thanks and very best wishes
Ray
RayGuselli
Thanks so much sluggy_warrior...
Another option for me to look at and much appreciated.
Seems I am not alone with this need.
Very best wishes
Ray
Barry Twycross Veteran Member • Posts: 4,679
Many thanks
Ray
VueScan was what I was going to suggest.
I don't often use a flat bed with it, but I thought there was an option to extract multiple pictures automatically with one scan.
 Barry Twycross's gear list:Barry Twycross's gear list
Panasonic GX850 Fujifilm GFX 50R Panasonic Lumix G Vario HD 12-32mm F3.5-5.6 Mega OIS Leica Nocticron 42.5mm Fujifilm GF 110mm F2 +9 more
(unknown member) Regular Member • Posts: 462
For Photoshop Elements users there is a menu item "Divide Scanned Photos" under Image in the main menu.
It does a very good job at splitting multiple photos from a single scan.
I would expect there to be a similar option in Photoshop.
RayGuselli
Hi Kaspah
That looks so simple.
I must have a ,ok for that....
Thank you very much
Thank you
Best wishes Ray
RayGuselli
Thank you Barry
Much appreciated
Best wishes
Ray
No problem Ray.
I'm not a Photoshop user but I did a quick google out of curiosity and found this web page which seems to show how to split images from a single scan in Photoshop.
https://www.dummies.com/software/adobe/photoshop/scan-multiple-photos-in-one-pass-in-photoshop/
If the article is accurate then in Photoshop:
File -> Automate -> Crop and Straighten Photos.
RayGuselli
Hi Kaspah.
That is certainly favourite for me I think.
Really appreciated.
Best wishes as always
Ray
Don Simpson Forum Member • Posts: 98
Many thanks
Ray
Yes, VueScan can scan multiple photos at a time, crop them and then save them as separate files.
Here is a link to VueScan's process:
How to scan multiple photos on a flatbed
 Don Simpson's gear list:Don Simpson's gear list
Nikon Z6 Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Nikon AF-S Teleconverter TC-14E III Nikon 200-500mm F5.6E ED VR Nikon Z 24-70mm F4
RayGuselli
Thank you Don...
really appreciated.
Best wishes Ray
