How to install Grain2pixes?
Started 5 months ago | Questions
Diano Regular Member • Posts: 184
My PC :  Windows 10 home 64b. 20H2, desktop
Have had my Nikon gears out (Nikon F, Photomic FTN & 5 lenses) & like to shoot some film.  I'll try to do it the easy way.  Have the film images inverted by Grain2pixel in PS.
Have downloaded & extracted Grain2pixel_SE_v5.3.8.1 but find no clue how to install & created a launcher.  Watched many times the Guide video, unfortunately, characters too tiny & voice too low, almost impossible to get any clue for installation.
Help, please.  How to get it started, installed and plugged in PS.
Diano
Overrank
Overrank Senior Member • Posts: 3,103
Re: How to install Grain2pixes?
Diano
I installed it a long while ago so I don’t remember all the details but I think I just followed the instructions in the first video at https://grain2pixel.com/guide/
I will add though that I don’t really use plug-ins or actions in PhotoShop and it was not very intuitive.  Maybe if you did use those it would be more second nature.
It dose a pretty good job of the conversion though
OP Diano Regular Member • Posts: 184
Diano
Thank you, Overrank.
Appreciate the link.  I have tried several times but simply can't understand anything the gentleman talking about, the voice is too low and the characters are too tiny.  Can't rely on the guide.  Have to find some other instructions.
No.  I am not going to rely on Grain2pixel or any other similar software for my conversions.  I have tried many times of manual conversions and colour inversions, and have experienced that the most frustrating part of the whole process is the first part, the first few steps of converting the negative to positive and to find the right white balance.  Once I can get this part done in the right way, then the colour adjusting is relatively easy.   What I need the Grain2pixel for, therefore, is to have my negatives converted to positives.  Then I'll do the colour adjusting.  Why?  Grain2pixel does a much better while balance than I can do.  How to you think?  Do I make any sinse?
Thank you.
Diano
Overrank
Diano
Thank you.
Diano
You might want to look at the instructions DrBormental has recently posted for inverting by hand - https://www.dpreview.com/forums/post/65309288
Or some of the other software that does the same thing -
Barry Duggan Photography
Barry Duggan Photography Senior Member • Posts: 1,225
Diano
Thank you.
Diano
Hi,
Basic question here but which from your list would you recommend.
I use Affinity Photo on a Mac.
Barry.
Website - barryduggan.com
Email - barrydduggan@gmail.com
Twitter - @barrydduggan
 Barry Duggan Photography's gear list:Barry Duggan Photography's gear list
Sony a7 Sony FE 28mm F2 Sony FE 50mm F1.8 Sony FE 85mm F1.8 +5 more
Overrank
Barry Duggan Photography wrote:
Diano
Thank you.
Diano
Hi,
I use SilverFast and a scanner so I might not be best placed….
But in the little camera scanning I’ve done (mostly disc film) I’ve been very happy with the *results* from ColorPerfect.  It is not the best workflow though. I don’t like LightRoom so NegativeLabPro is no good for me, Grain2Pixel does a good job but I think it  has a clunky interface because you use it through Photoshop, FilmLab doesn’t need Photoshop but I’m not sure the colours are always brilliant for non-Portra film
rdginto Regular Member • Posts: 121
Hi there. I was intrigued by this thread, so I downloaded G2P and followed the Mac version of the installation video. Here's a few things. The video is not easy to follow. The presenter is a bit hard to understand at points, and there's a lot of fussing around with converting 2 text files to executables and granting permissions. I would not recommend anyone try this unless you are very comfortable with the file system and Terminal.
G2P is not an app in the usual sense that most here are used to, and it's not a plugin. It is a script that evidently uses DCRAW and lots of Photoshop jiggery-pokery to spit out a 48-bit tiff file. It doesn't even open it in Photoshop for editing. The sample below was converted to a jpg in LR with adjustment for white balance only.
On the other hand, it works! and the conversion, compared to what I've been able to achieve in the past with Negative Lab Pro and ColorPerfect, is very good. Lots of contrast and vibrant colour. Here's a sample, which was from a scan (VueScan) of a 120 negative.
Bob in T.O.
