Canon 100-400mm V1 or 2X III extender with 70-200mm III for Safari?
Started 5 months ago | Questions
bernie r Contributing Member • Posts: 536
Re: Canon 100-400mm V1 or 2X III extender with 70-200mm III for Safari?
Just rent the 100-400 MK2 for the Safari?
Camera:
Canon EOS R5
Canon RF 15-35 2.8
Canon RF 28-70 2
Canon EF 70-200 2.8
Canon RF 85 1.2
Canon EF 500 f/4 L IS II USM + 1.4X III
Other:
Gitzo Fluid Gimbal Head
Gitzo GT4543LS Systematic Series 4 Carbon eXact Long Tripod
Benro Mach3 TMA38CL Carbon Fibre Tripod
Benro G3 Ball Head
Canon Speedlite EL-1 Flash
Canon Speedlite 470EX-AI Flashgun
Gitzo Adventury 45L
gavin
gavin Veteran Member • Posts: 8,108
Rent 100-400 II. i have 100-400 I and II. My friend has 70-200/2.8 + 2x and its not as good as 100-400 I.
 gavin's gear list:gavin's gear list
Sony RX100 III Canon EOS 5D Mark II Canon EOS 5D Mark IV Canon EF 50mm F1.4 USM Canon EF-S 17-85mm f/4-5.6 IS USM +5 more
John Sheehy Forum Pro • Posts: 25,210
What version of the 70-200/2.8?  If it's II or III, I would expect AF and IS with a 2xIII to be better than the 100-400 v1.  The 100-400 v1 is a virtual antique in terms of IS and AF speed, even if you have an optically-exceptional copy.
Beware of correct answers to wrong questions.
John
http://www.pbase.com/image/55384958.jpg
John Crowe
John Crowe Senior Member • Posts: 1,667
Take your zooms, and for not much more than the EF 2X III, get a used Canon EF 400mm f5.6 L instead.
I think for the most part a long zoom will be constantly at 400mm and the Canon prime will be superior to your alternatives.
Canon EOS 5DS R Canon EF 70-200mm F4L USM Canon TS-E 17mm f/4L Kenko Teleplus Pro 300 AF 1.4x Venus Laowa 12mm F2.8 Zero-D +15 more
User4286416121 Contributing Member • Posts: 860
Congratulations.  Thank you for planning so far in advance.  Gives you time to know your gear too.  A lot could happen in six months.  Changes, new gear, available used gear...even new bodies.
gavin
It was the old version 1 70-200/2.8. The 100-400 I is OK but the II is great. I use it with the 1.4xIII regularly to get 140-560/8 for surfing photos
The mark II and III lenses AF significantly faster with some bodies with the mark III Canon TCs.  The mark III version of the 70-200/2.8L may be significantly sharper wide open at the long end than the mark I.
John
gavin
I know. However I am thinking of changing to the RF system soon so  I will get the RF 70-200 to replace mine.
