2d-t-3D conversion- opinions on two pairs please
Started Jul 6, 2021 | Discussions
uuglypher
uuglypher Regular Member • Posts: 250
opinions please.
Dave
uuglypher
"100% of the shots you don't take don't go in!"
Wayne Gretzky
Donnie Loftus Junior Member • Posts: 45
Re: 2d-t-3D conversion- opinions on two pairs please
To me there is no difference, they both look the same.  Maybe a photo that has more depth would help.
uuglypher
OP uuglypher Regular Member • Posts: 250
some perceive a significant difference in depth between the two pairs, and can easily differentiate the two.
I’ll hope more responses, an wlll also  start another thread with a different pair.
Thanks for participating.
Dave
uuglypher
Wayne Gretzky
uuglypher
Really?
in two months why  has only one person examined the posted image pairs and responded? And has no one perceived a difference in in depth illusions provided by these two image pairs?
C,mon, gang,  let’s have more input..
uuglypher
Wayne Gretzky
rmexpress22 Senior Member • Posts: 2,304
They look very similar to me too but for some reason I can lock on the bottom one quicker.
 rmexpress22's gear list:rmexpress22's gear list
Canon EOS 5D Mark IV Canon EOS M6 Canon EF-M 22mm f/2 STM Sigma 85mm F1.4 Art Canon PowerShot G16 +20 more
uuglypher
Thank you, rmexpress22,
sample B is most often noted as lacking the “through-the-frame” effect so strongly shown in sample A.
Best regards,
Dave
uuglypher
Wayne Gretzky
uuglypher
Best regards,
Dave
The “through the frame” effect was introduced here just to see if anyone was paying attention and by way of introducing discussion on the relative effects of different  degrees of encroachment of E and W edge masks upon the image subject.
Evidently,, no one was, in fact, paying attention. /;>)
And so, now having been given the go-ahead by our Moderator let’s give it another go and view some examples of the effects of mask encroachments upon image subject:
Dave
Comments?
Discussion?
Slings and arrows?
uuglypher
Wayne Gretzky
Turbguy1
MOD Turbguy1 Senior Member • Posts: 1,467
Of the two, the top has more "3D effect" to my eye, although the subject elements appear somewhat flat (no "solidness" in the body,  no "z" difference between the BIF and the background).
The frame edges have been adjusted to place the scene in different "z" positions with respect to the image
 Turbguy1's gear list:Turbguy1's gear list
Minolta DiMAGE 7 Konica Minolta DiMAGE Z5 Konica Minolta DiMAGE A2 Fujifilm FinePix Real 3D W3 Nikon D300 +3 more
uuglypher
yep! Two people can view the same image pair and perceive very different 3D illusions!
The frame edges have been adjusted to place the scene in different "z" positions with respect to the image.
Right! Do you have a particular pattern of masking you follow for different effects?
Do you find that some images benefit more form frame adjustment than do others?
Dave
uuglypher
Wayne Gretzky
Turbguy1
My frames are all rectangular, equally sized for left and right views, and are meant to be perceived as a flat plane (all frame edges at an equal z-position).
To most viewers using an electronic screen, they should appear to be at the plane of the viewing screen itself (YMMV).
The "interior" image elements are placed so either all are at, or behind, the frame edges, OR some may project at a z-position above the screen (closer to the viewer) without any such image element intersecting any portion of the frame (hopefully, sometimes I overlook a blade of grass or small detail).
Does this make sense?
uuglypher
Of course it does! You have a personal preference and vision and make every effort to adhere to it. Couldn’t be more reasonable.
uuglypher
Wayne Gretzky
tony brown Veteran Member • Posts: 4,387
For me, "A".
Cheers, Tony.
uuglypher
tony brown wrote:
For me, "A".
Hey, Tony!
Many thanks for bringing this back to my original question!
you are now duly registered as preferring example A. Is that a gut feeling or do you have an objective reason for your preference?
Good t’hear from you, Man!
Dave
uuglypher
Wayne Gretzky
uuglypher wrote:
tony brown wrote:
For me, "A".
Hey, Tony!
Dave
It was fairly marginal but the lower wing tip looked genuinely in front of the background hill in image A and the stereo effect was much less, if at all, in image B.
Cheers, Tony.
uuglypher
tony brown wrote:
uuglypher wrote:
tony brown wrote:
For me, "A".
Hey, Tony!
Dave
Thanks for your comments, Tony.
The bottom line re: these two image pairs is that the image pairs are identical -as identical as cut-and-paste can make them identical.
The difference?
The difference lies solely in the degree of encroachment of the East margin of the frames to the near wingtips of the two pairs.
When the space between the near wingtip of the left eye image to the frame margin is less than that space in the right eye image, the near wing will appear strongly “thru the frame” (as in pair A)
When that space in the left eye image exceeds the space in 5he right eye image, the whole bird recedes back below the level of the frame. (as in pair B)
Cool, eh?
uuglypher
Wayne Gretzky
