BIF with R5 and RF 100-500mm compared to A9II and FE 200-600 G
Started Jul 4, 2021 | Discussions
Steve W Veteran Member • Posts: 6,998
I'm currently using a Sony A9 and FE 200-600mm f/5.6-6.3 OSS G for BIF work. I am thinking of switching over to a R5 and RF 100-500mm f/4.5-7.1L IS. Originally I didn't consider it because of the slower available aperture of the 100-500 and also the shorter reach of only 500mm vs. 600mm.
Today I woke up and realized that with the A9's 24Mpixel (6000 x 4000) pixel sensor when compared to the R5's 45 Mpixel (8192 x 5464) sensor I can crop my images  by ~1.36x and still get a 24 Mpixel image in post. This makes the 500mm give me the equivalent of 683mm equivalent if I only took out 6000 x 400 images.. So that removed one major barrier and now I know I can get a decent resolution out to 683mm.
The next barrier now though is the slower aperture at the log end of the lens. My calculations say that the Canon's  f/7.1 is only 2/3 of a stop slower than the f/5.6 of the Sony. If that's the case can the R5 deal with the higher ISO needed to make up the difference?
The R5 + RF 100-500 together cost about the same as the the Sony A1 which I am also considering so its not a done deal other than neither the A1 or RF 100-500 are easy to find. There are other plus and minus between the two systems I am also taking in account and trading off. Currently shooting both but realize I am wasting a lot of money but I admit to being a gear head and enjoying the advantages of owning each system.
Please share your thought. Thank you for your time.
Two things are infinite: the universe and human stupidity; and I’m not sure about the universe! - Words to live by. Albert Einstein
 Steve W's gear list:Steve W's gear list
Fujifilm X-E3 Canon EOS R5 Sony a1 Sony a7 IV Sony a7R V +49 more
Canon EOS R5 Canon RF 100-500mm F4.5-7.1L IS USM Sony a1 Sony a9 Sony FE 200-600 F5.6-6.3
(unknown member) Regular Member • Posts: 217
Re: BIF with R5 and RF 100-500mm compared to A9II and FE 200-600 G
I quit worrying about ISO and small apertures after I tried DxO Deep Prime. The Sony would still have an advantage, but not a big enough one to affect my decision.
What would have a major impact is the huge Sony lens size.
https://camerasize.com/compact/#851.910,870.830,ha,t
This past weekend I hiked several trails with 1000 foot elevation increases. Two had steep stone steps and even iron ladders. I would have been curing that Sony lens.
And for me, you may not shoot video, the lack of animal and bird eye AF during video eliminates Sony from my choices.
R2D2 Forum Pro • Posts: 26,531
+1 Canon must have teamed up with DxO this time around.
I too also appreciate the very light weight of this combo on my hikes (mine includes the 1.4x).
And AF acquisition for BIFs (Eye AF with “Auto Initial”) is simply astounding! It’s literally Point and Shoot (no disparagement intended)!
R2
Subutai Forum Member • Posts: 54
I've have used both systems you're considering (have not tried the A1) and IMO the advantages of the R5 with the 100-500 outweigh any disadvantage compared to the A9.  Both systems are excellent and you would get results with either one.  However, the conclusion I came to is that after having used both, the R5 with the 100-500 is a far more versatile setup.
It is lighter, packs smaller, has a significantly better MFD, and honestly, I did not see much difference in the IQ between the two at their maximum apertures.  The A9 is an amazing camera but in comparison to the R5, it's a significantly more purpose focus setup especially with the 200-600.  If all you're using it for is BIF then I'd say its a harder decision, but if you want a camera that can do extremely well for BIF and then so much more, I'd point you at the R5 and the 100-500 without hesitation.
It can do BIF, is easier to carry for hiking/trekking, can do semi-macro, portraiture, etc.
All other accounts I've seen of people who have used both seem to agree for the most part.  Now, if you do BIF, the A9+200-600 is considered better for things that like to fly low to the waterline as the R5 can get confused and bounce back and forth between the waterline, but outside of that, the R5 can handle almost every situation you would likely throw at it and pass with flying colors.
OP Steve W Veteran Member • Posts: 6,998
To all, so far, thank you for your feedback and input. Please keep your comments coming the input is very helpful.  I am definitely focused mostly on BIF but do use my cameras for other things.
Right now I own three full frame cameras with the R5, the A9, and the A7R IV. The R5 I'm using right now for events and general photography. The A7R IV for landscape, architecture, and portraits, and the A9 for BIF and wildlife but when I do the A7R IV is there as well as my backup.
I didn't mention travel and walking around because when I do that I try to take my X-T4 and its smaller primes if I can.  I won't hesitate to take full frame but If I do its a Sony due to its smaller excellent primes like the 35/1.4 GM
So you can see I am all over the map and admit to being a avid gear head. It maybe because I am involved in the design of electronics although I had my first film darkroom when I was in junior high school so an avid photographer for even longer.
Take care please share your experiences further if you can.
MjMac Forum Member • Posts: 77
I have the R5 + RF 100-500. It's a great set up. The only draw backs are the 7.1 at 500mm and the 300mm requirement to use the extenders (you have to zoom the lens out to 300mm to attach the extender). I assume Canon did this to keep the overall size of the lens down. You get used to it, but there are definitely times with BIF when I have the 1.4 extender on and the bird comes in so close that it's impossible to keep it in the frame. Being able to zoom back passed 300mm would be nice in those situations.
I also have the A9 and 200-600. This is a good combo. I would say personally that the Canon R5 and RF 100-500 combo produces better images. The AF is great in the A9 and 200-600, but's it's even better with the R5 and 100-500. You do gain extra reach and the 2/3 stop difference you already mentioned when using the A9 and 200-600. But since I've purchased the R5 and 100-500 I don't use the Sony setup any more.
If you are considering the Alpha 1 and 200-600 that's an entirely different story. I do not have the Alpha 1, but I've seen it in action and the AF is every bit as good as the R5. The one issue I have heard is that the 200-600 doesn't have the resolving power to really take full advantage of the Alpha 1 sensor. I'm not sure if this is mostly anecdotal, or if there is data to back this claim up or not.
One other thing to consider is the 200-600 is a G lens, and not a GM lens, while the Canon is an L lens.
Georgeee
Georgeee Contributing Member • Posts: 796
Sony 200-600 is a great lens on my A7rIII . I love its internal zooming is so  smooth. IQ is great. I wish Canon had a lens like that. The lens is a main reason  that I keep a Sonly body.
I also have R5 with adapted 100-400II + 1.4xIII, AF is faster than my a7rIII for sure
 Georgeee's gear list:Georgeee's gear list
Canon EF 70-200mm F2.8L IS II USM Canon EF 16-35mm F4L IS USM Canon EF 100-400mm F4.5-5.6L IS II Sony a7R III Canon EOS R5 +6 more
duncang Contributing Member • Posts: 960
I have a9, a1 and 200-600 and recently used the R5 100-500.  Some observations when compared to A1.
R5 combo seems to have more saturated colours and slightly better contrast and maybe a bit sharper.  Colours seem quite a bit easier to work with in post.  Contrasts/sharpness is pretty marginal at best.
R5 animal/bird af is excellent but the a1 tracking seems to be better with slightly fewer misses when shooting bif.  Both over 90% so pretty marginal and obviously 30% more frames to choose from for A1.
200-600 is not really 600 so actual reach difference is not so much.  However Both a9 and a1 work extremely well with the TC1.4 at 840mm.  R5/100-500 at 700 maybe not so much.
200-600 does not extend, quite a bit heavier and has nice short zoom throw.  100-500 on the other hand is super light and more flexible with 100-200 range for landscape, self video etc.
So when considering R5 I would think about it vs A1. But no contest when compared to A9 or A9ii.  They can't compete with the AF system or lack of megapixels.  In video mode none of the Sony's can compare with the Canon for animal/bird af tracking - they don't have it at all.
BigBen08 Veteran Member • Posts: 7,472
Your last sentence concerns me, as I'm considering the 100-500 and 200-600 for fast moving subjects (aircraft).
Do you have an opinion as why the Sony combo autofocuses slower than the Canon? Is it the a7rIII  or the lens itself. Would another camera body make a difference? Maybe I'm asking questions you can't answer.
My best aviation photos: https://500px.com/kenfm2018
French Fry Regular Member • Posts: 196
In my experience with the Sony A9 and A7RIV, the A9 focused considerably faster than the A7RIV. If you are photographing fast-moving subjects, you may want to consider a body that is better for fast moving subjects, like the A9II, A1, and R5.
I plan on renting the 200-600 and 100-500 for testing (I have started a thread on the subject). Have to find a Sony camera to go with the lens. So your comments help, thanks.
Georgeee
A7rIII is a couple of years older than the R5, so the AF is slower. but A7rIII is not too bad.
I have seen people shot A1 with the lens, the AF is super
I will keep the 200-600mm for the foreseeable  future and upgrade to a new A1 or A7rV (rumored) next year
I honestly did not notice much of  a difference in autofocus speed between the A9 / 200-600 vs. the R5 / 100-500.  The R5 was better in the sense that it has a much better animal eye focus than the A9 but the A9 is better in that it is truly blackout free.  The R5 has a slideshow effect when you release the shutter and press again, but is blackout free AFTER the initial shutter press.
The main thing I did notice between the two is that the 200-600 is an absolute monster in size/weight when compared directly to the 100-500.  I was shocked at how big the 200-600 is compared to the 100-500.
The 100-500 is definitely something I could hike with and take long scenic walks with without any concern whatsoever.  I'm specifically not buying the 200-600 because it is too large for my uses which is long walks and hikes.
Now compared to bigger super telephoto lenses, the 200-600 is much smaller and portable but compared to the 100-500, the 1-500 is much more portable.
arbitrage Contributing Member • Posts: 585
11
I own or have owned the A9, A9II, A1 and R5.  I own the 200-600 and owned the 100-500.
They are both excellent systems/combinations.  It is a hard choice between them.
You are correct in that the resolution of the R5 will help make up for the loss of 100mm.  However, one thing to keep in mind is you are comparing 24MP worth of nice big FF pixels on the A9 to 24MP of smaller pixels after cropping the R5.  I believe that the 24MP FF A9 image is nicer compared to the 24MP cropped R5 image. I don't know how much that really matters but may matter in lower light, higher ISO situations.
You mention a difference of 2/3 stop but at the long end it is only a difference of 1/3 stop (6.3 v 7.1) so not too significant.
I think you are aware of the main differnces between the two lenses.  One is larger and heavier.  The other can focus closer for semi-macro and is smaller and lighter.  The 200-600 has much smoother and shorter zoom throw.  If you do any shooting where you zoom back to acquire and then quickly zoom in to 600 to shoot the 200-600 is so much better.  The 100-500 is stiff and a long throw.  I found the tension ring to be too loose at the tight end and not loose enough at the loose end.  I have the same opinion with all the 100-400 type lenses I've owned including the Sony 100-400 and Canon 100-400II.
As far as AF goes, the big attraction of the R5 is the Bird Eye-AF.  However, I found that to be most advantageous for perched or floating birds.  For BIF it does activate sometimes but I didn't find it any better than using my favorite Zone or Wide modes (non-tracking) for BIF on the A9.
My feeling is that the A9/A1 still has better AF than the R5 for very fast reactions to a fleeting, fast BIF that comes out of nowhere.  I found the A9 to be a bit more sticky on the BIF if it started to track it properly.  I found the R5 to be a little more likely to jump off the bird and grab distracting water or backgrounds.  That said, I think the R5 is excellent AF for BIF and will get you a high keeper rate.
For non-BIF I found the R5 superior because of the Eye-AF.  Of course now that I have the A1 I have Eye-AF that is almost on par with the R5.  I find the R5 picks up eyes with BIF more often than the A1.  The A1 requires very smooth panning to see eye-AF show up for BIF...but I've had it show up even for swallows IF so it is possible.  The R5 recognizes body and head shapes early on and when the bird is in weird poses.  The A1 seems to require the bird to be in a more normal pose and really doesn't have body/head detect.  I find that once the bird is in a pose that you'd actually want to push the shutter, both A1 and R5 are equally effective for Eye-AF working.
I decided to sell my R5/100-500 kit to pay for the A1.  This was mostly because I had a better investment in Sony lenses and liked the 200-600 more than the 100-500.  So I sold my entire RF kit, bought the A1 and now shoot it with the 200-600 and 600GM.  I repurchased a Sony 100-400 which I had sold when I bought the RF 100-500.  If I had still owned some of my larger EF Canon superteles I might have gone the other way.
 arbitrage's gear list:arbitrage's gear list
Canon EOS 450D Nikon D500 Nikon Z50 Sony a1 Canon EF 100mm F2.8L Macro IS USM +15 more
For walking around/hiking I take my excellent FE 100-400 mm f/4.5-5.6 with 1.4x teleconverter instead of the 200-600. It’s very sharp, and focuses even faster IMHO. It is one of the Sony GM lenses that convinced me to sell my Canon version and get the A9 three years ago.
Still want to try the Canon RF 100-500 but can’t seem to find one.
Thank you for sharing your experience. I’ve also considered selling my full RF kit and buying the A1 like you have. For primes from 14 to 135 I am all Sony GM with the 20/1.8 and 90/2.8  Gs.
(unknown member) Junior Member • Posts: 28
I wonder about this.  I've read through many reviews, watched many videos, and read any posts.  The R5 and A1 appear to be very close, but while a few have said the R5 AF is better, no one has said the A1 is overall better.  In fact, I've read A1 owners wish its AF worked more like the R5 without having to switch better eye detect modes depending on subject.  And others wished eye detect worked during video.  And still others say the A1 does not hold focus as well when the subject moves to the edge of the frame (A1 only has ~90% coverage and no AF points on the edges of the frame).  To be fair some have said the A1 AF is stickier and holds focus better (but others say with the right tweaks the R5 is as good or better).
I release the A1 has the stacked sensor, but overall the R5 seems to be as good and in some ways better than the A1 but a price $3000 lower.  I don't count IBIS on the R5 as being better though, they both look very good.
If it were me, I'd get the R5 a couple RF lenses and some tried and true EF lenses, the ones said to work as well as mirrorless lenses.   I think I'd have several thousand left over compared to the Sony. Maybe enough for a used 600/4.
JackiePan Regular Member • Posts: 136
I used my friend's RF100-500 for one week,  as he wanted to try my 600MM F4.
RF 100-500 with R5, is really a good combination, no doubt about IQ or AF speed. because of its low weight, i can handheld for a very long time.
I go birding every day and i found for most handheld birders, earlier Sony A9+200-600 and Nikon D500+500pf are very common, now i can find Canon R5+100-500.
 JackiePan's gear list:JackiePan's gear list
Canon EOS-1D X Canon EOS 5D Mark III Canon EOS-1D X Mark II Sony a7R III Canon EOS R5 +5 more
I agree.
I don't see them as being so drastically far apart in AF that the A1 justifies the extra $3000 unless there's a specific scenario (such as Arbitrage's) that warrants it and even then, it'd have to be a pretty significant improvement.
If you like the Sony ecosystem, then yeah, the A1 is the only option for high mega pixel and best in class AF... but it comes at a hefty price, but I guess that's relative to each person's pocket book.
As I've heard it said in another forum, "Sony did something that they likely did not want to with the A1 and that's make the R5 look like a bargain."
Subutai wrote:
I agree.
The higher cost of the A1 has been holding me back even though if I never bought back into the Canon RF system I could have had the money to just buy the body and battery grip. Can also afford it if I sell of thyme RF kit.  I bought my R5 though befor the A1 was announced.
So today I’m still trying to decide what to do. Lurking in the back of my mind is also the potential of the teased EOS R3. Canon knew what the were doing when the leaked it a few months after the A1 was announced. waiting at this point to hear more about that camera.
Is it possible that Sony would consider an A9 III? A new 30-36 Mpixels sports / wildlife at maybe $4500. It would be a great response to Canon going up market with the R3 to go down market and challenge the R5.
