How should I configure unequal RAM?
MacroDonata
MacroDonata Regular Member • Posts: 260
I was under the impression that slots 1&2 should be used for the higher capacity sets and 3&4 for the lower.
However, I found this verbiage on the apple support page:
"If your DIMMs are mixed in capacity, minimize the capacity difference between Channel A (slots 1 and 2) and Channel B (slots 3 and 4) when possible."
If I am reading that correctly, the slots should be ordered as 1-big, 2-small, 3-big, 4-small.  That would equalize the two channels.
When I look at "Memory" on the "About this Mac" function, should the larger capacity DIMMs both be at the top?
Not a big deal to rearrange if needed, but I thought I'd check here first.
Thanks.
 MacroDonata's gear list:MacroDonata's gear list
Ricoh GR II Sony RX100 V Sony SLT-A65 Sony a77 II Panasonic Lumix DMC-GM5 +23 more
Leon Wittwer Forum Pro • Posts: 13,526
Re: How should I configure unequal RAM?
I would guess that each pair of shots should have equal sized memory cards.  That has been my experience in other Mac products where the memory shots come in pairs.  I don't know anything about using a single slot in a pair.
tsinsf Contributing Member • Posts: 848
Why would you believe a stranger on the internet rather than the Apple support page? If it were me, I would follow their advice and see if their are any problems. You can always switch later.
 tsinsf's gear list:tsinsf's gear list
Canon EOS 5D Mark IV
(unknown member) Regular Member • Posts: 264
You likely have a 2020 iMac? Those require paired DIMMs. Slots 1/3 and 2/4 are paired. Apple is 100% correct as they should be. Be aware, though, that mixing capacities and even brands in this manner will result in your RAM speed being throttled.
MacroDonata
OP MacroDonata Regular Member • Posts: 260
I am simply trying to confirm my understanding of the verbiage on the Apple support page.
The sentence following the Apple quote shows how I think they mean for it to be configured.
People on this thread tend to be pretty knowledgeable, so I thought it made sense to see if they agreed with my assessment.
MacroDonata
Thanks for your reply.
It is a 2017 model 18,3.
They are OWC DIMMs designed specifically for that model.
Thanks.
jeffnles1 Senior Member • Posts: 1,756
I read that a little differently.  Say you have 2 32gb memory cards and 2 16gb memory cards.
Bank A
32 / 32
Bank B
16 / 16
 jeffnles1's gear list:jeffnles1's gear list
Nikon D7200 Nikon D500 Nikon AF-S DX Micro-Nikkor 85mm f/3.5G ED VR Nikon AF-S Micro-Nikkor 105mm F2.8G IF-ED VR Sigma 1.4x EX DG Tele Converter +5 more
MacroDonata
OWC clarified it.
When I posted this question last night, OWC cust service was closed and I didn't feel like getting Apple support on the phone.  I was looking to make sure I understood the Apple support page before I reconfigured the RAM.
Spoke to OWC a couple of hours ago and they confirmed that the different sizes should be stacked intermittenly in the slots.  Either Small/Big/Small/Big or Big/Small/Big/Small.
Thanks for your helpful responses.
