Note of Caution / Information re GFX 100 V4 firmware update
Rand 47
Rand 47 Senior Member • Posts: 1,467
Just updated my GFX 100 successfully, BUT.
Be aware that it “may” put your camera in P mode (Program mode) during the update.
A friend of mine (David Brookover) has two GFX 100 bodies, and it did it to both of his.
I just updated mine and it did it to mine, as well.
Easy enough to hit the shooting mode button to put back to your preferred mode, but David and I were both a bit flummoxed, wondering if something more serious was amiss.
Rand
cortex95x Contributing Member • Posts: 718
Re: Note of Caution / Information re GFX 100 V4 firmware update
Rand
Hi Rand,
I had the same experience, and noted that many of my settings had been changed to factory default.
Rand 47
OP Rand 47 Senior Member • Posts: 1,467
Rand
Hi Rand,
Hi,
I don’t use the Custom Settings, but it did reset my Q menu to factory default.  All my other settings, from the main menus, were left intact.  It also doesn’t seem to “default” to the MY MENU when you press the the OK/Menu button.  The behavior seems to have been changed to go to “where you last were” as opposed to MY MENU.   I don’t like it, but I can understand why they did it.
Rand
Bipin Prag Regular Member • Posts: 182
Yep, I had to reset everything
Rand 47
Anecdote:
Another friend with GFX 100 & V4.  He could not focus, either manual, AF or back-button MF after update and was "fine" just before update.  We messed around confirming all the proper menu settings.  Pulled batteries out of camera, etc.   Finally turned camera off, took lens off (32-64), put lens back on.  Voila!  It works again.
Rand
