Weird effect on XF 18-55 2.8-4 Lens
Started Jun 30, 2021 | Discussions
davidmorillacabello New Member • Posts: 13
Hello everyone. I posted a long time ago regarding some issues that I could find sometimes with my lens (out of warranty). Today I made the propper testing comparing it with a brand new from the store. I would like you to see the results for a proper diagnosis and possible solutions. The first picture was taken with my lens, the second with a brand new and the third with my lens and IS turned off. All the pictures were taken: 1/1600s, 55mm, f4, ISO 200, automatic focus and focus point is the furthest sign which says "Museo Picasso". It is weird for me that the focus point is completely blurred while the "Le Courtois" sign is somehow more focused. In the brand new lense, everything looks as expected and perfectly sharp. This effect is stronger with this specific conditions: strong and one bounced light and it is less noticeable in controlled environments (charts and home or shades). My theory is that it could be due to decentering. However, I am not completely sure (the decentered chart did not show clear problems) and might need some experts opinion.
GKN Contributing Member • Posts: 568
Re: Weird effect on XF 18-55 2.8-4 Lens
I have a similar effect, but it only happens occasionally …. Never have got to the bottom of it. I’m using mine on an XT2 and was wondering if it was an AF issue, but more likely a lens issue. I must find the time one day to see if I can reproduce and see if is only at certain aperture or certain shutter speed, or IS related. It does seem to be an issue at 55mm … haven’t seen it at wider focal lengths. Thanks for your post, seems I’m not the only one with this issue …
 GKN's gear list:GKN's gear list
Fujifilm X-T2 Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 10-24mm F4 R OIS Fujifilm 50mm F2 R WR +1 more
OP davidmorillacabello New Member • Posts: 13
I found that it is more related to light nature more than anything (strong and one bounce. During sunset or photographing trees, bushes and plants). Of course, closer apertures diminished it to the point that it is hardly noticeable at f9. However, it is a clear problem by comparison with a different lens of the same model.
pifilos Regular Member • Posts: 343
I have seen couple more posts that show the exact same issue during my 1.5 year in this forum but if I recall correctly that happened after the lens was dropped (on one of the cases at least). Did it start to happen randomly or was it after any impactful incident ?
btw I remember your older post with the beach scenes.
 pifilos's gear list:pifilos's gear list
Fujifilm X-T2 Fujifilm X-T20 Fujifilm 50-230mm II Fujifilm XF 10-24mm F4 R OIS WR Fujifilm XF 33mm F1.4 R LM WR +1 more
I am not sure since I can't recall when I started noticing it. I guess that yes, it might have been a fall. Now I am moving to Switzerland and will probably try Fuji's customer's service there in case that there is any chance of repairment. Thanks for following up on the discussion! Any experience or old post that you could share on these experiences would be nice.
Nicolas Det New Member • Posts: 1
Does your lens have the latest firmware ?
maltmoose Veteran Member • Posts: 3,050
Love hate with lens. Certainly update the firmware  before going any further as that fixes a couple of bugs.
I highly recommend you test by using manual focus. If it cant get sharp on what you focus your lens is duff.
I also recommend using electronic shutter with this lens as i seem to get a higher rate of sharp photos. Turning ios on and off was inconclusive for me.
Imo opinion fuji AF is flakey and sometimes just takes out of focus photos, its like it cant af on a low contrast subject and just takes it anyway, my other systems do not do this.
This lens appears to have even less reliable AF compared to primes like the 50 f2. Certainly at wide end wide open its a lottery.
The lens also has a lot of distortion which can affect sharpness acros the field.
All that said its possibly the best fuji lens due to its cost, size weight,range, aperature. I wish they would redesign a modern improved version 2 though.
Ive got some great photos im happy with and ive mostly settled on using electronic shutter and the tiny pin point AF point for most reliable results.
Rightsaidfred
Rightsaidfred Senior Member • Posts: 2,179
Occasionally
I think GKN you found the right words. Same here. Very occasionally. No real explanation. Hypothesis is that it has to to sth with OIS/floating lens elements. Not sure.
Look at this one. It is nowhere really sharp. Focus was on the ice cracks.
X-T20, XF 18-55, 55 mm, 1/640 s, f/5.6, ISO 200
Otherwise the XF 18-55 is a great lens and I have tack sharp photos with it.
I recently went for the famous XF 16-55 and I haven't encountered such an issued so far; all my photos are satisfactory in terms if IQ (the man behind the lens is the limiting factor). That lens obviously has no OIS. It is heavy and - hypothesis - mitigates possible shutter shock through its mass inertia.
BR,
Martin
 Rightsaidfred's gear list:Rightsaidfred's gear list
Fujifilm X-T20 Fujifilm X-T4 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS +5 more
Rightsaidfred
Simple and effective decentering test
And if you suspect your lens is decentered, I recommend this simple and effective test:
https://www.dpreview.com/forums/post/63756500
Since I "discovered" it, I do it with every purchase.
My opinion: forget all the star charts. This one is easier, quicker and more effective.
Kind regards,
Martin
i updated to the latest firmware and it didn’t resolve it. An earlier firmware did list something like this as an issue addressed…… but it still causes occasional grief for me. I have noticed parts of the image as sharp (foreground), while the background which was focused on, is out of focus. This happened without ever being dropped.
