Underwater Infrared or Ultraviolet Photography
Started Jun 29, 2021 | Questions
Dann-Oh Contributing Member • Posts: 894
Does anyone know if the full spectrum or ultraviolet camera conversions will work for underwater photography?  I know there is a technique where one can use a UV light and "excitation filters" (article link).  would the conversions make the excitation filters useless? would I still need the uv lights?
I take photos, not particularly good photos, mostly abstract photos. Yeah abstract is what I would call them, you might call them blurry.
 Dann-Oh's gear list:Dann-Oh's gear list
Olympus E-M5 III Olympus E-PL10 Olympus E-M1 III Olympus M.Zuiko Digital ED 9-18mm F4.0-5.6 Panasonic Lumix G Fisheye 8mm F3.5 +20 more
petrochemist Veteran Member • Posts: 3,619
Re: Underwater Infrared or Ultraviolet Photography
Both IR & shorter wavelength UV get blocked fairly quickly by water, but local lighting can still be used to some extent for either UV or IR. Longer wavelength UV will travel a moderate way through water possibly enough for UV induced fluorescence (UVIF) which seems to be what you are referring to.
UV fluorescence is usually best shot with a normal camera. The UV light excites the subject which then emits some of the energy gained as visual light. UV or sometimes just blue light is needed to excite the compounds involved the excitation filters then block the wavelengths used for excitation so you see only the longer wavelength light given off by the fluorescence. If you have a UV lamp it's relatively easy to try UVIF out of the water, some flowers work but subjects like plain white (or dayglow) paper/fabric usually fluoresce nicely.
 petrochemist's gear list:petrochemist's gear list
Pentax K100D Sigma SD14 Pentax K-7 Panasonic Lumix DMC-GF2 Pentax Q +19 more
