how to firmware update now?
Started Jun 29, 2021 | Questions
kev-xkq New Member • Posts: 12
l have a 50-200mm(version 3) and want to update it to firmware 1.11 but find no way to do it. i-launcher seems to stop working and I can't open the official website. Does anyone knows how to update now?
 kev-xkq's gear list:kev-xkq's gear list
Samsung NX 30mm F2 Pancake Samsung NX 50-200mm F4-5.6 OIS Samsung NX 10mm F3.5 Fisheye Samsung 16-50mm F3.5-5.6 power zoom
Wahid Khan 1961 Regular Member • Posts: 179
Re: how to firmware update now?
I've never used i-launcher. I get all my firmware updates from this excellent resource;
https://matteverglade.com/lenses/nx-firmware/
The firmware often comes as a compressed file, un-pack it first before copying the 'bin' file on the 'root' of your memory card. Beware, they look very similar, make sure you have one and only one 'bin' file on you memory card at any one time. Also make sure it's the correct one. You don't want to 'brick, the camera or the lens. I delete my 'bin' file as soon as I've updated. When you go via the menu to update the firmware, the camera will recognise if you have a newer version of the firmware and will ask if you want to update. Make sure you have a fully charged battery before proceeding.
It really is very simple, don't be put off by my long-winded explanation.
Hope this helps.
 Wahid Khan 1961's gear list:Wahid Khan 1961's gear list
Samsung NX10 Pentax K-5 Samsung NX1000 Samsung NX20 Samsung NX1100 +32 more
markyboy81 Veteran Member • Posts: 4,778
Hope this helps.
Wahid, how do you download the files? If I click on the link all I get is this;
 markyboy81's gear list:markyboy81's gear list
Sony ZV-1 Samsung NX1000 Samsung NX3000 Samsung NX1 Samsung NX500 +9 more
kypfer Contributing Member • Posts: 985
Just out of interest, I copied the url given for the 18-55mm OIS into the "Wayback Machine" http://web.archive.org/ and, after a re-direction, was given a zipped .bin file, so the files would seem to be still available!
The .bin was copied to my SD card and now my lens has new firmware
Good luck
 kypfer's gear list:kypfer's gear list
Pentax *ist D Pentax *ist DS Pentax *ist DL2 Pentax K200D Samsung NX5 +7 more
Good luck
That's amazing! I'm bookmarking the wayback machine! Thanks for the tip!
Hope this helps.
Sorry for late response, you may well have a solution via kypfer. However, for the record, you would normally click on the red firmware version and a download would start. I've just checked it and it no longer works. Either that resource is no more or my latest version of Firefox is playing up. I've always kept all the firmware updates from that page anyway, they are very small and don't take up much space so I could forward one if I have it.
OP kev-xkq New Member • Posts: 12
