RICOH GR III OVERHEATING
Started Jun 28, 2021 | Questions
GR63 New Member • Posts: 3
I have had the camera for 6 months now and I have a problem on screen a notification says that the camera is closed because it might be damaged
It is overheating and shuts down, and it happens even with an original battery...
Maybe it's dust... I don't know.
Thank you
Ricoh GR III
doceyes Regular Member • Posts: 165
Re: RICOH GR III OVERHEATING
As discussed on this forum and in the past.....is the camera left on all the time or do you turn it off and on when shooting, or you have it set to shut off automatically  after a preset time. If it is set to the last 2 then you may need to send it back, but others can probably tell you better. If it is on all the time, then try setting it so it shuts down automatically.
 doceyes's gear list:doceyes's gear list
Pentax 645D Samsung NX1 Samsung NX500 Pentax K-1
sae1lin2aug3
sae1lin2aug3 Senior Member • Posts: 2,095
That's a very BAD issue with the GR111.
# 1 reason it's no buy for me.
"Think Different." S. J.
telemach Contributing Member • Posts: 696
it's a feature not a bug
OP GR63 New Member • Posts: 3
hi friends
I turn it off and on when shooting..not in every click but I use to...on and off
I almost never filming with the camera, just take a lot of photos, I use an original battery and two from Newnowa every day First,
There is either a small thermometer (red) on the screen and then a message that the camera holds itself out so that nothing is further damaged will .... or without the thermometer icon, only the message comes.
I have had the batteries for 6 months like the camera and when taking photos (the camera is so very fast) I turn it off often, but it can happen that I can do 30-50 cliks at once without switching the camera off
Tungsten Nordstein
Tungsten Nordstein Veteran Member • Posts: 3,182
Thank you
It's probably faulty. Have you been in contact with Ricoh or the shop you purchased from. I think you should return it.
 Tungsten Nordstein's gear list:Tungsten Nordstein's gear list
Ricoh Caplio GX100 Ricoh GR Digital Ricoh GR Digital IV Sigma dp2 Quattro Ricoh GR II +8 more
BTW, as some have posted elsewhere, does the camera have the latest firmware? If not I would do it and see if it makes a difference. If no difference and it is under warranty the time to return it for repairs.
