X-E3 - Images overexposed - Is something wrong with the camera or am i doing something wrong ?
Started Jun 21, 2021 | Questions
Samuraidog Senior Member • Posts: 1,672
Re: X-E3 - Images overexposed - Is something wrong with the camera or am i doing something wrong ?
Erik Baumgartner wrote:
Does it do this with both the mechanical and electronic shutters?
This is what I was going to say.
An easy thing to test, which may narrow things down a bit.
 Samuraidog's gear list:Samuraidog's gear list
Fujifilm X-T30 Fujifilm X-H2S Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 +13 more
a_c_skinner Forum Pro • Posts: 13,047
I think Fuji will detect water damage and decline to repair.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
robert1955 Veteran Member • Posts: 7,299
Saw this in a Roger Cicala blog: no self respecting repair shop will touch once they see water damage. They might be able to repair something, but can not warranty it will stick
baobob
baobob Forum Pro • Posts: 18,248
This is most likely while obviously thecamera and the sensor works, a shift of 1.5 EV being after all a minor problem
Now why not use this camera with a permanent EV correction ?
In PS I have corrected the file (JPEG) in a second !
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
Or on manual.  But I'd not trust the camera to continue to work, esp. if it was salt water.  Corrosion is, well, corrosive.
Andrew Skinner
A_Mist
A_Mist Contributing Member • Posts: 988
a_c_skinner wrote:
The OP has said it was a wave splash. It is almost certainly beyond economic repair. Worth considering but I'd not be hopeful.
Never ever would buy a camera that’s already partly broken from wave splash, but that’s just me.
 A_Mist's gear list:A_Mist's gear list
OM-1 Canon EOS R6 Mark II Olympus 12-100mm F4.0 Canon RF 50mm F1.2L USM Canon RF 24-105mm F4L IS USM +4 more
baobob
A 1 month observation period. Again I'm not too pessimistic the files are ok in PS and easily corrected.
Anyway as you stated, nobody will seriously repair it, if it lasts the issue is minor
Bob
baobob
One hypothesis.. and the pilow case tip.....
If we imagine that some humidity is still present in the body that could explain for the erratic overexposure.... (different from one shot to the other)
Put the camera without lens in the bottom of a pilow case take a hair dryer set to the first t° (mild heating) then warm the pilowcase from its opening  with the hair dryer for a while avoiding exceeding say 35°C leave the camera cooling down and try
If this did not worked, an idea to save your 150$ investment would be to use the camera with a permanent -2 or -3 EV correction, plus if needed the addition of a ND filter a rather cheap solution
Good luck for the future of this odd camera
DarnGoodPhotos Forum Pro • Posts: 11,881
Does the issue still exist when setting the Exp Comp dial to -1 or with an ND filter? If you don't have an ND, try shooting through sunglasses.
www.darngoodphotos.com
 DarnGoodPhotos's gear list:DarnGoodPhotos's gear list
Fujifilm X100V Fujifilm X-T5 Fujifilm XF 18mm F2 R Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 27mm F2.8 +3 more
Threaded Veteran Member • Posts: 4,180
Good call, my money’s on the shutter and this would be a perfect test. Also, if the shutter is fried and can’t be repaired, it might still be useful as an e-shutter only body going forward, but best to discover that now before the shutter fails entirely and locks the camera up.
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
RetiringGuy Contributing Member • Posts: 576
Out of interest - does a RAW file show the same overexposure as its associated out of camera jpeg?
RG
baobob
Good question indeed...
SVJIM Senior Member • Posts: 1,758
Yes, are the RAW files effective and lets not forget about using the electronic shutter. If the electronic shutter works, I suspect it would be a safe bet that the problem is mechanical. If the electronic shutter does not work, you are looking at something other than a mechanical defect.
Photography should be fun
http://www.TouchingMemories.com
 SVJIM's gear list:SVJIM's gear list
Fujifilm X-T3 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 27mm F2.8 Fujifilm XF 18-135mm F3.5-5.6 R LM OIS WR Fujifilm 50-230mm II
OP Fxt1 New Member • Posts: 8
Hello,
Thank you all very much for your guesses, inputs ideas and advice !
I'll have my hands on the camera tomorrow, i'll try the raw files and check if the issue persists on both mecanical and electronic shutter
i'll upload the files of course
As I said, i bought the camera knowing it was basically sold for parts, so given the amount i paid for it, i'm more than happy with what i got
Thank you again !
moinmiami Regular Member • Posts: 100
Fxt1 wrote:
Hello,
Thank you again !
Wanted to add that I experience the same thing with an x-e1 I bought used recently. But it only happens sometimes.
And the jpeg is very washed out. The raw file i can bring back to 'normal' exposure with one click of 'auto' in Lightroom. But the raw file is initially washed out too.
Here's a screen shot of my lightroom library. First two images upper left are inside the train station. When I walk outside, bam, blown out images. I tried readjusting exposure, meter reading you know, spot, average etc. Nothing fixed it. I had to find a spot with less light, much less, and the camera seems to re-adjust itself and all good from there. Weird.
This said. It's my first experience with fuji ilc. Bought a used 27mm lens for it. I'm really enjoying using the camera. One other thing not related to exposure. Focus can be hit or miss. I'm used to more modern bodies that are fast and nearly always hit focus where I want.
My first fuji? An F30 way back when.
