X-E3 - Images overexposed - Is something wrong with the camera or am i doing something wrong ?
Started Jun 21, 2021 | Questions
Fxt1 New Member • Posts: 8
Hello,
I just got an X-E3, I bought it for a very cheap price, the seller told me something was wrong with the joystick, it doesn't go down, and left direction is faulty sometimes.
But the real issue, it seems, is that images are over exposed, or rather burnt.
Even if i put the camera and lens (xf 35mm) in automatic setting/position.
I'm discovering the Fuji way of doing things so i'm not sure if the problem comes from the camera or maybe i'm just doing things the wrong way.
When i half-press the shutter button, the 'preview' looks ok on the lcd screen or the viewfinder, but when the photo is taken, it's looks way over exposed.
I inserted a few examples.
Any ideas / advice are welcome
Thank you
Erik Baumgartner Senior Member • Posts: 6,893
Re: X-E3 - Images overexposed - Is something wrong with the camera or am i doing something wrong ?
6
It would be helpful to have the full jpeg with the exif data intact. Are you in bright light with the aperture wide open? If so, make sure the electronic shutter is enabled (MS+ES), the MS might be maxed out at 1/4000”.
Sony RX100 Fujifilm X100V Fujifilm X-T2 Fujifilm X-T20 Fujifilm XF 35mm F1.4 R +5 more
FTOG Senior Member • Posts: 1,359
7
The EXIFs might certainly help to identify potential causes:
  • fastest possible mechanical shutter speed
  • exposure compensation dial knocked out off neutral (happens to me all the time on my X-E3s, taking them out the bag)
  • spot metering on the wrong area in the frame
  • accidental exposure lock (AE-L)
  • accidental manual shutter speed rather than A
 FTOG's gear list:FTOG's gear list
Fujifilm X-E3 Fujifilm XF 14mm F2.8 R Fujifilm XF 23mm F2 R WR Fujifilm 50mm F2 R WR Fujifilm XF 27mm F2.8 R WR +2 more
jhorse Veteran Member • Posts: 5,913
6
Hi, the XE3 is a great camera. I agree with others that the image data may have a story to tell. I think I would start by doing a full reset back to the factory default settings (manual Page 209), then put it into full Auto Mode using the top lever (Page 7), and see what happens.  If the image is normal, that could indicate a rogue setting. If the image is still over exposed, that would be more troubling and could indicate a fault.
Anyway, worth a try. Good luck.
 jhorse's gear list:jhorse's gear list
Fujifilm X-E4 Fujifilm X-T5 Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 55-200mm F3.5-4.8 R LM OIS Fujifilm XF 10-24mm F4 R OIS +6 more
Ad12 Senior Member • Posts: 1,514
Fxt1 wrote:
Hello,
Thank you
Are these out of camera JPGs?
 Ad12's gear list:Ad12's gear list
Nikon D500 Nikon Z6 Sigma 150-600mm F5-6.3 | C Sigma 100-400mm F5-6.3 Nikon Z 24-70mm F4
A good list, anyone of these could be the culprit.
baobob
baobob Forum Pro • Posts: 18,248
Be sure light mesure is correctly set same for ISO (low enough in bright sun
Check for all settings to avoid an unwanted config.
Some lenses might need an EV correction but only about +- 1 to 1.5 EV
Sony RX100 Panasonic ZS200 Fujifilm X-H2S Fujifilm X-H2 Fujifilm XF 35mm F1.4 R +16 more
OP Fxt1 New Member • Posts: 8
Hello everyone, thank you all for your replies and your time.
Since file sizes were pretty big, i resized the previous photo examples, which removed the exif metadata.
Here are some other examples with exif info.
i tried taking similar pictures with the x-e3 and an X-T1 using the XF 18-55mm and evrything set to AUTO and exposure compensation set to neutral on both cameras.
Precision : following @jhorse's advice, i did a full reset back to factory settings of the x-e3 before taking the examples below.
I didn't pay attention, the X-T1's date is set to 2014 but that doesn't matter much.
Thanks again to everyone
X-E3
X-E3
X-T1 (room was quite dark, so the x-t1 lighting is closer to reality than the x-e3 example above.
X-E3
Same photo with X-T1
Doug MacMillan Veteran Member • Posts: 3,695
Good advice here.
I'd also check to make sure it has the latest firmware.
The fact that the joystick doesn't work correctly is worrying.
 Doug MacMillan's gear list:Doug MacMillan's gear list
Canon EOS 5D Mark II Fujifilm X-E1 Fujifilm X-E2S Fujifilm X-E3 Fujifilm X-H1 +10 more
baobob
I have sorted the 2 files in PS to get the histograms
they show cleraly the overexposure of about 1.5EV according to PS
Is the camera new or used ? It seems it needs calibration since now we know that there is no wrong setting
Re: Good advice here.
Yep, you're right, it was on 1.22
I ran the update to 1.3 after your message but images are still very bright.
As for the joystick, the seller warned me about it. he said only the up direction works flawlessly. turns out up and right work perfectly, left is ok 90% of the time, and down seems dead.
It had to do with a wave splash.
He was selling it pretty much for parts, so i bought it without expecting much to be honest (150 USD)
With exposure compensation, i can trick the camera and get decent images, but it's a guess game with every shot.
Threaded Veteran Member • Posts: 4,180
What’s curious is that these two horse images are taken with the exact same shutter, aperture and ISO values (according to the EXIF of each), so for them in reality to be 1.5 stops out is rather alarming. It’s quite conceivable the two sensor generations may vary slightly at any given ISO but surely not to that extent.
I’m assuming that the same 18-55 lens is in use with each camera, which takes aperture out of the equation. Is it possible that the XE3’s shutter is running too slow?
 Threaded's gear list:Threaded's gear list
Fujifilm X-Pro3 Fujifilm X-E1 Fujifilm XF 35mm F1.4 R Fujifilm XF 18-55mm F2.8-4 R LM OIS Fujifilm XF 23mm F2 R WR
Thank you very much,
The camera is used, i gave some details on my previous post.
Could you point me at some step by step calibration guide ?
Thank you
baobob
IMO a repair center should be able to do that easily provideed the sensor is in good condition
1.5 stops is not so huge
Does it do this with both the mechanical and electronic shutters?
A repair centre might be a good next step. Considering the equal settings, I wonder if it's a faulty mechanical shutter. If it's slower than nominal, that would lead to a relative overexposure, despite correct metering and correctly shown nominal shutter speed. But that's just guessing at my end.
a_c_skinner Forum Pro • Posts: 13,047
The OP has said it was a wave splash.  It is almost certainly beyond economic repair.  Worth considering but I'd not be hopeful.
Andrew Skinner
Fujifilm X-T2 Fujifilm X-E3 Fujifilm X-H2 Fujifilm XF 35mm F1.4 R Fujifilm XF 14mm F2.8 R +7 more
Water Damaged Camera
You might as well quit guessing.  The OP picked it up for a low price because it was water damaged (wave splash).
I think any more speculation based on the assumption that it is a settings problem is an exercise in futility.
maltmoose Veteran Member • Posts: 3,049
Re: Water Damaged Camera
Yep, never buy a camera with water damage or even no damage..
baobob
I am no t so pessimistic The camera works and it is only 1.5 stops so in Bob i trust
