Want to bring on a boat
SuzukiGS750EZ Junior Member • Posts: 28
Hey guys. I'd like to bring my 5D on a boat out in Salt water. I don't want the spray on my lenses or body. Waterproof housing is 1,500. Do i have any other alternatives?
Andy01 Senior Member • Posts: 4,599
Re: Want to bring on a boat
How big is the boat ? Obviously on a large ship/boat, nothing is required except a strap to prevent you from dropping it overboard. If it is a smaller speedboat or inflatable, then copping sea spray is much more of a reality.
What lenses are you using ?
An option is a "bag" type waterproof enclosure - something like a DicaPac enclosure can be had for less than $100.
Never tried one on a 5D series - the largest I have had in one was a 70D + EF 24-105L when I was snorkeling in Thailand.
There are pretty clumsy to use but they do offer reasonable protection at a budget price - obviously not for diving though.
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF-M 11-22mm f/4-5.6 IS STM Canon EF 100-400mm F4.5-5.6L IS II Canon EF-M 18-150mm F3.5-6.3 IS STM +5 more
OP SuzukiGS750EZ Junior Member • Posts: 28
The boat is about 15 feet and open to spray. I'd be using probably my 16-35 or 70-200. I'm not shy of spending money, but not $1,500 on a waterproof enclosure. I wouldn't mind using my 80D. Both cameras have battery grips. All my lenses are L lenses.
Tom59 Senior Member • Posts: 1,434
5
The optech rain sleeve is a cheap option.  Not completely waterproof but better than nothing. They have a couple different sizes.
You might get a 5D + 16-35mm into a DicaPac bag type enclosure as I mentioned above, but it will not take a 70-200mm. I am not aware of any waterproof enclosure that would take a full size DSLR + 70-200mm - perhaps a rain jacket, which is not waterproof but may be splash-resistant enough for your needs ?
Colin
Ltgk20 Regular Member • Posts: 259
Are you going to be shooting while the boat is underway or only when it's stationary?  If mostly while it's stationary, keep the camera in the bag (or under a towel) while you're underway and shoot like made when stationary.
 Ltgk20's gear list:Ltgk20's gear list
Sony a1 Sony FE 35mm F1.8 Sony FE 100-400mm F4.5-5.6 Sony FE 200-600 F5.6-6.3 Sony FE 55mm F1.8 +4 more
GreatWhiteWing Senior Member • Posts: 1,507
Don't know if still available but I use an Ewa marine bag on a camcorder years ago. Far less than a hard housing and lets you go to like 10-15 deep underwater. I used off the coast of Kauai , Niagara falls and fresh water pools with great results
 GreatWhiteWing's gear list:GreatWhiteWing's gear list
Canon EOS 5D Mark IV Tamron SP 70-200 F2.8 G2 Canon EF 24-70mm F4L IS USM Canon EF 16-35mm F4L IS USM +2 more
Shaun_Nyc
Shaun_Nyc Senior Member • Posts: 2,321
Just be smart about it if the boat is underway, if you feel any spray don't pull the camera out. Use a protect clear filter on the lens that you don't care much about. Have a clean soft cotton type rag available and a bottle of water to moisten towel for camera/lens/filter wipe downs if needed. When the day is over you should wipe down all gear this way to remove salt air residue even if camera was keep 100% dry.
 Shaun_Nyc's gear list:Shaun_Nyc's gear list
Nikon D50 Nikon D810 Canon EOS R6 Nikon AF Fisheye-Nikkor 16mm f/2.8D Nikon AF Micro-Nikkor 60mm f/2.8D +11 more
BirdShooter7 Veteran Member • Posts: 7,022
I’ve done quite a bit of photography from small boats and haven’t ever taken any special precautions.  When I get home I usually just wipe everything down with a damp cloth.  So far so good...
Some of my bird photos can be viewed here: https://www.flickr.com/photos/gregsbirds/
CasperMarly Junior Member • Posts: 27
Saran Wrap. Works well and you can see the viewfinder - if you cut a small hole to view. Also a hole for the front lens element so you are not shooting through the plastic wrap.
Protects and doesn't cost much at all.
Don't drop the camera into the water as this is not a waterproof housing and water will leak in - mainly through the opening for your lens element.
Norm Neely Senior Member • Posts: 2,806
+1
Also consider a Canon 77mm Protector Filter (like Shaun_Nyc mentioned) for your 70-200mm lens. used $41.95
https://www.bhphotovideo.com/c/used/763705?gclid=CjwKCAjwuIWHBhBDEiwACXQYsZwkKdYTtWD_ySqcrjcKNLCjJVCt-kjsYWKdduVtpvidoRE2wyRzLBoCU4UQAvD_BwE
New: $64.95
https://www.bhphotovideo.com/c/product/763705-REG/Canon_2602A001_77mm_UV_Protector_Filter.html
And a lens hood. $44.95
https://www.bhphotovideo.com/c/product/239600-REG/Canon_6746A001_ET_86_Lens_Hood.html
You can start the Saran Wrap by taping to the lens hood.
Basically the only things exposed to water spray will be the protective filter and possibly the viewfinder. Both should be easy to clean with damp fresh water cloth. You could carry the cloth in a zip lock bag.
Or some lens wipes. $9.00 at Walmart.
https://www.walmart.com/ip/ZEISS-Lens-Wipes-Pre-Moistened-Eye-Glass-Cleaner-Wipes-225-Count/125911673?wmlspartner=wlpa&selectedSellerId=0&&adid=22222222227086892990&wl0=&wl1=g&wl2=c&wl3=200342504307&wl4=aud-1025716567856:pla-324175930456&wl5=1027790&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=125911673&veh=sem&gclid=CjwKCAjwuIWHBhBDEiwACXQYsasjCReQvdFByk8kH4jfZJzAwqa3CkzuwD9T3XiXv_SJU3ri6MgEXxoCLcEQAvD_BwE&gclsrc=aw.ds
Norm
 Norm Neely's gear list:Norm Neely's gear list
Nikon Coolpix 995 Olympus SP-550 UZ Canon EOS 40D Canon EOS 5DS R
