Panasonic G7 - Extended ISO option?
Started Jun 20, 2021 | Discussions
Brisn5757 Veteran Member • Posts: 4,540
I was taking some low light photos using my Panasonic G7 camera and found that the ISO value of the photos seemed to be stick on ISO 100 causing very slow shutter speeds. When looking at my camera settings I found the 'extended ISO' had been turned on. When I turned it off and tried to take low light photos the ISO then gave me higher settings.
I couldn't find much information about this setting for a Panasonic G7 camera so I'm hoping that someone can tell me what this setting is for.
Brian
 Brisn5757's gear list:Brisn5757's gear list
Olympus SP-570 UZ Sony Cyber-shot DSC-WX70 Sony Cyber-shot DSC-HX200V Sony RX100 IV Canon EOS 300D +9 more
Panasonic Lumix DMC-G7
pannumon Veteran Member • Posts: 4,130
Re: Panasonic G7 - Extended ISO option?
Brian
Extended ISO enables ISO 100 (and perhaps ISO 25600?). Normally, the lower the ISO, the better the image quality. With G7, this is true at ISO 200 and higher. Anything lower than ISO 200 does not really provide better image quality. However, there is still an option to use ISO 100 if it is needed for some reason. This is called extended ISO.
When you are in other modes than full automatic, pressing the up key from the 4-way controller (ISO button), one of the two dials will choose ISO and the other will choose the max ISO. Max ISO will be used if you select AUTO ISO (or intellect ISO or whatever it is called). If you choose ISO 100, the camera will use it no matter what.
Panasonic Lumix DMC-GF1 Panasonic Lumix DMC-GH2 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GM5 Panasonic Lumix DMC-G7 +21 more
OP Brisn5757 Veteran Member • Posts: 4,540
Brian
Thanks pannumon.
From what I understand when using Extended ISO the exposure is locked at 100 ISO and it's up to me to change the ISO settings to a value greater than 100.
I'm not certain what the different between Auto ISO and intellect ISO as it seems either way that camera will  be automatically choosing the best ISO setting.
I got caught out when taking a few low light photos. I should have paid attention to what the camera setting was showing in the view finder. Also checking one or two photos afterwards. But lucky the camera shake photos were not important to me.
Does these ISO settings also effect the video recording?
Brian
Tim Reidy Productions
Tim Reidy Productions Veteran Member • Posts: 5,296
From what I read, you probably want to avoid the extended ISO, you may not like it.
I like images from 200-1600 iSO with this body.
 Tim Reidy Productions's gear list:Tim Reidy Productions's gear list
Panasonic Lumix DMC-FZ200 Pentax K-7 Pentax K-3 Panasonic G85 Olympus E-M1 II +3 more
The title for this option seems misleading as I first thought it would extend my ISO to higher values than what the camera normal goes up to.
I have now turned this option off.
Brian
alcelc
alcelc Forum Pro • Posts: 19,006
Brisn5757 wrote:
Brian
Thanks pannumon.
No. If you are under Auto ISO or iISO, the camera is still free to adjust ISO by itself upto the ISO ceiling that has been set.
I guess you were actually using manual ISO mode. After enable Extended ISO in REC Menu, you might have set ISO to 100. Once a particular ISO value been used, we are entering manual ISO mode.
Yes, it is what manual ISO works.
Extract from the pdf manual of G7
iISO will not support S and M shooting mode.
Although I shoot with A most of the time, TBH I really can't find the beauty of iISO, so on conservative basis I stick to Auto ISO on my every Panny camera.
Some limitations for Video shooting:
1) In Creative Motion Picture mode (not use under full auto video mode by using the red REC button), "AUTO/200~6400" will be available.
2) For Video (might include both of full auto mode and Creative Motion Pict mode?), UPPER ISO LIMIT is not supported.
Brian
Wish the above could help.
Albert
** Please forgive my typo error.
** Please feel free to download the original image I posted here and edit it as you like **
alcelc wrote:
Brisn5757 wrote:
Brian
Thanks pannumon.
Brian
Thanks Alcelc.
Useful information.
In my case I just turned off Extended ISO and the iso automatically set its self to the best value.
Brian
