Carl Zeiss Biometar 2.8/80mm on Nikon body
F8AD
F8AD Forum Member • Posts: 65
Have any of you members tried the medium format P6 mount on a Nikon using the P6-Nikon F adapter ?
Were you happy with the results ? Disappointed with some IQ ? Full frame or DX ?
Thanks in advance for any opinions! I am just considering it for future use.
Lightshow
Lightshow Veteran Member • Posts: 7,615
Re: Carl Zeiss Biometar 2.8/80mm on Nikon body
I haven't.
I believe the optics were also used in Exakta and possibly in M42 lenses, so, IQ on FF should be good.
P6: http://allphotolenses.com/lenses/item/c_358.html
Exakta/M42: http://allphotolenses.com/lenses/item/c_4126.html
I have a silver 80/2.8 Tessar in Exakta that is similar, IQ is great and the Biometar is supposed to be better, my Tessar has an easily removable mount, so modification to a different mount should be super easy compared to other lenses, I think the Biometar may be similar. Edit it is not.
A Manual Focus Junky...
One photographers junk lens is an artists favorite tool.
http://www.flickr.com/photos/lightshow-photography/
[My Lens list](http://www.fredmiranda.com/forum/viewprofile.php?Action=viewprofile&username=LightShow)
####Where's my FF NEX-7 ?????
https://c1.staticflickr.com/1/447/31518420576_7916966b11_b.jpg
https://c2.staticflickr.com/2/1962/31024497798_85526ac8ca_b.jpg
Firmware request:
-A button map for toggling the EVF & LCD
-Still waiting for the minimum shutter speed with auto ISO for my NEX-7 and A7r. I know it will never happen.
-Customize the display screen layout, I'd love to have both Histogram and level at the same time.
-More peaking options, being able to set peaking sensitivity and a threshold level.
-An RGB overlay on the histogram https://c1.staticflickr.com/1/602/20236258313_c604dd9522_n.jpg
-An option to return the focus assist zoom to one button press
-An option to return to how the NEX-7 handled playback, ie. center button to zoom, then you could use the control dial to zoom in and out, then center button to exit the zoom mode.
 Lightshow's gear list:Lightshow's gear list
Sony Alpha NEX-7 Sony a7R Leica Elmarit-M 24mm f/2.8 ASPH Leica APO-Summicron-M 90mm f/2 ASPH Voigtlander 15mm F4.5 Super Wide Heliar +20 more
F8AD
OP F8AD Forum Member • Posts: 65
Thanks for your comment, Lightshow.  Nikons have such a deep flange register that medium format lenses are usually a good bet .They are made in other mounts.
Lightshow
https://www.pentaconsix.com/80mm.htm
Firmware request:
