There should be a mft webcam body
Started 7 months ago | Discussions
tehdehzeh Forum Member • Posts: 57
Okay, so like probably many of you, I am using one of my cameras (GX85) as a webcam in my home office, and I enjoy how that enables me to be seen even though my desk is in the worst possible spot with more or less direct sunlight behind me for most of the day. However, it is kind of cumbersome. I need a HDMI capture device, I need to remember to check the battery before I start a meeting, because the GX85 doesn't charge via USB when it's on (I know there are AC adapters, but I don't have one), and also I need to frequently disassemble the rig, because it is my main camera (the others I have don't put out live view on HDMI..).
Now, of the current crop, the cheapest option that is directly compatible with Pana/Oly webcam software is the G100, but that's still around 500€, which is quite a lot if your use case is only webcam. Also it has a lot of features a webcam doesn't need.
So what I wish would exist (for let's say half the price?) is a minimal webcam-only body. No IBIS, cheapest 4/3-sensor that can do 1080p, no screen, no viewfinder, no buttons (you should be able to select aperture, focus method, etc in the webcam software), no flash, no SD card slot, no battery. Just a sensor, a flange, a mount point and a usb socket.
I would buy one, who else?
(I am sure lots of people will explain why it's not going to happen - I know! I just wish it would ;))
 tehdehzeh's gear list:tehdehzeh's gear list
Olympus OM-D E-M5 Sony a7 Panasonic Lumix DMC-GM1 Panasonic Lumix DMC-GX85 Panasonic Lumix G 20mm F1.7 ASPH +11 more
Gabriel Perez New Member • Posts: 4
Re: There should be a mft webcam body
Maybe the Olympus Air should work
kalisti
kalisti Contributing Member • Posts: 618
BGH1
or
A decent webcam, with some lights.
 kalisti's gear list:kalisti's gear list
Panasonic Lumix DMC-GX85 Panasonic Lumix DC-G9 Panasonic Lumix G Vario 45-150mm F4-5.6 ASPH Mega OIS Panasonic Lumix G 14mm F2.5 II ASPH Panasonic Leica 12-60mm F2.8-4.0 ASPH +2 more
OP tehdehzeh Forum Member • Posts: 57
I have never seen one in the wild, but it seems to me that it can only tether to a smart phone with the app, and hence not be used as a webcam on a normal computer?
Dann-Oh Contributing Member • Posts: 571
We just bought a web cam for like $30USD for my wife to work from home.  it does a great job handling the harsh side light from her home office window.  its going to be hard for a camera company to compete in the oh so cheap webcam market.
I take photos, not particularly good photos, mostly abstract photos. Yeah abstract is what I would call them, you might call them blurry.
 Dann-Oh's gear list:Dann-Oh's gear list
Olympus E-M5 III Olympus E-PL10 Olympus E-M1 III Panasonic Lumix G Fisheye 8mm F3.5 Olympus Zuiko Digital 2.0x Teleconverter EC-20 +15 more
SDreamer Forum Member • Posts: 50
I can see the want, but I don't think any company would do it. You can pretty much get an older mft body that supports a clean HDMI out with a dummy battery for maybe the price of what a company would charger for a webcam like that.
 SDreamer's gear list:SDreamer's gear list
Olympus OM-D E-M10 Olympus E-M5 II Olympus E-M5 III Olympus M.Zuiko Digital 14-42mm 1:3.5-5.6 II R Olympus M.Zuiko Digital 17mm F1.8 +6 more
Yeah, this is the path I'm looking at. Like a GH3 or a G7 so.
Or an EM1.1.
These are all still not that cheap though. I guess I could maybe be lucky and find a defective model where the defect is irrelevant for my use case (broken display or such)
Michael Meissner
Michael Meissner Forum Pro • Posts: 27,273
Well yes and no.  I briefly had the Air A01 and I returned it as unusable.  It was a revision 1.0 product.  Perhaps it was useful to the developers to refine the OIShare interface, but I couldn't get it to work.
 Michael Meissner's gear list:Michael Meissner's gear list
Olympus Stylus 1 Olympus E-5 Olympus OM-D E-M5 Olympus Zuiko Digital 14-54mm 1:2.8-3.5 Olympus 14-150 F4-5.6 II +23 more
Michael Meissner
Or an EM1.1.
No, an E-m1.1 will not work. Olympus did not support live view through HDMI until the E-m5 mark II came out. On cameras before the E-m5 mark II, if you plugged in an HDMI cable, it would immediately send the camera into review mode (on the assumption you hooked up the camera to a TV to review pictures).
But I believe the E-m1.1 supported delivering analog video output through a CB-AV3 cable, and you needed a compatible analog device to hook up the yellow RCA jack to. Resolution wasn't that great however.
Michael Meissner wrote:
Or an EM1.1.
Yeah, but it works with the Oly Webcam software via USB, which is even better.
