Is the Godox V1P flash not compatible with the K3?
Started Jun 15, 2021 | Discussions
Richard Smals
Richard Smals Senior Member • Posts: 1,929
I was looking at a discounted Godox V1P flash, but in the specifications/manual the Pentax K3 is not mentioned, only the K3 II and KP, K1, K70 etc..
Is this wrong?
Is the K3 different in flash protocol then the K3 II? Did Pentax change flash TTL and wireless function. The K50 which is from the same year is mentioned though. Strange.
Can anybody give some insight? Thanks.
Bye4now
Richard
Pentax K-1 Pentax K-50 Pentax K-70 Pentax KP
3KK3
3KK3 Regular Member • Posts: 107
Re: Is the Godox V1P flash not compatible with the K3?
Looking at a swedish dealer of Godox flashes and particularly the V1P... there it doesn't  say anything about any specific Pentax camera model.... just Godox V1P for Pentax. I have been using Sigma flashes since 2007 when I bought the K10 and used the same flashes with my K-5 and K-3. With the new K-3 mkIII I haven't yet taken any flash pictures but when I do I wouldn't hesitate at all to use a third party flash since they are made to be compatible for Pentax....
KK
Kobie M-C
Kobie M-C Contributing Member • Posts: 701
The compatibility list from Godox is a list of physical cameras they've had in house for testing. It doesn't mean it won't work. I have the TT350 p and it works fine on my K-3 even though it's not in the "list".
I am not a Pentax insider. I just have a unique way of gaining insight.
 Kobie M-C's gear list:Kobie M-C's gear list
Pentax K-30 Pentax K-3 Pentax K-3 Mark III Pentax smc DA 18-135mm F3.5-5.6ED AL [IF] DC WR Pentax smc DA 50mm F1.8 +6 more
Richard Smals
OP Richard Smals Senior Member • Posts: 1,929
Thanks Kobie, that's great. Thanks for the reply.
Bye4now
Richard
Richard Smals
KK
Thanks, Kobie also mentioned that it what Godox means is that the K3 is not tested, means not it's not working.
Thanks for looking into this.
Bye4now
Richard
James O'Neill Veteran Member • Posts: 6,117
That makes a lot of sense. The manual for the for 540 and 360 FGZ II flash units has a 2013 copyright date on it.  It gives its compatibility as K5, K5-II, k30, K50, K500, K-r and 645D.  The K3 hadn't been launched at that point.  I don't think there was anything new about the flash support in the K5 over the K7.  I don't think the interface between flash and camera hasn't changed for at least 10 years.
 James O'Neill's gear list:James O'Neill's gear list
Pentax K-5 IIs Pentax K-1 Pentax smc FA 50mm F1.4 Pentax smc DA 18-250mm F3.5-6.3 Pentax smc FA 43mm F1.9 Limited +3 more
Richard Smals
That was also my understanding, maybe the Chinese translation into English is at work here. The manual stated: "compatible with Pentax K3II, KP etc..." should have stated that they tested with these camera's.
Sjak
Sjak Veteran Member • Posts: 7,318
When the V1P was released, the K3-3 didn't exist yet, so not surprising it's not mentioned in the manual
 Sjak's gear list:Sjak's gear list
Leica M Monochrom (Typ 246) Ricoh GR IIIx Pentax K100D Pentax K10D Leica M-Monochrom +1 more
Adam007 Contributing Member • Posts: 805
It works
I have both, and they work perfectly together as far as I can tell.
 Adam007's gear list:Adam007's gear list
Fujifilm X100F Pentax K-1 Pentax K-3 Mark III Pentax smc DA* 300mm F4.0 ED (IF) SDM Pentax smc FA 31mm F1.8 AL Limited +7 more
Richard Smals
Some misunderstanding, i was probably not enough to the point.
I was referring to the original K3.
Richard Smals
Re: It works
